Question about Mach Speed Trio 4GB 7" Trio Stealth Pro
My power adapter is'nt working
My Power Adapter won't work right for me
Does the Adapter Work? Is it Powering the Tablet? If not, it's Probably Bad, Test it. Try the same Type of Adapter, Process of Elimination. Reset Tablet? If it is Defective, Contact the Company and have them Replace it. If the Adapter is Working, could be the Tablet.
Posted on Mar 29, 2014
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
My Sony pcg-9c1l won't turn on!! When I press the
Could be your adapter, adapter socket - most common issues.
AC ADAPTER CHARGER POWER FOR SONY VAIO PCG 9C1L PCG 9D1L VPCCW14FX... Test your power adapter with a multi-meter. Example below
Hope this works to help you and your situation.
Mar 11, 2012 | Sony Computers & Internet
I bought a power adapter for the camera, but it doesn't seem to work without batteries in the unit. If I use the batteries alone, I will eventually get a red blinking light at the back of the camera,...
Because the camera is what is technically known as 'Portable'and is designed to work purely from the internal battery. the Power Adapter merely charges the internal battery
May 08, 2017 | Kodak EasyShare C330 Digital Camera
When starting my netbook(turning it on) it goes to right after the 3 light down at the bottom right an application error occurs that claims that the system must shut down, of course it does not....
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Aug 24, 2011 | Sylvania G-Netbook
Will not power up
http://www.hitachigst.com/support/index-files/simpledrive-pininfarina-faqs The SimpleDrive and (re)Drive lines require a 12Volts, 1.5Amp or greater, and Center Positive power adapter. So if it's not on warrenty still I would go to radio shack, or somewhere that sells a/c adapters, Take your old one or the drive to match the right size plug. It should work, you maybe able to have them test your adapter to see if its' some other problem, but I've had a/c adapters that show they are making power that won't work the device. Inspect your a/c adapter make sure it's not something simple, like being unplugged, or a cut wire. Hope this helps.
Jun 12, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
My printer won't turn on. I have tried turning everything off and back on but it still won't turn on.
There is only one way to find out if it is an issue with the printer or the Power cord or Power Adapter.
Normally every HP printer has 2 parts. One cord connects the Printer to an Adapter. the Adapter cord then connects to the Wall outlet.
Now that you have connected the printer to working outlet, Check after 10-15 mins if the Adapter ( black box ) is warm or cold. If the Adapter is warm and the green LED light on adapter is glowing, then it could an issue with the Cord or the Printer.
Try with another Adapter or power cord to diagnose.
For Other brand printers, there should be a power adapter ( black box ) and it should be warm when connected to wall outlet, if it is not warm then it is defective power adapter that you need to replaced. Else it is a problem with printer mechanism.
Regards,
Shawn
May 07, 2011 | Office Equipment & Supplies
Hp nc4200 won`t start
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 28, 2009 | HP Compaq nc4200 Notebook
No power
There is a possibility that the receptacle for the adapter plug has one or more broken solder joints on the circuit board.
Mar 22, 2009 | Music
USB 2.0 cardbus pc card adapter N2PUCB
Straight from NexxTech's website:
http://download.nexxtech.com/nexxtech/N2PUCB_pcmcia_USB2.0.zip
Jan 05, 2008 | NexxTech NCARDBUS Network Adapter
Mach Speed Trio 4GB 7" Trio Stealth Pro Logo
42 people viewed this question
Top Mach Speed Trio Video Cameras Experts
Francis L Barresi
Francis L Barresi
Level 1 Expert
Tom Chichester
 Mikey
Mikey
Are you a Mach Speed Trio Video Camera Expert? Answer questions, earn points and help others
