Question about HDMX Audio HMDX Jam Plus blue
Pairing bluetooth w ipod
How do I pair my bluetooth headset with my ipod nano 7th generation?
Can I pair my Bluetooth earphones to my iPad?
How to pair Bluetooth headphones to IPAD?
Most headsets have a power button or a switch to turn the device on. Press the "Pairing" button on your Bluetooth headset, if necessary. Select your headset from the Devices list on the iPad's Bluetooth window. Enter the passkey or PIN for your headset, if prompted.
Does the iPad Pair With Bluetooth Headphones? ' Chron.com
smallbusiness.chron.com/ipad-pair-bluetooth-headphones-62883.html Search for: How to pair Bluetooth headphones to IPAD?
Dec 05, 2016 | Radio Communications
Can I pair my jam wireless speaker with my IPod Nano 7th generation?
no because the speaker wont connect or show on any ipods except forr the ipod touch
Feb 17, 2015 | Hmdx Jam Plus Wireless Speaker for Most...
How do I pair ipod with bluetooth headset
1. go into your settings on your ipod and click on the bluetooth section so that it is open.
2. on your HEADPHONES press whatever button to start syncing the bluetooth(it will most likely start flashing blue or w.e color)
3. go back to your ipod, the device will show up in the list of avaliable devices, press it, connect it, there you go!
Mar 28, 2014 | Apple iPod nano 7th Generation
Pairing ipod nano 7th generation with plantronics bluetooth headset
Please check the video link provided below for your reference. The device used there is a iphone but the instructions on how to connect a bluetooth headset are the same.
How do you pair the 903 headset with my ipod touch?
To pair the Plantronics BackBeat 903 with an iPod Touch:
On the 903 headset:
With the headset powered off, press and hold the "Power/Pairing" button until the LED indicator flashes blue and red. This will put the 903 headset into pairing mode.
Use the iPod Touch menu to search for the headset and select 9xxBackBeat.
(If prompted, enter 0000 for the PIN code/passkey. Some devices also require you to accept the connection. Headset is paired when LED flashes blue.)
On the iPod Touch:
In Settings, choose General, Bluetooth, and turn Bluetooth on.
Choose the device on iPod Touch, then enter the PIN/Passkey 0000 (4 zeros).
After pairing the 903 and iPod Touch, the headset model may appear on the screen when you are viewing the audio or video playback controls. (You can "tap" to switch to a different audio output, such as the internal speaker)
Aug 17, 2011 | Plantronics BackBeat 903 Bluetooth Headset
How do i get it to connect to my ipod
ok, this is a bit complicated of a matter so ill make it as simple as possible. First of all, the first generation iPod Touches DO NOT have bluetooth capability, so if your ipod is a first generation you cant use bluetooth. Second, the iPod must be running on the latest firmware, which can be updated through iTunes. Third, iPod Touches CANNOT pair with bluetooth headsets (such as the ones you use with a cell phone the go over one ear) however they CAN be paired with bluetooth HEADPHONES (go over your entire head to cover both ears) now assuming you meet the above criteria, the option for bluetooth is in Settings>General>Bluetooth On. place the device in pairing mode and it should be discovered. if it is not, you are using an incompatible Bluetooth Device. Hope This Helped! Remember to Rate
Aug 25, 2010 | Motorola Mobility Bluetooth...
I am trying to pair a Discovery 925 to an ipod touch (2nd generation). It recognizes "9xxPlantronics Not Connected" I click on that bar (or line) and get the keyboard screen with the request to enter...
I might be wrong, but I think the iPod Touch, not being a phone, doesn't have either HSP (HeadSet Profile) or HFP (Hands Free Profile) bluetooth profiles, solely used for phone calls. Nevertheless, being an audio/video reproduction device, it must have A2DP (Advanced Audio Distribution Profile) and AVRCP (Audio/Video Remote Control Profile), from its 2nd-gen onwards. Your problem is that the Plantronics 925, being a monoaural bluetooth headset, bears HSP and HFP only. You were able to successfully pair it with your TP2 because it is a phone. You must purchase stereo bluetooth headsets, in order to pair them with your iPod Touch.
Just my 2 cents... Carlos
May 23, 2010 | Plantronics Discovery 925 Bluetooth...
How do I pair my s9 bluetooth headset with my
do you have the adapter that makes your ipod nano have bluetooth?
im guessing you do so
turn on the bluetooth adapter on the ipod
mod the power button on the motorolla s9 untill blue light is constantly on
from the ipod select the bluethooth options and select the headset
use the password 0000
Apr 29, 2010 | Motorola Mobility MOTOROKR S9 + Bluetooth...
Pairing Motorola D650 to Motorola S9 with ipod nano or touch
It does work with the itouch. Try turning off the ipod completely. Turn it on again, then plug in the D650 and then your S9. Enjoy!
Mar 18, 2009 | Motorola Mobility MOTOROKR S9 + Bluetooth...
HDMX Audio HMDX Jam Plus blue Logo
95 people viewed this question
Top HDMX Audio Medical Experts
Electro Med Services...
Are you a HDMX Audio Medical Expert? Answer questions, earn points and help others
