Question about Zebra TLP 2844-Z Thermal Label Printer
TLP 2844-Z prints half the label info on half the label
TLP 2844-Z prints only the right half of the label information on the left half of the label.
  • Jenika Schmidt
    Jenika Schmidt Mar 31, 2014
    We have tried everything in the user manual to try and fix this. I am not sure that we have tried the "Q" values. Can someone please get me the steps to check these? Thank you for all your help.
    Champion:
  • Zebra Expert
  • 285 Answers
Check the label megerments at driver, or reset printer to default settings. you can also print settings direcly from printer without connect with computer, if still doing than, its possible the printhead its faulty. but before replacet please run test after factory default. hope it helps. Paulo.
Posted on Jun 01, 2014
SOURCE: trouble printing using Zebra TLP 2844-z
Does the tlp2844 come with a ribbon
Posted on Apr 08, 2008
itdude4321
  • 13 Answers
SOURCE: TLP 2844 skips over labels
The first thing I would do is to default the printer then run a width calibration. The instruction are in the user's manual that should have come with the printer. If the instruction did not come with the printer I can provide the instruction.
Posted on May 08, 2008
SOURCE: TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Posted on Jan 05, 2009
  • 62 Answers
SOURCE: TLP 2844-Z is faded on the right half when it prints
above (calibration) solution would work on a TLP2844 not a TLP2844-Z.
Reset Z model by loading media, Turn printer on and get a green light (Ready).
Then hold down feed button and wait for flashing led sequence.
Release button after 4 flashes (Performs reset)
1 flash - prints config
2 flashes - performs calibration.
There is no mechanical adjustment of the printhead on desktop models. Try cleaning the printhead with isoproply alcohol and a cotton bud.
Posted on Apr 21, 2009
  • 130 Answers
SOURCE: Trying to Print USPS Labels from PayPal on TLP 2844
see if you can set the printer preferences to borderless printing.
Posted on Jun 14, 2009
Scaling issues with zDesigner 2844-z
You need to set the label size in the driver. Goto printers and faxes then right click on your zebra printer driver. Left click properties and then left click the advanced tab, then left click printing defaults button and the size is listed there.
May 03, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Using tlp 2844-z
hold the green feed button down intill it flashes 4 time to default the printer and calibrate it
Apr 07, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844 label printer only printing left row of labels
I am not sure what you are describing here, if the prints are left justified this is just a setting. If you are saying that the print doesn't come out on the right side there could be several problems. Please find a qualified engineer to assist
Mar 10, 2010 | Zebra TLP 2844 Label Printer
I have TLP 2844 its printing very poor quality
Download zebra setup utility and use it to configure print quality.
Sep 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
TLP 2844 GAP sensor problem (I guess)
I had the same problem. I found out later there was a small piece of label sticking against the sensor, thus blocking the sensor from sensing the end of the label. As soon as I removed the label (open the cover, it is on the top part) it immediately started to work as usual. Hope this helps.
Apr 22, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Tlp 2844z printer prints far to the left
Check the Driver Setting if its define the size of your label Q#what software are u using?
Mar 18, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Dec 08, 2008 | Zebra LP 2844 Thermal Printer
Problem printing on Glossy Label [butterfly label] using Zebra TLP 2844 EPL
You must make sure that the ribbon is compatible with the label you are attempting to print on. It must be a permanent resin. We use the AXR7+ material. Try to avoid using such a high printer head temperature as this will reduce the life of the head.
Dec 26, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP2844 Prints Centered and Half the Width
create a word template document with the page size the same size as the label. Set the margins to 0 and fill the label up with text. This should make the printer print right the way over the bale.
Nov 21, 2007 | Zebra Eltron TLP 2844 Thermal Label...
Zebra TLP 2844-Z Thermal Label Printer Logo
296 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
