Question about Generic Laser Compatible Dell 2330 2350 6000 Page Yield ADS330-2649
My dell 2350 dn feeds to much paper causing jam
Feeds too many sheets of paper at once causing jam
    Scholar:
  • 63 Answers
Step 1: Try fanning the paper at the feed edge before placing it in.
Step 2: Ensure that the paper is placed in with the edge curl up. When holding a bunch of paper between two fingers, the paper will naturally have a curl to it. It should be placed in "happy" (Edges up).
Step 3: Inside the printer's paper tray and where the feed mechanism is, locate the feed rollers and static feed pad. These will all be rubbery or "foam"-like. They should always be slightly tacky when rubbed against, however paper dust will eventually cause them to become slippery instead. Rubbing alcohol can be used to clean them with care and a Q-tip and recover the slightly rubbery, tacky feeling, thus resolving misfeeds.
Posted on Mar 28, 2014
Dell 1720 printer single-sheet feed stopped working
Pull out the paper that is jammed and continue.
Nov 29, 2012 | Office Equipment & Supplies
Ricoh SP C410 DN jam from bypass
If you can take off the bypass unit, two screws and a harness, you may be able to check the shaft, bushings and rollers. Sometimes removing jammed paper cause parts to get out of normal position. The grinding noise for example, gears not meshing together correctly. If it worked before the jam, then that is where I would look.
Apr 20, 2017 | Ricoh Aficio SP C410DN Laser Printer
PAPER JAM
When the paper goes it on the inside of the printer grabs both side which what feeds it through, if it is not tight enough will cause paper jams, open it back up and check the roller to see if it can be adjusted if it cant then you will need to buy a new one, this usualy happens when it has had too many paper jams forcing the gap to increase in size and not allow the collection of one but many, on single sheets of paper the gap wont be small enough to collect 1 sheet anymore.
Aug 18, 2012 | Dell 810 All-In-One InkJet Printer
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Jun 03, 2010 | Kyocera FS- 4000DTN Laser Printer
Several pieces of paper feed at once causing printer jam
Clear jam, if not already done so.
Cheap paper will and does cause jams a lot, like me spend a little more for quality. Not too much!
When placing in tray hold amount of paper in your hands and twist and wiggle, this has the effect of seperating the paper sheets that and do stick together. The more wriggling the better chances of paper running free. But rem, jams do happen even with better grades of paper.
Finally, have a good look at the front of the printer rollers for tiny bits of paper that you might not at first to see?
Nov 12, 2009 | Dell P1500 Laser Printer
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Dell 922 All-In-One Printer will not print anything
The printer does not feed paper from the tray and then states that there is a paper jam. I have removed all paper and there isn't a paper jam. It will feed paper through the lower roller and straight into the printed paper tray, but will not feed a new sheet.
Nov 01, 2008 | Dell 922 All-In-One InkJet Printer
HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
False paper jam
If the paper is lodged too far into the printer and can't be removed:
Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for inkjet printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
Apr 25, 2008 | Dell 922 All-In-One InkJet Printer
Generic Laser Compatible Dell 2330 2350 6000 Page Yield ADS330-2649 Logo
76 people viewed this question
Top Generic Office Equipment & Supplies Experts
EE Eddie
Gilbert Ruiz
Tom Chichester
Are you a Generic Office Equipment and Supply Expert? Answer questions, earn points and help others
