Question about Multitech Systems FF220 2 Port V.34 FaxFinder
Can't log in to multitech fax finder 2200. Default username and pword supposed to be lowercase admin but it's not working. any idea how to reset it?
If you can help me access it. I'd be eternally grateful
When I try to log in it says wrong username or
Type the router ISP 192.168.0.1 then it's usually user : admin
pass: admin all lowercase then you can reset password etc.
Sep 13, 2014 | Computers & Internet
Password and user access point ap 2750
Default Settings for accessing the AP as admin:
  • Default Username / UserID: (leave blank, try admin if prompted)
  • Default Password: admin (lowercase only)
  • Default IP Address: 192.168.1.1
  • Default Netmask: 255.255.255.0
Jun 10, 2011 | 3Com AP2750 802.11a, 802.11g/b...
Do not remember passwork
if you have changed the password from the default, you must reset the router.
then you can use the default password.
if you have not changed the password, and simply dont remember the default log on is:
username: (keep blank)
password: admin (all lowercase)
Mar 28, 2011 | Linksys Wireless-G WRT54G Router
When using set up system is asking for a password for linksys G
have you tried entering a blank username i.e. enter nothing? and use admin as the password
if that doesnt work look on the label on the bopttom of the router your isp might have configured it with there own username and password
if you find this info useful please vote
Feb 23, 2011 | Linksys Wireless-G WRT54G Router
How do I log into my router config if I don't know the password? I've tried pushing the button on the back to reset but that didn't work
Hi vmontour,
To Factory reset your router you need to locate the Reset Button at the back of the router. The Reset Button is the small hole at the back and you need a Pen or a Paperclip to press it. Press and hold the reset button for 15-30 seconds. Make sure that the router is on when you reset it.
To access the router page just open a browser then type 192.168.0.1. the username is admin and the password is blank.
Rate me if this will help you so that i can help other people.
Thanks for using Fixya.
Jan 31, 2011 | D-Link AirPlus DI-524 Wireless Router
Default login for samsung syncthru
the username is
Admin
Password is
sec00000
Aug 11, 2009 | Samsung CLX 3160fn All-In-One Printer
Need to find existing WEP ID, do not want to reset my WEP ID
Flip over your ACTIONTEC and you would see there the default wep key. If you've had it personalized before, you have to open the configuration page of your modem and check for the wep key.
To go to the configuration page, open your internet explorer and type in 192.168.1.1 on the address bar. that is the default address for your actiontec. type in your username and password when prompted. the usual default it ADMIN for username and PASSWORD (lowercase) for password. or you could also try ADMIN (uname)-ADMIN(pword).
click on the wireless settings icon and then click on basic security settings. scroll down on the middle of the page and you will see there your wep key.
if you are unable to open the configuration page because you forgot your username and password, you can reset your modem so that it the uname and password will go back to its factory default settings (admin/password). However, if you are using pppoe connection (authentication using username and password to connect to network) you can lose your connection and you would have to configure your router. so be careful not to press the reset button at the back.
Apr 19, 2009 | Actiontec (5GE583000-01) Router
Problem in setup wireless router,need default security key/phrase
If there reset the router to the factory settings:
Default Username: admin (lowercase)
Default Password: none (none, leave blank)
If this doesn't work, try pressing the reset button for 10 seconds with it powered ON. Then try it off. I can't remember which one will work.
After this is complete, username: admin and password: (nothing, blank, nada) will work.
Good Luck!
Apr 07, 2009 | Hawking 54M WIRELESS G ROUTER AP 4PORT...
Lost Password
Default IP is 192.168.0.10
There is no default password.
BTW-did you try that yet? No password that is....
Jeff
Feb 02, 2008 | D-Link DP 101 Print Server
Multitech Systems FF220 2 Port V.34 FaxFinder Logo
71 people viewed this question
Top Multitech Systems Computers & Internet Experts
Vladimir Frolov
Larry Fostano
Larry Fostano
Karen Gibson
Level 1 Expert
Are you a Multitech Systems Computer and Internet Expert? Answer questions, earn points and help others
