Ford motors crack windshield
    Master:
  • 680 Answers
Replace it. You should repost this in autmotives.
Terry
Posted on Apr 03, 2014
How do you replace windshield wiper motor on a 1997 ford e250 van
REMOVAL
  1. Raise and support the hood.
  2. Remove the windshield wiper pivot arms.
  3. Remove the cowl top vent panels.
  1. Disconnect the windshield wiper mounting arm and pivot shaft.
  1. Remove the access cover from the dash panel.
  2. Remove the mounting arm and pivot shaft retaining clip.
  3. Disconnect the windshield wiper mounting arm and pivot shaft from the windshield wiper motor.
  1. Remove the windshield wiper motor.
  1. Disconnect the electrical connector.
  2. Remove the three bolts.
  3. Remove the windshield wiper motor.
INSTALLATION
  1. Install the mounting arm and pivot shaft retaining clip on the windshield wiper mounting arm and pivot shaft.
  1. Install the windshield wiper motor.
  1. Place the windshield wiper motor in the dash panel.
  2. Install the three retaining bolts.
  3. Reconnect the electrical connector.
  1. Reconnect the windshield wiper mounting arm and pivot shaft.
  1. Press on the windshield wiper mounting arm and pivot shaft after it is aligned with the windshield wiper motor.
  2. Install the access cover in the dash panel.
  1. Install the cowl top vent panels.
  2. Install the windshield wiper pivot arms.
  3. Adjust the windshield wiper pivot arms.
This is technically for the V6 4.2L but I'm sure those Ford E250's have the same setup for windshield wiper motor. Let me know how it goes.
Nov 17, 2014 | Cars & Trucks
Windsheild washer motor will not work.
Windshield Washer Pump
1990 Ford Truck F150 1/2 ton P/U 2WD 5.0L FI 8cyl
The Windshield Washer Pump is located: Under hood, driver side front side of wheelwell, mounted inside washer bottle.here's the part. TAAP Windshield Washer Pump 7 664 1990 Ford F150 1 2 ton 2WD 8...
Jan 14, 2014 | 1990 Ford F150
Windshield washer doesn't work, is there a relay for it or do i replace the pump?
Check to see if you can hear the washer motor run when you push the button, if so check the rubber lines to see if they are cracked/broke. If not the motor is located on the washer reservoir.
Jan 18, 2011 | Ford Taurus Cars & Trucks
94 Mercedes-Benz e320 how and where is blower for ac
the blower motor for the a/c is located under the windshield wiper motor. you access it from the engine compartment by removing all the trim covers under the windshield, also have to remove the wiper motor and assembly but be careful not to crack the windshield. once you pull all the covers out of the way you will see the blower motor housing. remove clips and voltage regulator in order to remove top cover of blower motor housing.
Sep 27, 2010 | 1994 Mercedes-Benz E-Class
How to replace a windshield wiper motor
the wiper motor is located under the cowl. (the black plastic piece at the bottom of the windshield, under the wiper arms) remove the wiper arms, remove the cowl, it is held on with aprrox 8 phillips screws. Two of these screws are hidden, Open the door on either side and in the crack between the door and the front fender at the top you will see a screw. HTH
Jun 16, 2010 | 1992 Ford Taurus
The wiper motor on my 1983 Ford Ranger still works but the wipers no longer move. I think there is a failure of the mechanical linkage. Where do I go to find repair parts?
why do you think the motor still works if the wipers don't move? Can you hear the motor run or can you see a little movement when you turn the switch on?
What happens when you activate the washers?
go to a salvage yard that allows you to remove the parts yourself. Then you can see how the motor and linkage assembly comes out.
don't have 1983 info, but here is 1994:
Section 01-16A: Wiper and Washer System, Ranger/Explorer 1994 Ranger and Explorer Vehicles Workshop Manual
DESCRIPTION AND OPERATION Windshield Wiper System, Ranger/Explorer The windshield wipers are actuated by a permanent magnet, rotary-type electric windshield wiper motor (17504) . The two windshield wiper pivot arms (17526) and windshield wiper blades (17528) are mounted on a pivot shaft, one at each side of the windshield. The windshield wiper mounting arm and pivot shaft (17566) are connected to the motor by windshield wiper adapter and connecting arm clip (17531) . Ranger and Explorer vehicles are equipped with an interval wiper and washer (IWW) system featuring a lever-type turn signal and windshield wiper switch (13K359) mounted on the steering column. The IWW windshield wiper governor (17C476) uses a relay contact to control current to the windshield wiper motor . The governor electronic circuitry controls the contact to supply current to windshield wiper motor . A rear wiper/washer system is available on Explorer vehicles. The rear window wiper system consists of a windshield wiper motor mounted inside the liftgate (40010) , an articulating windshield wiper pivot arm and windshield wiper blade , a windshield wiper/washer switch (17A553) and an inline circuit breaker. The front electric windshield washer system consists of a control switch, integral with the turn signal, a windshield washer reservoir (17618) and windshield wiper motor and the necessary windshield washer hoses (17A605) , windshield washer nozzle jet and brackets (17603) and attaching parts.
Pivot Shafts and Linkage Removal and Installation
NOTE: The left and right pivot and windshield wiper adapter and connecting arm clip assemblies are serviced separately.
  1. Perform Steps 1 through 9 of Windshield Wiper Motor Removal as described in this section.
  1. If servicing left windshield wiper adapter and connecting arm clip , remove left windshield wiper mounting arm and pivot shaft and windshield wiper blade assembly.
