Question about Water Heaters
Ariston MicroGenus 24 HE MFFI - Error A03. Heating runs for approximately 5 minutes then errors. On reset, it repeats. Error indicates that returning pump temp is above 103 Degrees. Have replaced the Overheating Thermostat (#996065) but issue persists. Have switched off heating and hot water will run for 5 minutes without error. Does this suggest that the pump is degraded / broken?
  • 1462 Answers
SOURCE: Hoover nextra 5+5 washer dryer HNWF 3135 heating broken
it is seperate heaters for wash and dry and unlikely to be connected with blocked filter tho you should check filter regularly. take top off. on manifold running across top you will see stats. one of these at least is resettable by presssing a small knob in middle and if it has gone you will hear a slight click. then check dryer manifole for build up of lint as pooir air flow can cause stat to pop. for wash heating, start by checking continuity of the wash heater located at the bottom of the tub
Posted on Apr 19, 2007
SOURCE: no hot water help
have a ariston euro combi boiler ,the problem to get hot water i have to turn the heating on to get hot water. but now it only run for a few min then run cold please help
Posted on Feb 28, 2008
SOURCE: F05 on Maytag MFW9700SQ1
I have had my epic front loader washer and dryers for 1 year now. I picked them after carefully researching other brands/models and reading many reviews. Epic had the most positive and satisfied reviews/ratings of all at the time.
I have a large house with 6 furnished suites and I do the laundry for all suites weekly, so there is a lot of laundry. The Epic machines have been great, even with some overloading abuse by the cleaning staff.
I did, however, just experience my first problem - the "Control locked problem"
I googled and found this excellent site - and the fix for the problem (hold "cycle end signal" button down 3 seconds). Worked like a charm...
I tend to think that all of the digital front loaders for all brands will have a problem like this once in a while, as they are fairly complex compared to the prior generation of washer/dryers.
However - your problems with your new machine sounds bad - like you may have gotten a lemon.
I bet they would send you a new replacement machine at no charge if you called Maytag... I would try that first before shopping for a different brand/model...
good luck!
Posted on Jun 13, 2008
SOURCE: Maytag Epic Z washing machine F20 error
F-20 error code its water inlet problem (no water or insufficient water supply) check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Posted on Mar 16, 2009
  • 6 Answers
SOURCE: Hotpoint WF645 error message: test
press start once then press again then hold on/off and cancel for a few seconds should now turn test off should be ok now
Posted on Oct 17, 2009
I have an ariston 20/24 mffi combi pressure rises when switched to central heating but pressure ok when asking for hot water ? expansion vessel ?
over heat limit stat on central heating circuit ? if hot water is ok and hot to temp when run for 5 minutes the expansion vessel is doing its job.remember hot water is the maximum demand for any boiler ,,heating is secondry?once you establish hot water at maximum rate then the only real problem is on you demand for heating??
Dec 10, 2012 | Water Heaters
Ariston ACO MFFI 35 E34 fault code present
This is the manual for your boiler. I hope the information contained in the manual will help you identify your problem.
http://www.ariston.co.uk/uploads/doc47e92b04013d8.pdf
Mar 30, 2009 | Water Heaters
Pilot light on boiler
The plumbers repair should be guaranteed, give him a call back.
It sounds to me that the pilot flame needs to be adjusted or the thermocouple is not aligned properly or there is a draft that is blowing out the pilot.
Good luck...
Feb 22, 2009 | Water Heaters
Boiler problems
heres a copy of the serviceing manuel for the unit. just click on the link and download the manual. http://www.ariston.co.uk/uploads/doc482c2cada6e71.pdf good luck
Jan 11, 2009 | Water Heaters
Moved in house Monday & have a radiator leak due to bad rust...what's best temporary repair to hold for a few weeks b4 plumber available? What sort of Boiler is Ariston Genus 24 mffi ?
turn both valves off at each side of radiator and once the pressure balances it will stop leaking, there is no solution to this whilst using this as a radiator to heat the space, but will stop the leak.
Dec 24, 2008 | Water Heaters
Radiator Leak rust
what part is leaking ?what type of set up do you have? steam or water
make sure you completely drained and refill the system before use. your water level needs to be corrected or this will force water up the lines instead of steam
your radiators need to be pitched so that the steam (water) can return back when the system shuts off
as for the leak. where it is or what part is leaking
heres a manual for your system
http://www.ariston.co.uk/uploads/doc4947b0d538f79.pdf
hope this helps
Not able to top up water level on my ariston microgenus 20 MFFI
Julie... I need more information to solve your problem. Such as make and model of your heater.
Ray
Nov 14, 2008 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
