Question about Vapor WhiteWing Steamer Canister Vacuum
Doesn't produce steam, but canister is hot. - Vapor WhiteWing Steamer Canister Vacuum
No steam 2400
Water level low or clogged steam jet
Jul 07, 2014 | Polti Vaporetto 2400 Canister Steam Vacuum
Steamer
Try running a phial of Kalstop through the boiler to descale the boiler unit. Calicification in the boiler and on the controlling solenoid can cause the unit not to produce steam. My boiler unit was so corroded that I had to get the boiler container completly replaced.
Feb 02, 2014 | Polti AS700 Canister Steam Vacuum
Handle is to hot to hold and steam is comming out of the top of the handle
i believe your hot water/steam hose/tube runs through the middle of
the handle down to the floor(where it sprays hot water/steam. it ether came apart on the inside or you have a hole in it.
Sep 02, 2013 | Polti Vaporetto 2400 Canister Steam Vacuum
Iron will not heat up
See the causes and proceed according, fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord. Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Sep 23, 2012 | Unknown LAURASTAR PREMIUM S3 Ironing...
Shark S3101 Steam Mop won't produce steam
You have to use distilled water in the steam mop. regular water clogs it up and causes it not to work.
Nov 27, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
It is getting up to tempeture but it will not produce any steam
Your machine need to reach boiling point to produce stem? Then check if all the sustem is sealed other than the pip outlet gun and it should now operate with the gun trigger ( pull to operate, but only when the water within the vessel is boiling, producing steam)Hope this helps Regards Mike
Jul 08, 2011 | Polti Vaporetto 2400 Canister Steam Vacuum
My mop would produce steam. It gets hot but when
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
xxxx
Jan 24, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop. I feel that the canister gets
heatman101
ad
Oct 02, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Unit gets hot but doesn't produce steam!
heatman101
l
Aug 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vapor WhiteWing Steamer Canister Vacuum Logo
27 people viewed this question
Top Vapor Vacuums Experts
richie46
ray gallant
Tom Chichester
Are you a Vapor Vacuum Expert? Answer questions, earn points and help others
