Question about Vehicle Parts & Accessories
On 1998 Itasca sunflyer the big slide out is stuck in the retracted position. When I push the switch to extend, the motor doesn't run. When I push the switch to retract, the motor does run. Is ther
Slide out won't work
  • 336 Answers
Make sure nothing is in the path of the slide if not then use WD40 twice a year on slide
Posted on Apr 30, 2014
2015 keystone Laredo 312re Slide not extending all of the way out. Supposed to be a manual override, but where?
I had this problem several years ago.
Problem can occur at least three ways:
1. Most likely, something is in the way. A displaced trim molding, the rubber seal has moved, or ? With the slide only slightly extended, using a flashlight and mirror, examine every part of the seal/body junction inside and out that you can. A straightened coathanger can help remove a foreign object.
2. The slide might be binding. The motor would hang, draw excessive current, and shut down. Testing this would involve manual slide extension. Not familiar with Keystone, but typically, you run it out with a crank. The crank location is a round opening under slide. Depending on length of slide, there may be two. If two, they must be actuated together, or each one alternately, a little at a time. On some brands, the gear train between actuator motor and slide MUST be disengaged to allow manual extension/retraction, it depends on how the manual extension works. Hopefully you have a manual that can explain the procedure. The crank(s) to extend/retract are usually stored in the bay(s).
3. The motor has weakened. This is unlikely, if the problem is just the last inch or so.
Dec 13, 2015 | RVs
2011 Honda Ridgeline center console cup holder can't retract. Stuck in the extended position. Won't close. Hits something.
Most often it is just gummed up with soda syrup. spray a little armor all into the mechanism and let it sit for a few minutes, then operate the mechanism. repeat until it works smoothly again, making sure to wipe any excess fluid up. Hope this helps.
Nov 11, 2015 | Honda Cars & Trucks
I have 98 grand prix ignition is stuck in start had to pull fuel pump fuse but cant shut car off lights are still on
Suggest disconecting the battery. Then you can work on the problem. it is not clear if the issue is the key stuck in the start position in the iginition switch or if the starter motor is stuck (running) after the car starts. If it the starter motor is running... Time for a new starter. If it is the ignition switch, try
pushing the key in and turning back off. Still stuck? Try pulling pn the key and turning off. Either way, if it is the key, yime for a new ignition switch.
Jan 29, 2015 | 1998 Pontiac Grand Prix
What do i do when my slideout isn't responding.
Can you get to the motor wiring connector? Check power source fuse/breaker first to make sure you have power. Use test light or meter to see if power is coming to motor. If yes does the motor make any noise? Check for jam? If no power to the motor, pull the switch and check for power on both sides when in the on position. You may also have a safety cutoff switch in the circuit to shut the motor off when the slideout is fully retracted...check it to make sure it is working or not damaged. It may be stuck in a position that kill the power to the motor. You may be able to jumper around switches, or pull wires off, to perform open/closed tests.
Jan 23, 2015 | Cars & Trucks
Repair slide <living room is extended and won`t return>
Check to ensure nothing is blocking the slideout, its path or the gears of the motor. If you don't see a dimming of the lights when you push the retraction button or don't hear any motor noise check the fuse for the slideout motor. If all else fails there should be a manual slide retraction option somewhere that allows you to retract the slideout using a crank or a power drill. Check the owner's manual.
Sep 28, 2014 | Coachmen 2009 Concord 300 TS
Rv slide out
Check the switch inside the coach. Usually either the switch or the breaker fails.
Aug 16, 2014 | Fleetwood 2009 Tioga Ranger 31N
How to fix a stuck seat belt VW GTI 2009
I just solved the problem for a stuck rear center seat belt in my 2002 Jetta.
Flip the base seat cushion forward against the front seat backs. Trace down along the belt to its tether point on the floor. The belt is sewn around a steel loop. The loop is anchored to a black steel hook. A thin silvery retainer plate is spring tensioned on top of the loop to prevent it from sliding off of the hook when the seat back is folded.
Therefore, you need to press the silvery retainer plate away from the hook (push up) to allow the loop to be slid from the hook. The belt was tight with the seat back in the upright position, so it was necessary to fold the seat back forward to create slack in the belt. Now push the belt loop towards the trunk and slide it off of the end of the hook (only possible with the retainer plate pushed up out of the way).