  1. Remove left windshield wiper adapter and connecting arm clip access cover.
  1. Remove left pivot nut, lower windshield wiper adapter and connecting arm clip and slide it out through left access opening. For installation, follow removal procedures in reverse order. Tighten nut to 10-13 Nm (7-10 ft-lb). Make sure the clip is fully seated in the windshield wiper adapter and connecting arm clip . Do not try to install clip with windshield wiper adapter and connecting arm clip on motor crank pin.
Windshield Wiper Motor Windshield wiper motor are not serviceable. If worn or damaged, the windshield wiper motor must be replaced as an assembly. Removal
  1. Cycle windshield wiper blades until in straight-up position and turn ignition switch OFF.
  1. Disconnect battery and wiper motor electrical connector.
  1. Remove the right windshield wiper mounting arm and pivot shaft and windshield wiper blade .
  1. Disconnect the battery ground cable (14301).
  1. Remove the right pivot nut and allow the windshield wiper adapter and connecting arm clip to drop into the cowl top outer panel .
  1. Remove the linkage access cover, located on the right side of the dash panel near the windshield wiper motor.
  1. Reach through the access cover opening and unsnap the wiper motor clip.
  1. Push the clip away from the windshield wiper adapter and connecting arm clip until it clears the nib on the crack pin. Then, push the clip off the windshield wiper adapter and connecting arm clip.
  1. Remove the windshield wiper adapter and connecting arm clip from windshield wiper motor crank pin.
  1. Remove nut and ground strap.
  1. Remove three attaching nuts from windshield wiper motor. Remove the windshield wiper motor .
Installation
  1. Position the windshield wiper motor and install the three attaching screws. Tighten to 13.6-19.0 Nm (10-14 ft-lb).
  1. Install nut and ground strap.
  1. Connect wiper motor electrical connector.
  1. Install clip completely onto right windshield wiper adapter and connecting arm clip. Make sure the clip is fully seated. Do not put the windshield wiper adapter and connecting arm clip on the motor crank pin and then try to install the clip.
  1. Install the left windshield wiper adapter and connecting arm clip onto the wiper motor crank pin.
  1. Install the right windshield wiper adapter and connecting arm clip onto the wiper motor crank pin. Pull the windshield wiper adapter and connecting arm clip onto the crank pin until it snaps into place. The clip is properly installed if the nib is protruding through the center of the clip.
  1. Install the right windshield wiper mounting arm and pivot shaft and nut. Tighten the nut to 9.5-12.5 Nm (84-110 in-lb). NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 10 miles or more to relearn the strategy.
  1. Connect the battery ground cable and turn the ignition switch on. Turn turn signal and windshield wiper switch off so windshield wiper motor will park, then turn ignition switch off. Replace right windshield wiper adapter and connecting arm clip access cover.
  1. Install the windshield wiper mounting arm and pivot shaft and windshield wiper blade assemblies on the pivot shafts to dimension X. Dimension X is the distance between the centerline of the blade saddle and the top edge of the cowl top outer panel grille. The value of Dimension X for each vehicle is given in the Dimension X chart in the Specifications portion of this section.
  1. Test the system.
Jan 04, 2010 | 1983 Ford Ranger
How do I remove the windshield wiper motor from a Ford F-250?
2002 Ford F-250 Windshield Wiper Motor Removal & Installation 1. Turn the ignition switch to the ON position. Turn the ignition switch ON until the wiper blades are straight up, then turn the ignition switch OFF. 2. Disconnect the negative battery cable. 3. Remove the right-hand and left-hand windshield wiper arm and blade assemblies. 4. Remove the cowl top vent panels. 5. Detach the electrical hardness connector at the windshield wiper motor assembly. 6. Remove 3 wiper motor (module assembly) retaining bolts and remove the module assembly from the vehicle. 7. Remove the wiper linkage retaining bolt and remove the linkage from the wiper motor. 8. Remove 3 retaining nuts and remove the windshield wiper motor To install; 9. Place the windshield wiper motor in position and install 3 retaining nuts. Tighten to 10-12 ft. lbs. (12-17 Nm). 10. Connect the wiper linkage to the windshield wiper motor and install the retaining bolt. Tighten the bolts to 14 ft. lbs. (20 Nm). 11. Place the wiper motor (module assembly) in position and install 3 retaining bolts. Tighten the bolts to 6 ft. lbs. (9Nm). 12. Install the electrical hardness connector to the windshield wiper motor. 13. Connect the negative battery cable. 14. Allow the windshield wiper motor to cycle several times while checking for proper wiper motor operation. 15. Turn the windshield wiper motor to the OFF position to park the wiper motor in the park position. 16. Install the cowl top vent panels. 17. Install the wiper arm and blade assemblies. Install the retaining nuts and tighten to 22-29 ft. lbs. (30-40 Nm). 18. Connect the negative battery cable. 19. Check the windshield wiper motor for proper operation and the wiper arms for adjustment.
Nov 09, 2009 | 2002 Ford E250
Need to remove the broken bumper on the back of a 1994 Ford Taurus, buy a new one, and put it on. help.... also need to fix a crack in the front windshield.
check out the junk yard for the bumper it will be a lot cheaper and only 4 bolts on each side of bumper. sometime if the crack isnt big you can put a dab of crazy glue on the crack to keep it from spreading but it s smarter to replace the windshield
Aug 16, 2009 | 1994 Ford Taurus
Windshield wipers stuck upright when off
It is the fuse or the pulse board. Most likly the pulse board though
Jan 30, 2009 | 2002 Chevrolet Monte Carlo
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
