Question about Keurig Coffee Makers & Espresso Machines
Water sprays Hot water does sprays all over. All trouble shooting (in owners manual)procedures have been repeatedly performed.What options are left to perform.
  • Ken O'Connell
    Ken O'Connell Mar 30, 2014
    Water spills out from the top of the machine during brewing process. We have tried all the required procedures without success.more than once. This must be a defect in the product which was purchased 9 months ago. The product has not been used daily, but 2-3 times per week and only for 1 serving. Can it be fixed or do we just discard it as a lost cause.
    Problem Solver:
  • 14 Answers
Ken - this too sounds like the rubber gasket that goes around the water output is either missing or defective. I had that issue with a keurig at work. There is a small cylindrical rubber gasket that goes around the water output in the top of the brew head that helps seal over the top of the k-cup when closed. Make sure this didn't come off.
Posted on Apr 20, 2014
BRAND NEW RINNAI BOILER E75cn Shower runs hot then warm then hot then lukewarm then cool then lukewarm then cold
get the installer people back to set the operation correctly as it should have been test run before they left
read your operators manual for settings or trouble shooting
Feb 24, 2016 | Home
Inglis MOD#IPU58460 Dishes not cleaned properly...thought that enough water was not being filled into tub because more water added manually and washes great! I checked inlet water valve operation and...
HI,
The problem can be with not enough water to get the arm to spin. To test this just add a pan of water to the wash cycle and see if the arm spins. If it does then the problem may be with the water intake line. There is a screen at the connection where the intake line enters the dishwasher. So turn the supply valve off and disconnect the intake line and remove particles that may be traped in the screen. The cause of the particles is from the hot water tank that tend to accumulate a bit of corrosion on the bottom of tank. To remedy this just open the valve at the bottom of the hot water tank and drain it in a pan until the water is clear.
Jul 03, 2008 | Dishwashers
Pld4555rfc3
Hello ddux97 - Here are a few simple troubleshooting tips that may help you resolve this issue:
· Do you have hard water? Hard water is the primary reason to cause soap residue. Water hardness can be determined by the local water supply company, water treatment company or via a water hardness test kit, which can be found at local part distributors or hardware stores. Some kind of water softening is recommended, in areas where the water hardness is 12 grains or higher. For very hard water a home water softening system would be recommended.
· Will the upper spray arm rotate freely? If it does not, then there isn't enough water being pumped to the spray arm or the full flow of water is not making it to the upper spray arm. Remove or replace the spray arm assemblies since it is possibly damaged.
· Confirm that the drain hose is strapped up properly under the sink to prevent the water from siphoning out during the cycle.
· Dishwashers require the water inside the unit tank to be 120F to perform properly. Best way to ensure this happens is to run the sink faucet until the water comes out hot before the dishwasher is turned on. This will ensure that hot, 120F water goes directly into the dishwasher when it starts to fill. When checking dishwashing detergent boxes and with detergent manufacturers, the compounds in the detergent need water temperatures to be between 125F - 140F to dissolve in the dishwasher. The water pressure should be 20-120 psi (pounds per square inch). If it is too low, I recommend reaching out to a plumber to further assist you.
· Rinse aid dispenser should be checked and filled about once a month depending on the number of washes you do in a month since this will cause cloudy dishes and soap residue.
If these basic troubleshooting tips prove ineffective, then at this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Jun 19, 2013 | Frigidaire PLD4555RFC Dishwasher
Changing thermostat on ruud water heater
1) Copy following link to adjust water heater temperature.:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Add a comment if more help is needed. Jan 2013
Jan 26, 2013 | Rheem Ruud Commercial Electric Water...
Need instruction book for Cuisinart Single Serve Brewing System Model # CUISS-700
Here are the instructions to de-scale your Cuisinart SS-700, taken directly from the unit's manual, available here (www.cuisinart.com/share/pdf/manuals/ss-700.pdf):
1. Empty the reservoir.
2. Disable the AUTO OFF and OFF TIME features.
3. Making sure there is no K-Cup in the brewing chamber, fill the reservoir with 60 oz. of undiluted white vinegar.
4. Place a large mug on the drip tray and run a Hot Water cycle. Select the 12 oz. brew size. Discard contents of mug.
5. Repeat the hot water process until ADD WATER is displayed on the control panel and the reservoir lights will flash.
6. Let the Brewer stand for at least four hours while still on.
7. Rinse the water reservoir thoroughly and fill with fresh water.
8. Run another Hot Water cycle. Discard contents of large mug.
9. Repeat hot water process until ADD WATER is displayed on the control panel and the reservoir lights will flash.
10. You may need to perform additional Hot Water cycles if you detect any residual vinegar taste.
Note: If DE-SCALE is still displayed on the control panel after completing the procedure, repeat the de-scaling procedure above.
If you found this solution helpful, please leave a positive rating!
Sep 17, 2012 | Cuisinart SS700 SINGLE SERVE BREWING...
I have a honeywell pilotless hot water heater control model wv4460e. This unit is not working and I was trying to trouble shoot it. I have tried to unplug it and plug it back in and it seems like the...
The blinking light is actually an error code. See the trouble shoot section in the manual: http://www.bradfordwhite.com/images/shared/pdfs/manuals/45960A.pdf
Jan 28, 2011 | Kitchen Ranges
Does not clean
Hi
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 08, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
No water
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=467200
No water
Posted by Emma Ann on Mar 25, 2008
My Bissell ProHeat 2x and it's not spraying any water out.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Bissell 9500 ProHeat 2X Clean Shot Upright
This could be that you have a defective water valve assm below the water tank or the trigger assm is not working properly or not connected. You may want to refer to your owner’s manual and check out the trouble shooting guide for no water coming out. You may want to contact the factory or manufacturer to see if they have service tech support or to send out a new owners manual for your current model #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don – The Vac Man
Go Ahead. Use Us.
Mar 25, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Coffee Makers & Espresso Machines Logo
139 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