Now with total release of tension on the system via the bottom end of the seat belt being untethered and with the seat back returned to the upright position, normal extension and retraction of the belt will be reestablished. Next, simply extend the seat belt and slide the loop back into place over the floor hook. It snaps past the silvery retainer plate without all the effort required to hold the plate up during removal of the loop during disassembly.
Check again, the seat belt should be extending and retracting properly. Now just put the seat cushion back into regular position and you will be able to safely buckle up three people across the back seat.
It took about as long to do this repair as it has taken to post this answer to the problem. Note, the seat belt safety mechanism only allows normal extension and retraction of the belt when the seat back is upright.
Nov 29, 2009 | Volkswagen GTI Cars & Trucks
2003 gmc mirrors do not fold in
The power mirrors are controlled by a module (computer) DDM - drivers door module an the PDM - passenger door module .
Folding Mirror System
Folding Mirror System Controls
The folding mirror system requires signals from 2 separate switches. The mirror select switch must be in the neutral/fold position and the mirror direction switch must be activated to the left/extend or right/retract positions. Both switches are integrated into the DDM and provide direct signals.
Folding Mirror System Operation
Upon receipt of the required switch inputs the DDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function. The DDM will also send a class 2 message to the PDM indicating the requested function. The PDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function.
Power Mirror System
Power Mirror System Components
The power mirror system consists of the following components:
• The driver door module--Class 2 module with integrated switches and requires programming when replaced
• The passenger door module--Class 2 module with integrated switches, requires programming when replaced and also contains the RFA receiver
• The power mirror direction switch--Integrated into DDM and is a 4-position momentary switch that provides a signal input to the DDM for up, down, left/extend and right/retract with a mirror switch activation
• The mirror select switch--Integrated into DDM and is a 3-position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• The left outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The right outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The body control module--Class 2 module that requires programming when replaced, serves as the power mode master and is the main message handler
• The DDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The PDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The memory switch, if equipped with memory mirrors--Supplied power by the DDM and provides a voltage signal to the DDM upon a switch activation
• The horizontal and vertical position sensors, if equipped with memory mirrors--Supplied a 5-volt and low reference by the DDM/PDM and provide a variable voltage signal to the DDM/PDM that is proportional to mirror position
• The park neutral position switch, if equipped with memory mirrors--Provides transmission gear selection information to the PCM and is used for memory recall and mirror tilt in reverse functions
• The powertrain control module, if equipped with memory mirrors--Class 2 module that requires programming when replaced and provides Class 2 message indicating transmission gear selection
• The driver information center (DIC), if equipped with memory mirrors--Part of the instrument cluster which is a Class 2 module that requires programming when replaced and is used to personalize the memory recall and mirror tilt in reverse functions
• Fold motor in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
Each of the outside power mirrors contains 2 reversible motors to provide horizontal and vertical movement of the mirror glass. The vertical motor operates the up and down directions and the horizontal motor operates the left and right directions. If equipped with power folding mirrors, each outside power mirror will contain a reversible fold motor to operate the extend and retract functions. Each of the mirror motors are circuit breaker protected.
DTC B1722
The driver door module (DDM) and passenger door module (PDM) switch the mirror fold motor control circuits to battery voltage and ground in response to mirror extend or retract command.
Apr 06, 2017 | 2003 GMC Yukon XL
Antenna motor runs while the radio is on or off. The antenna is stuck in the extended position. When the car is shut off the antenna motor continues to run to retract the antenna, but it doesn't go
You need to pull the fuse for the antenna or just unplug it. It has a fairly ridgid plastic wire that pushes the antenna up and down. Works fine until the wire breaks then it rolls up (antenna down) but it never increases resistance because the antenna never comes down , it's like a fishing reel when the lure breaks off, so the motor thinks that the antenna is still coming down and it will run and run and run trying to do it's job. Your lucky it stuck up and not down. If you want your antenna to go up and down again you'll have to buy and install a new one.
Jun 02, 2009 | 1992 Jeep Cherokee Limited
Vehicle Parts & Accessories Logo
61 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
