Question about Kenmore Refrigerators
Kenmore elite side by side refrigerator 253.44383406
The Actuator-water paddle is broken off at the base. I have ordered a replacement part but can't figure out how to get the broken part out and replace. Can anyone help.
3 Suggested Answers
HVACRH20
  • 237 Answers
SOURCE: Water Actuator is broken.
This diagram may help you see what's behind all that stuff. Let me know if it helps or if you need something better. http://www.partselect.com/Schematics/Frigidaire/YZ41HPYZ.gif
Posted on Jan 13, 2007
I had the same problem with my water dispenser and since they were willing to sell me a part but provided no directions and I couldn't locate any I decided to make my own for those who might need them. Here is a link to a PDF I made, hope it helps.
http://www.rharriman.com/SupportFiles/FridgeActuatorReplacement.pdf
Before starting this job I would also like to warn all to please be save and UNPLUG the fridge. The whole job took me less then 30 minutes and I doubt anything will go bad in that amount of time.
Posted on Mar 31, 2010
How do I get the kneeding blade out of the bread machine?
soak the paddle in soapy water overnight with enough water to keep the paddle submerged. The next day wiggle it back and forth while holding the litte ears underneathe the pan. Move it up and down too. If it still doesn't break free go to you tube and type "how to remove a stuck bread machine paddle" have your husband do that move, but don' use more than one jug of water because the TBR15 pan is thin and can bend. Be sure your husband uses hot pads to hold the pan edges so he doesn't hurt his fingers. If that method doesn't work you will have to live with a stuck paddle or order a new pan assembly and paddle and then always remember to remove to soak your paddle after baking and remove it from
the stem, clean, and store. Daryl,,, from breadmachineshelp.com
Feb 26, 2013 | Toastmaster TBR15 Bread Maker
I love doing surfing on flat water and looking for best Paddle manufacturing company in US? Can anyone give suggestions?
I feel proud to give you best suggestion about paddle manufacturing company which provide broken paddle replacement warranty also.I will provide you link here hope you share with other also. http://crocstix.com/blog/
Oct 27, 2012 | Refrigerators
How to remove water filter paddle for ge fridge
From the looks of the illustration you'll have to first pop the trim off from around the dispenser area using a small flat head screw driver. Once that is done remove the control panel, which is sometimes held there in place with a screw from bottom area of the board. Lift the board out of the retainer that holds it in place and you disconnect any wiring to remove it completely. Once that is out of the way you should have access to the paddle to replace it. Be sure that the machine is unplugged when you start, don't want to get shocked
http://www.partselect.com/ModelFrames.aspx?ModelID=1598847&ModelNum=PFCF1NJXABB&mfgModelNum=&ManufactureID=2&Selected=00127059i01&Position=2&mfg=GE&Type=&Mark=2
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 22, 2012 | General Electric PFCF1NJX Bottom Freezer...
I have a stainless steel Frigidaire side-by-side refrigerator with an ice/water dispenser in the door. The paddle on the water dispenser broke, and I need advise on how to disassemble the dispenser in...
the front cover will come off. if you dont see any screws then it WILL unsnap. look for a slot on the top or bottom of the cover. good luck some of them can be nasty
Oct 28, 2009 | Refrigerators
Ice and water dispenser stopped working
Welcome to the computer world. When depressed, the paddle actuates a switch attached to the bracket above. The switch sends a low voltage signal to a small circuit board mouted right behind the display. A computer chip on that small board communicates with another chip on the main control board mounted in the rear wall. Your situation could be a bad actuator switch, a broken paddle tab, possibly a bad door switch (the fresh food doors must be closed to dispense), or a bad electronic control.
Jun 05, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Whirlpool gold refrigerator icemaker leaking water
hi there,
sounds like the ice or water actuator or paddle is broken. purchase a new paddle and replace it.
the reason you have leak is because you have warm air entering through the broken part into the freezer.
can you provide me with the model # and i will send you a part breakdown.
Sep 09, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Broken water paddle
remove the bottom pan by pulling it out, then you will see three screws. remove the screws. Push the fram up which will unlatch it. The asbly will now come out. pull the water hose and the electrical connector, and you'll see the screws that hold the paddle.
Aug 12, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Broken water paddle
be sure to unplug the refrigerator.
remove the drip tray by sliding it forward.. then remove two screws . slide the dispencer cover up two screw hold in the control remove water line two screws hold in water paddle. remove paddle and wire.
to replace water line use a long screw driver to push back into cover. make sure it extends bellow outlet..
hope it helps
Aug 08, 2008 | Frigidaire FRS26R4A Side by Side...
Jan 13, 2007 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
122 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
