Samsung hd103si/y do you know where I can find board AE0906057-1 USB plug is broken.
You know, on this board you have switch, DC plug, and USB plug. Thanks
  • 3,320 Answers
Replace the usb connector.
Posted on Mar 28, 2014
Can my hdd samsung 1tb model hd103SI work with 775dual-880Pro motherboard? I conect but Its not deteted!
That is an Asrock board and Yes, any standard hard drive will work with it. The reasons for your problem in descending liklihood:
>Your connection is incorrect or a bad cable.
>If you have an operating system, there is a corruption/problem with it.
>The hard drive has failed
>Drive is not activated; enter Disk Manager and activate it.
May 18, 2014 | Asrock Computers & Internet
Wrong adaptor plugged into hard drive
you can use a external hard disc connector ,,, but still you must open the box ,, i think the guarantee is already void ,,, cause misuse is not guaranteed any way you must ask about the guarantee thing ,,,
Mar 06, 2012 | Computers & Internet
About 2 months ago I bought a samsung s2 portable 1Tb. It has worked fine until yesterday. It slipped down from where it was laying (while plugged in and running) and was hanging the 20 cm usb-cabel. Now I...
Hanging by the 20cm USB cable?
The cable could be stretched, and wires broken inside.
The cable to small circuit board, inside the case, could have broken solder joints.
The circuit board inside the Samsung's case could be broken.
Inside that small outer case of the Samsung portable is a laptop size Harddrive.
The harddrive measures 2.5 inches across in width.
(6.4cm. In comparison a desktop size harddrive is 3.5 inches across in width, or 8.9cm)
The harddrive is a SATA unit also.
This is a general example of a 2.5 SATA harddrive,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148591
Inside the outer case (External Enclosure) is also a small circuit board (PCB)
The harddrive plugs into the small circuit board, and the circuit board has a USB cable attached to it.
(Or there is a small cable from circuit board to harddrive. Then a USB cable to the circuit board)
I would suggest removing the 2.5 SATA harddrive, and install it into an economical external enclosure.
Example of a 2.5 SATA External Enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
Basic guidance in removing the Harddrive from a Samsung S2 Portable,
1) It looks as though the outside front is a thick cover like a label. It may be that you peel back the corners, and there will be a screw in each corner.
(For example; Where it states Samsung. Go to the right corner. Does this cover-like material peel back? Is there a screw underneath? Remove it.
Go to the opposite corner. Now above to the left and right corners)
The unit looks to come apart in two halves.
Might just be held together by sticky tape.
Here are some videos performing opening the external enclosure, (Case) of other external portable harddrives,
1) http://www.youtube.com/watch?v=dMzRYCZXVEs&feature=results_video&playnext=1&list=PLC129A4F797CCC09E
2) http://www.youtube.com/watch?v=Y2vUMO2mGLE&feature=related
There are other related videos. In general most are not very professional, but get the job done.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 18, 2011 | Samsung S2 Portable HX MU010EA 1 TB...
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
On start up the lap top starts to come on and within 6 seconds it switches off and not even the screen comes on?
Do you have it plugged in? Also, do you know if the battery is charging? You may have a bad DC connection.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
The DC connector needs to be resoldered on the system board.
Dec 08, 2010 | HP Compaq nc6000 Notebook
Dell 1525 not charging. dc usb board replacement
rubberman
Sorry to hear that you are still having trouble. The only other thing to try is your battery on your buddies notebook. If it works there then it is the charging mechanism on your notebook and this would mean replacing the motherboard.
Issken
Jan 11, 2010 | Dell Inspiron 1525 Notebook
Asrock K7VT4A will not recognise Samsung HD103SI 1gb sata drive, any advice would be appreciated.
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Hope this helps you out.
Nov 21, 2009 | Computers & Internet
I have the same problem
http://www.seagate.com/staticfiles/support/downloads/firmware http://atulchitnis.net/files/seagate.pdf red carefully and follow instruction
Aug 26, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
DC input jack broken
you need to buy a new jack for replacement. then solder the broken one out of the mainboard and clean the place and solder the new one. or some acer have a separet jack then that one is easy only to change.
Dec 25, 2008 | Acer Aspire 5500 5570-2609 Laptop
Dell latitude c610
sounds like a mother board replacement,if theres a repair shop in your place,you can ask them if they can replace your DC jack..its hard to replace it since its soldered onto the board..mobo replacement is the fastest way..
Oct 20, 2008 | Dell Latitude C610 Notebook
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
