Question about Emerson Televison & Video
Emerson TV not turning on
Hello I have a Emerson LC401EM2F 40" TV that is currently not turning on. The TV wouldn't turn on a couple of days ago. I would press the power button, and it would act like it was going to turn on, but the screen would stay pitch black. I was told that it was the digital main board that went out. I bought a used digital main board on ebay, switched it out with the old one and it still didn't work. When I ran a flashlight through the screen while "on" and I saw a dark grayish rectangular frame towards the middle and in the center its a dark rectangle. When I turn the Tv off the dark grayish rectangle disappears. Any ideas what it could be ?
Emerson model number LC 401EM2F Bluetooth built in
What is the problem you faces with this TV? If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Dec 04, 2016 | Emerson LC401EM2F 40" Inch LCD Full HD TV
I can't change the screen resolution on my Emmerson 40 inch tv, the format button does nothing. Please help!
get the on screen menu up and scroll around for aspect ratio or pixel screen if you have it
adjust to what you want , ok- then exit
Aug 02, 2016 | Emerson LC401EM2F 40" Inch LCD Full HD TV
What's wrong with my lcd tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 06, 2015 | Emerson Televison & Video
My emerson lc401em2f is flickering with different colors almost like arolling-flickering? how can i fix it?
Flickering can be adjusted. Type in the keyword "Flickering"; in the search box, at the top of the display window, to get gathered related posts.
Mar 07, 2015 | Emerson LC401EM2F 40" Inch LCD Full HD TV
My Emerson TV Wont turn on... No sensor lights working either.
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Apr 28, 2014 | Emerson LC401EM2F 40" Inch LCD Full HD TV
Emerison lc401em2f
More than likely its the tcon board.
Mar 29, 2014 | Emerson LC401EM2F 40" Inch LCD Full HD TV
Vertical lines hdtv
Check the LVDS cable. {LVDS (Low Voltage Differential Signaling)that involves transferring a signal on a wire and its opposite over a second wire to allow the receiver to reconstruct the signal by difference.} The cable that connects to display panel to its T'Con board. Replace it if necessary. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 25, 2014 | Emerson LC401EM2F 40" Inch LCD Full HD TV
Trying to replace power supply board to tv and need help
What type of help do you need. If you wish to know something, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 25, 2013 | Emerson LC401EM2F 40" Inch LCD Full HD TV
Enerson lc401em2f
Buy a replacement and pay for the extended warranty.
Dec 18, 2012 | Emerson Lc320em1 TV
Televison & Video Logo
130 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
