Question about Pyle Pro Pttcsm60 Turntable Boombox Multimedia System
Some of my records keep jumping the songs, how do i solve it?
Songs keep skipping in some records
Turntable skips regularly
Once adjusted to the correct weight for the type of cartridge then the arm should only jump on a bad record. If it keeps on jumping then either there is something wrong with the platter, being warped or a bad matt. Or there is something in the mechanism that is causing the jumps. Either of these two causes is possible if it does it in the same position on two different records.
Mar 05, 2014 | Technics Audio Players & Recorders
Marantz tt 530 turntable
The needle skipping is caused by (A) a worn stylus. (B) not enough pressure. Which is solved by adjusting the weight on the end of the arm. It can only really be solved by trial and error. You increase the weight slightly, then play the record. You keep doing this till the record stays in the grooves but doesn't make a rumble sound. If it starts to rumble reduce the weight.
Aug 20, 2013 | Audio Players & Recorders
Hi. I have a technosonic kha712 model and my needle skips over the first 10-15 seconds of the first song on every record. Is this fixable?
You could try increasing the weight at the end of the turntable arm. It will be a question of trial and error. Trying a record to see if it stops, but putting to much weight will make the sound rumble.
First however check to see if there's something on the arm somewhere that makes the record jump. Could be anything: muck, a pin, or a wire.
Aug 07, 2013 | Audio Players & Recorders
My Sony mini hifi component system is going berserk!! 2 problems: 1- CD system skips tracks and on playing on repeat song, the song skips certain times and jumps ahead of the track. 2- Tape system plays...
Your cd player is fubar and in definite need of replacement.
Tape unit seems to have a mind of its won. Try to reset the electronics to factory defaults. If that has no remedy, since it is a sony< best advise is to trash it. Repair cost is prohibitively expensive.
Sep 19, 2017 | Sony MHC-RG222 CD Shelf System
Itunes skips during music playback
Boot to safemode and see if it does the same thing.
Oct 16, 2017 | Apple iTunes
Recording not right
Check the recording buffer latency on your recording software. And so you know, you should max your ram out with that soundcard. or have everyone record there parts in as, 5 ins is alot for a machine to process, especially if youre recording to 1 track..brutal, and the final recording will be real muddy.
Keep me posted.
Oct 25, 2007 | Behringer (UCA202) Sound Card
Pyle Pro Pttcsm60 Turntable Boombox Multimedia System Logo
50 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
