Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Starter problems with 98 flstc
Bike starts,every once in awhile i can hear bendix turn but not kicking in.
  • 379 Answers
2 possibilities here. First, the solenoid and bendix are working correctly and the starter is kicking in. You will hear and be able to feel a "clunk" on the primary cover if you touch it. This means the overrunning clutch is going bad. (Can be called starter clutch, sprag clutch, etc. depending on the shop). About $40, but hard to install if you aren't at least a semi-experineced mechanic. Second, you have a failing solenoid (the pull-in coil) or the actual starter bendix is hanging up. Replace the solenoid and clean the starter. (DON'T use gasoline! Get some quick evaporating spray cleaner from the autp parts store.) If that fails, it looks like it's new starter time. Check all your wires and conncetions. Ya don't want to waste money on parts when a good cleaning with a wire brush could fix it.
Posted on Jun 30, 2009
2009 HERITAGE SOFTAIL STARTER HOT GRIND
That does not sound good. I suggest you get it to a dealer before you do any additional damage.
Apr 02, 2014 | 2009 Harley Davidson FLSTC Heritage...
I have a 98 Jimmy that when I try to start it the starter does not engage, I put a new battery in and it seemed to work for a couple of days and now it's back to the same problem. Any suggestions?
sounds like the starter is going, what happens is the battery had more power to help get the starter to operate a few more times but it is already shot. The part that will go on starters is the Bendix. It's the part that pushes the drive gear out to the front of the shaft to engage it with the flywheel. It's like a spring and plunger assembly with a magnetic part that pushes a fork on the gear while the key is turned and then springs back away from the flywheel once you let up on the key. You extra power from your new battery got it to push the gear out but was bound to fail since those parts were worn out. That's why you will hear the starter wizzing up but not engaging on the flywheel or you'll hear that grinding sound. that is due to the starter already turning the drive gear before the bendix has moved the gear forward. The gear is spinning and the bendix is stuck but then comes loose and tries to kick the spinning gear out and just grinds the flywheel without ever having the chance for the teeth to align first.
bottom line is you will need a new starter.
Jan 02, 2014 | 1998 GMC Jimmy
I have a 2004 Dyna Low Rider. I just replaced the battery, and after a short ride, I was opening garage door, left it running and propped it on kickstand. Heard a small rattle as I walked away. Returned...
Sounds like the solenoid relay is stuck up and shorted your starter! Better check the starter, pull it down and look if the bendix drive is still intact, upon driving and engine is running the bendix drive is still engage, thus it might have broken and loosen up.
If you can't repair it, a mechanic can certainly repair it, hope that bendix drive is still okay, if damage is already done, just replace that part. The solenoid that gives power and pushes the bendix drive is at fault, better check that too, it is the first one that malfunctioned and damages the bendix.
Hope that helps you out!
thanks for using FixYa!
Jul 03, 2011 | 2004 Harley Davidson FXDL - FXDLI Dyna Low...
I changed my starter and solenoid and my bike still wont start. I can hear the solenoid engage and the starter run. When i push the start it almost starts but then kicks out and the starter motor keeps...
Replace the "Bendix" unit on the starter shaft in the primary. It's basically a one-way bearing designed to lock up when turned one way and to freewheel when turned the other. When the starter turns the "Bendix" it locks up but when the engine starts, the Bendix turns the same way but faster. This make it reverse directions in relationship to the starter shaft. When they go bad, they either don't lock up at all or the "jump out" once started turning the engine over.
Do not use a cheap Bendix replacement (made in China). You'll be back in there again in six months if it lasts that long. I like the Accel units made in the U.S.A. Clamp the shaft in a vise with "soft jaws" on it and take the nut off the end of the shaft. It has left handed threads.
Good Luck
Steve
Sep 12, 2010 | 1979 Harley Davidson XLH 1000 Sportster
Yamaha virago 535 turn ignition on neutral light is flashing and there is a clicking noise coming from the electrical system bike wont start
These are known for starter problems... The clicking you hear is the relay but the bendix is locked up put it in about 3rd gear and rock it hard forward and back. Bendix may release. Make sure battery is good. As I said before these bike are well known for their starter problem and even after having it fixed by a dealer problem seems to show back up after a very short time. Good Luck!
Sep 23, 2009 | 1997 Yamaha XV 535 Virago DX
Gilera dna 50cc electrical starting problems. It was ok now it spins but wont turn over only had it a day!! could it be petrol or lack of it. the kick start works
it sounds like the bendix on the starter is bad you can try to remove the starter and spin it off of the bike to make sure
Apr 11, 2009 | 1992 Gilera Saturno Bialbero
2003 Heritage Starter Problems
High compression engine needs compresssion release plugs. Thats why it turns over easy with plugs out. Have compression release put in your heads
Apr 04, 2009 | 2003 Harley Davidson FLSTC Heritage...
Starter just spining
I would try to start it again and all I get is a spinning and whining sound from the starter. It is as if the starter is not engaging somehow. A while after it cools down the bike will start agian. Does anyone have any possible answers. Thanks in advance!A lot of the starters are designed so the bendix shaft shears if it sticks to the fly wheel or over torques. If you remove the starter, connect a pair of vice-grips to the bendix gear. Jump the starter with a pair of cables, to get it to activate. The bendix will probably kick out, but not rotate. You should hear the armeture spin. Otherwise, the bendix will kick out, and you'll hear the armeture hum. If that's the case, check to make sure the fly wheel has been ground down, on the side facing the starter. However, you would probably hear grinding not spinning, if that were the problem.,,,
Nov 10, 2008 | 2008 HM CRE F450XI
Starter spining
Nov 10, 2008 | 2007 ATK 450 Enduro
Lands Phones Logo
371 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
