Question about Mtd 22" Yard Machine Push Mower
How to replace the cranking pull cord?
Pull cord broke need replace spring loaded
  • 658 Answers
Ok, the spring will more than likely unravel when you remove the pull cord cover/assembly. There is notch in the spool for winding the rope around it. So make sure the spring is wound enough to fit it in the housing. Then take the rope, already knotted and in the spool. Turn the spool in the direction that tightens the spring.Push down on spool and allow spring to retract the rope. (Don't forget to tie the knot in the rope handle before placing on mower). Then lightly clamp in vise or visegrip, or channel lock pliers. I like to use visegrips on one side, and channel locks on the other. Place over the square flywheel nut,release channelock pliers, hold with fingers tightly so the spring does not unravel. Then release visegrips and hold with other free hand, Place over flywheel nut and slide down. Re-attach with screw previously removed. Your done. Don't forget to tie the knot in the rope handle before placing on mower.
Posted on Mar 29, 2014
2 Suggested Answers
rburroak
  • 14 Answers
SOURCE: lawn mower needs new cord to crank the engine. how do i replace the cord
Remove the 3 bolts located on the flywheel housing.(should be 7/16") one in front and two on side.
Posted on Jun 19, 2009
How do I replace a pull cord for pm 605 mcculloch chainsaw?
First remove the pull starter housing.
The next part is tricky. You'll have to release and unwind the spring that rewinds the pull starter cord. Remember how you do this because after replacing the cord, you'll have to rewind the cord and spring before inserting it back in the housing.
re-attach the pull cord housing to the chain saw.
Hope this helps.
Oct 19, 2014 | McCulloch Pro Mac 605 610 645 650 655...
How do i rewind the recoil spring on my craftsman lawn mower?
Normally these small engines use a clock spring to retract the rope.
Remove the cover on the top and you should find the spring either broken or the tab where the spring end has broken off or jumped out of the mount.
You will need to pre-load the spring with enough tension to retract the rope.
Remove the pull handle from the rope, load the spring and then wrap the rope around the pully holding the pully and spring in the loaded position. place the end of the rope through the hole and tie up the handle. The rope should pull and retract without being installed on the engine.
Best explained here...
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jun 27, 2014 | Mtd 22" Yard Machine Push Mower
Need toknow how to rethread pull cord for briggs & stratton 300 mower
You need to remove the Recoil
Remove the Old line
Insert the new line
Wind the spring tight
Ensure you have 6 feet outside
SO YOU UNDERSTAND. THE SPRING IS COMPLETELY WOUND (Then backed off ONE ROTATION). and then allow the spring to RECOIL to PULL the line in and then the Pull Length. it will become quite clear as you are doing it
Apr 13, 2013 | Garden
Pull start cord won't rewind model no RLT30CET curved shaft electric start
There is a spring there you don't need to buy one use the old one.. If you need one go online give them model number have in two days.... Good luck..
Sep 15, 2012 | Garden
How to thread pull cord on my Talon rotary mower
remove THE COVER THAT HOUSE THE PULL CORD pully. TURN THE WHEEL IN THE direction THAT IT GOES WHEN cord is pulled ( THIS TIGHTENS THE RETURN SPRING) hold this wheel tight..every turm it could spin back rapidly. turn wheel 6 complete turns. align the hole in the housing with the cord hole in the pully wheel. thread cord through both tie a double knot . slowly release now install cover. try it if too loose pull out to max , hold pully, remove knot , cord and turn 2 or 3 more turns, replace cord, double knots , slowly release. replace cover, crank it and cut that grass.
Dec 04, 2011 | Talon Rotary Lawn Mower
The pull string broke how. how do i put the new one on?
Go to a hardware store and ask them if they have ant bulk pull starter rope. Buy about 3 feet or so of the small stuff (it is only 30 or 40 cents a foot, cheaper that the kits) Remove the motor cover with the pull start and turn it so you can see the wheel inside. Remove the knot that held the old rope in the handle and then cut the knot on the starter wheel and pull out the tag left in there.
Now the fun part. The wheel is spring loaded and the spring has no tension on it after the rope broke. Wind it up like a clock spring until it is tight then back off until the holes where the cord goes line up. Stick a small screw driver, nail, ect in the slot to keep it from unwinding . Do not tie the handle to the cord yet. Slide the new cord through the hole in the cover and wheel and then tie a knot in the cord and pull it snug in the wheel. Hold the rope and remove the pin and let the cord slowly wind itself up. Run the cord through the hole in the handle, Adjust to the length of pull you want and tie another knot.
Reinstall the motor cover (if it binds and wont go on, pull the rope just a little bit to line up the crank with starter wheel and it will slide down.)
It sounds a bit windy but it really is a simple fix.
Jun 09, 2010 | Troy Bilt Tiller/Edger 26cc, Model No....
Pull cord broke on my craftsman gas push edger. I replaced cord but when I pull cord..It wont rewind but I can hear it trying to start
It sounds like you did not properly rewind the spring that is behind the spool that the cord would around, that spring is what rewinds the cord after pulling the cord.
May 05, 2010 | Craftsman Garden
Pull cord stuck in the out position
this can be caused by sevral things inside the pull cord hub assembly. examples: Dirty inside & needs taken apart & cleaned. something logged inside, plastic spool tabs broke, spring/s broke, levers broke or any of these items could just be to worn. replacement parts should be available.
Oct 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Pull cord for a cs30 broke how do you replace it? yes i know about the 4 torx screws. does the torque converter just pop off?
Here is a general overview of what you need to do.
1. Get a new cord
2. Remove the old cord from t-handle.
3. Remove cover of starter pully & old cord( pay attention to which way it is wound or mark w/ an arrow).
4. Tie new cord onto pully & wind.
5. Now you need to pre-load the re-winder spring. ( If you need help with this write me a comment & I can help).
6. Holding the rewound spring, thread the cord through the cover and t-handle and tie.
7. reattach the cover.
Hope this helps,
Andy
Sep 11, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Pull cord is out and wont return. unable to crank
they spring clip is broke, you have to take the head off and reconnect. You have to get a new head or spring, depending on which one failed. Good luck
Jun 09, 2009 | Garden
Mtd 22" Yard Machine Push Mower Logo
67 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
