Ln46a550 picture freezes when turned on
When turning set on after it has been off for awhile the pic freezes for a few seconds, then the screen goes blank for a few more seconds, then the pic comes on normal.
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
Firmware corrupted. Update the firmware. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 29, 2014
mrlobsterbob
  • 22 Answers
SOURCE: TV goes on and off every few seconds
sounds like a bad backlight
Posted on Oct 20, 2008
  • 51 Answers
SOURCE: sharp aquos display comes on for a few seconds then blank screen
I have the same problem with my 37" HP which is the same as Sharp Aquos, it's bad backlight inverter boards, the screen comes on for a second then nothing, no menu, no channel change indicator then turn it off and you hear the clicking of the power supply about 10 seconds after.
Posted on Jan 16, 2009
SOURCE: samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Posted on Feb 08, 2009
SOURCE: frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Posted on Feb 28, 2009
SOURCE: Magnavox 42MF130A/37, no picture
IF your not getting sound and its shutting down it could be a the main board, or the power supply (huge board in there.) I just got done parting one of these tvs that was in a vacation rental. the tv met with an unfortunate accident so the screen was cracked and so on. Anyhow if your intrested i have the main board and the power supply board for that exact model. I was listing them on ebay and saw this post. Listing here. I am going to probaly get about 25 buck a board (very cheap) plus shipping. IF your intrested let me know and I list that power supply board as well. I can't guarentee it will fix it but its worth the shot for 50 plus shipping. form my experience with mostly LCD tvs if your not getting sound odds are its the main board. I also listed what was refered to as the signal scaler (logic board)
Posted on Sep 19, 2009
Lcd flat panel, no picture
Most LCD sets use backlights---in a dark room with a flashlight look carefully with set on to see if VERY faint images can or cannot be seen--if see them the backlights are not on or not powered up.,
Nov 05, 2012 | Toshiba Televison & Video
HL-6187W, picture has vertical lines
If you can post a picture of what the lines are I can assist with the possible causes. I would assume digital board or DMD/ light engine
But a pic would help make it easier to figure out whats going on with the set.Respond to this same post for assistance.
Aug 07, 2012 | Samsung HL-S6187W 61 in. HDTV
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
I have a samsung model hlr4667wx/xaa picture freezes
analog board can cause that symptom especially if the pic is freezing .
Jun 26, 2010 | Televison & Video
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
Picture Display delay
Here is the location of the manual. You may also have to download the firmwhere updates that are located in this website also.
http://support.nikontech.com/faqid=14541
Good Luck!
Dec 16, 2008 | Cameras
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Set turns off randomly
there is a capacitor right behind hori output transistor it most of the time goes bad 1200pf 2k volts,yours could be on its way out,when it does set will not come back on.
Jan 09, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
