Question about Sears Genie Garage Door Gpwk12 Wireless Keypad Compatible with 9 or 12 Dip Switch Genie Max Openers
Program auto w/garage opener
Program automobile w/Genie Power Max 1200 opener
dburns60
  • 410 Answers
SOURCE: Genie Directlift garage door opener, wall control problem.
Sounds like a skinned wire on your front or rear limit switches is touching metal. Go over your low voltage wiring and test again.
Posted on Jul 05, 2009
SOURCE: I have a Genie garage door motor. Whenever I try
check the track for tight spot it will stop if it is not stright, too close or too wide also check cable or chain for dirt lubracate all
Posted on Oct 23, 2009
  • 3197 Answers
SOURCE: Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: Can I use a genie wireless keypad on a craftsman o...
No each manufacturer uses a different code that is built into the keypad.
Posted on May 18, 2010
swolfinor
  • 504 Answers
SOURCE: genie auto garage door. closes then imediately re...
GET A COPY OF THE ADJUSTMENT INSTUCTIONS FROM THE GENIE WEB SITE - IT IS A SMALL AND SIMPLE ADJUSTMENT - BUT, IF YOU MESS IT UP THE DOOR WOULD BE UNSAFE.
Posted on May 23, 2010
swolfinor
  • 504 Answers
SOURCE: i want to program garage door opener to my
IF IT IS A CRAFTSMAN / LIFTMASTER / CHAMBERLAIN IT IS A SQUARE BUTTON WITH A LITTLE LED NEXT TO IT. YOU WILL SEE AN ANTENNA WIRE HANGING DOWN, IT IS ON THAT END OF THE UNIT NEAR THE MIDDLE.
HOPE THIS HELPS
Posted on Jun 18, 2010
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
Unable to program universal opener with genie pro max garage
Actually, this remote can be used with Genie Garages. See the article here on eHow - I used this to program a KLIK1U to work with my Genie Promax 2 garage. Hope that helps!
Oct 11, 2012 | Chamberlain Clicker Universal Remote...
Genie H4000A manual
The garage door will only go down by holding the button on the wall switch
Aug 30, 2012 | Sears Genie Garage Door Gpwk12 Wireless...
I have a genie pro max PMX 300 IC/A garage door opener and bought a Genie 3-button remote (model G3T-R) and I can't get it programmed. I push the button on the back of the opener, push the button
Take the opener apart and see if there are about 4 numbers that can be set. If you have an older remote take it apart and match the numbers, then program it.
Feb 07, 2012 | Home Security
I want to program my Genie ecellerator isd 1000 so that I can use my Homelink system in my car and my wife can continue to use her Genie remote that came with the opener. How can i do this? Thanks
Inside the car press the 2 outer buttons on the homelink until the led light by it goes out or flashes rapidly. This erases all old/factory codes. Hold the remote 1" from the button you want to program and press the button on the remote and the homelink button until it flashes rapidly. Then press the learn button on the motor head and then press the button on the homelink you pressed before 4 times and this should code in. Thanks BB
Aug 21, 2010 | Sears Genie Garage Door Gpwk12 Wireless...
How to program garage opener
SORRY,
Chamberlain key pads won't work with a genie receiver.
You will need to echange it for a Genie brand.
Also be sure what frequency your Genie is - They have changed the frequency a couple of years ago.
Jun 30, 2010 | Chamberlain 740CB Wireless Keyless Entry...
Genie auto garage door. closes then imediately re...
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears Genie Garage Door Gpwk12 Wireless Keypad Compatible with 9 or 12 Dip Switch Genie Max Openers Logo
32 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
