Question about Car Audio & Video
Goodmans model gspk28wip manual
Hi one speaker has stopped working, the blue light on the power button does not illuminate, how do I open the speaker?
  • 101 Answers
SOURCE: TV stopped working. Power light is blue, temp and
How long has it been sense you changed the lamp? This type of symptom seem as if it could be the lamp needs replaced. Check the manual for the lamp number. Make sure you buy an original hitachi lamp. I assume this is the brand. Hope this is helpful.
Posted on Nov 08, 2009
fingaz22
  • 1068 Answers
SOURCE: amp shut off and wont power mtx 12's blue power
the transistor that mount to the amps body (heat sink) inside. most common issue with these.
Posted on Feb 04, 2010
SOURCE: Hi my tail lights will not come on when my front
Hi,You have a tail light/insterment panel light fuse.the fuse is blown.hope this helps.Thank You for using fixya.... iluv2fish.....Ray......
Posted on Jul 07, 2010
  • 1779 Answers
SOURCE: Hi, Same Model Samsung
I hope you looked for any bulged capacitors on the power supply? If so then you must now check with the set plugged in find the 5V standby which will be labeled by the appropriate plug. If that is present then you have to look for the PO. when you've located that, with your probe on that pin, press the power button and see if it goes HIGH , usually between 3.8 and 5v. If that does not come up then appears you have a bad main board. You can also disconnect the plug going to the inverter board an see if the PO stays up, if it does you have a bad inverter. The only thing that is puzzling is that you had back light before. If you do all these things the last resort is your lcd display panel is bad the set is ready for the rectangular file.
Posted on Dec 08, 2010
  • 11800 Answers
SOURCE: My centrios wireless speaker (L)
I'm assuming that the speaker has been properly charged and the battery is in working order - slow blinking indicates a low voltage situation, either because the battery needs to be charged or it has aged and no longed gives the necessary voltage - and the speaker is set to the correct channel with the switch at the rear..
The fast blinking signals that the wireless connection isn't made - you will need to reset the connection as explained in the user manual. If it fails even after that then the wireless receiver is faulty - the system is unrepairable, because it's a sealed unit. Time for a new one.
Posted on Jul 03, 2011
Why won't my 32" Goodmans TV power up?
There could be an open fuse internally or the power supply may have failed.
Apr 25, 2015 | Goodmans Televison & Video
Hi i have a 95 buick lesabre i bought from a friend everything works great sides the radio i have an after market stereo jvc model no kd-g320 not sure witch color the antenna wire would be car has a power...
Antennae wire and other wires for the stock stereo are listed below:
1995 Buick LeSabre Stock Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black/White
Stereo Radio Illumination Wire: Gray/Black
Stereo Radio Dimmer Wire: Brown/White
Stereo Radio Antenna Trigger Wire: Dark Green
Stereo Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6? x 9? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Feb 19, 2015 | 1995 Buick LeSabre
How do i correctly install the radio in a 2000 kia sephia
Here are the radio connector wiring colors and what they do.
2000 Kia Sephia Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/Red
Car Radio Ignition Switched 12V+ Wire: Blue/Black
Car Stereo Illumination Wire: Red/Black
Left Front Speaker Wire (+): Black/Yellow
Left Front Speaker Wire (-): Blue/Orange
Right Front Speaker Wire (+): Blue/Green
Right Front Speaker Wire (-): Light Green
Left Rear Speaker Wire (+): Green/Red
Left Rear Speaker Wire (-): Green/Black
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Red/Blue
Jun 28, 2012 | 2000 Kia Sephia
I have a 1991 ford festiva i changed my radio and now my shifter and my dash lits dont work are they wired in with the factery radio
Hi, the factory radio uses the illumination wire, but the aftermarket radio does not. You have to make sure that wire is taped off so it doesn't short the illumination circuit. Check your tail lights fuse. If it's blown, pull the head unit and disconnect/tape off the illumination wire (blue with a white stripe) from the factory harness. Then put in a fresh fuse. If you have more questions, please specify the model of the head unit.
1991 Ford Festiva Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Red/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/White
Left Front Speaker Positive Wire (+): Blue/Red
Left Front Speaker Negative Wire (-): Blue/Yellow
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): Blue/White
Left Rear Speaker Positive Wire (+): Blue/Red
Left Rear Speaker Negative Wire (-): Blue/Green
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Green
Nov 21, 2011 | Car Audio & Video
Stereo stopped playing after installing after market rear speakers in my 1990 buick skylark.radio has power but no sound
Check the wiring?
Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Rear
Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green
Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Jan 04, 2010 | Car Audio & Video
Trying to install factory cd-cassette combo from a 1999 ford explorer into a 1996 ford crown victoria with only a cassette radio player. need to know wiring data on both vehicles.
Hi and welcome to FixYa,
On your need for the radio wiring of 99 Ford Explorer and a 96 Ford Crown Victoria, see below wiring scheme:
Confirm with a voltmeter on the +12 and an ohmmeter for speaker continuity.
Good luck and thank you for asking FixYa.
Oct 30, 2009 | Car Audio & Video
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
