Question about Mitsubishi LT-52153 LCD TV
3" vertical blue line in center of TV
Constant 3" vertical blue line in center of Mitsubishi Tv, Model #LT-52153
    Scholar:
  • 63 Answers
Defective panel or signal controller. Will require professional repair. If the TV is under warranty, you'll be fine. If not, start looking for a new TV as the cost of repair will likely be more expensive than a new TV.
Posted on Mar 28, 2014
herman2008
  • 7 Answers
SOURCE: Vertical lines on my 40 inch lcd mitsubishi hdtv 1080.
I assume your Misubishi is not close to anything electrical. However, it sounds like you have had an interference for some time. This will ineviteably cause the HDTV LCD to collapse. LCD's don't respond well close to heat. Is there a vent close? LCD's do well in a properly vented area but with all this said.......they will pick up interference from anything electrical. A few questions to ask ones self........are there any wireless devices or chargers close to the LCD? Might there be an oven, a/c unit or other wiring with 220 volts anywhere close to the LCD such as in the wall?
The Mitsubishi LT is a very reliable, multi component ready set that allows great viewing with surround sound. However, stop and think about this interference. It is not something in the unit. It is an interference. Look hard and when you've discovered it.....you won't believe how crystal clear this set will be.
Let me know what you find...Thanks for using Fixya and add any comments that may help us help you.
Posted on Jan 16, 2009
jhinsincity
  • 616 Answers
SOURCE: I have a LT-46244 and there are two vertical black
No format burn-in if thats what you mean, tv needs to serviced. good luck Julio milleniumtvsvc@gmail.com
Posted on Jul 23, 2009
  • 53 Answers
SOURCE: vertical lines on my 40 inch lcd mitsubishi hdtv 1080
Bad/Going Bad/Will go horribly bad TCON board (small circuit board sitting at the top of the panel in the back).
Most likely, the whole panel will need to be replaced in order to rectify the issue.
Posted on Aug 01, 2009
  • 3 Answers
SOURCE: Mitsubishi 40" TV, LT-40134 Vertical lines on left side of screen
I've got the same TV with the same problem. Sometimes by moving it on the stand the lines will go away but it only sometimes temporarily fixes the problem. For a while it seemed like it needed to heat up to go away but that is not the case. It seems like there is a bad connection somewhere but i cant seem to find it. One day, one thing will fix it, then the next day it wont do the trick. It gets very irritating.
Posted on Oct 26, 2009
  • 301 Answers
SOURCE: i have a 5 inch vertical bar on the right side of
that problem is going to be an LCD panel failure. it is actually a T-CON failure but mitsubishi doesnt sell the T-CON board by itself i suggest calling mitsubishi about possible repair accomodation customer support phone number - 1(800)332-2119 good luck
Posted on Jan 06, 2011
Vertical lines blue
Check area around TV for interference--cordless phone--wifi---also check input cords and hdmi cable or coax cable--- make sure connections are tight and secure
Aug 18, 2012 | Mitsubishi LT-52149 52 in. LCD HDTV
I have a Mitsubishi LT-52153 that has no sound. I have reset the tv as well as double and triple checked the audio input. i still dont get any sound from its speakers
Check in set menu and a box menu for the following:
Volume is not turned down or muted (both set and a box if used)
Speakers in the set are not switched to OFF.
If set has external hookup for speakers that is not selected (internal/external switch)
Lastly if set works with a DVD etc it has to be a setting either in the set or a cable or sat box or even a receiver if used causing this)
Apr 22, 2012 | Mitsubishi LT-52153 LCD TV
When I turn the TV on it goes to the blue screen but nothing works then the TV powers off on its own.
Blue screen usually indicates no input. Check the input selection. Check the cables from the source. If everything is correct, try this: unplug the TV, press and hold the power button for 30 seconds, repeat. Plug it back in and try again.
Apr 18, 2011 | Mitsubishi LT-52153 LCD TV
TV powers off and will not reset. The power light keeps blinking
Count the number of blinks and make note of the sequence, if there is any. The lights and sequence will tell you what is wrong with your tv. Google the make and model with "blink codes" at the end. From there, you can find a site that will tell you what the code means.
Feb 11, 2011 | Mitsubishi LT-52153 LCD TV
Oct 09, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Jul 23, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Line in left side of screen
bad panel call mits has 2 year extended warraty for panel, need to call for authorized service center
Jun 04, 2009 | Televison & Video
Similar problem with an eleven and a half month old LT-40148. Approx. 1 inch vertical banding line on left side of screen on all inputs. After about two weeks, same problem on the right side of the screen.
Fortunately this occurred two weeks prior to the one year warranty expiring.
Called Mits customer service and they referred me to an authorized service center who I happened to have dealt with before.
They picked up the set. The front panel (LCD screen ) had to be replaced. Set was gone for two weeks as parts were not in stock. There was no charge. I hope this screen last more than a year.
Jan 16, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Mitsubishi LT-52153 LCD TV Logo
164 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
