Question about Microsoft Xbox Console
  1. your controlers could have shorted out
  2. you could need to replace the controler ports
  3. u should open it up and see if everything is connected
  4. if not u could send it to me to fix i have solved this proble maney time befor
Posted on Nov 01, 2007
Microsoft kinect sensor for xbox 360 wont work unless my controller is turned off
Hi Chris, can you please check this setting:
1. Go to "System Settings" on your Xbox 360.
2. Select "Kinect Settings".
3. Choose "Chat Microphone".
How is it configured here?
Mar 23, 2014 | Microsoft Kinect Sensor for XBOX 360
I went to turn on my xbox wireless drum kit and the light just came on for a second and then went out so i replaced the batteries, several times but it still wont come on
Well you can try this solution to get it too work. The thing with the XBOX 360 is that it has a hard time syncing with other controllers made by different companies. So try these steps first and see if they work if not you might have got a set of bad drums.
Step 1. Turn on XBOX 360 Step 2. Turn on drums (hold xbox button on drums). Step 3. Press sync button on 360 (XBOX ligh on console should start circling Step 4. Press sync button on drums [under D pad] (xbox light on drums should start circling)
If this doesn't work then you should RMA the drums to to replace the bad ones.
Apr 23, 2011 | Activision Xbox 360 Guitar Hero II
Xbox 360 game contoller keeps disconnecting and wont reconnect.
You can try switching out new batteries, both the console and controller off and trying to turn one on and then the other and then try a different order of turning them on if that doesn't work, and if that doesn't work then try (after restarting the console and with the controller initially off) using the calibration button on the console and then holding the calibration button on the controller. If that doesn't work, call xbox support.
Mar 01, 2011 | Microsoft Xbox 360 Console
My turbo controller wont connect to the cuztomizer
my new wirless turbo fire 2 controller with rumble will not connect to my xbox 360 console... i' ve tried syncing it several times as instructed but no go...
what am i doing wrong, it will not work with my xbox 360!
Feb 17, 2011 | Datel Xbox 360 Turbo Fire 2 Wireless...
My xbox 360 controllers will NOT sync , i tried looking online and i tried every posible way. But nothing worked , is it the controller or the xbox itself. it worked purfect lasst night and it fell on the...
I'm sure you have tried most of these steps but I'm going to list them any way. So we have a complete picture of the trouble shooting process.
1. Sync system first (By pressing the sync button on the system)
2. Right after you hit the sync button on the system, hit the button on the controller
Try replacing the battery's and or rechargeable battery for the controller. Repeat the sync process above.
Try another controller with your xbox or try your controller with a different xbox. Repeat sync process above of course.
If another controller works with your system than that would indicate that there is an issues with your xbox controller.
If your controller works with another xbox and no other controllers work with your xbox than there is a issue with your console.
For issues related to the xbox I would suggest contact xbox directly by calling 1800 my xbox.
If possible please rate the solution I have posted.
Aug 25, 2010 | Microsoft Xbox 360 Controller
Xbox 360 Wireless Controllers Not Working
Have your Xbox 360 controllers replaced, it still has warranty, i presume. Any type of batteries would work, especially energizer, but you can try the original Xbox 360 controller batteries (rechargeable ones). Xbox 360 Tech Support....
Jun 05, 2010 | Microsoft Xbox 360 Controller
So i have a green xbox 360 controller and a white one. My wireless headset will sync with my green one but when I try to use it with my white one, it is recognized as player two and not syncing with the...
hi there,
just a quicky...but ur wireless headset dosnt sync to the controller it syncs to the xbox :-)
it dosnt matter which controller you use its synced with the xbox & not the controller !
if ur using 2 different controllers depending on which you switch on first will take player 1 as will the wireless headset. if after you have switched it on (the xbox) you decide to use the other controller it will obviousley take player 2 slot (even if you switch the other controller off first) as will the headset !
hope this helps :-)
Feb 13, 2010 | Microsoft Wireless Headset for Xbox 360
Controller wont stay linked .
If you are continually losing the connection between the Xbox and the controller, it is probably a problem with the controller losing power. Try replacing the batteries on the controller.
If that doesn't work, try a different controller and see if the same problem happens. It could be that the controller itself has a problem.
Jul 05, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont synch with my controller even if i tried pressing the buttons
It could either be one of 2 things , your controller is knackered or the wireless board where the power switch is mounted could be faulty, try a mates controller and see if it does the same.
Sep 04, 2008 | Microsoft Xbox 360 Console
Juiced 2-dual action controller not working
Download the xpadder from the website and you are set, works fine with my Logitech rumblepad 2 on Juiced 2 no problems. I don't see that it wont work on Logitech Dual Action controller, it is on the list of controllers that xpadder support
Feb 06, 2008 | Logitech Dual Action for Pc (963292-0403:)...
Microsoft Xbox Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
