Question about Garden
Castlegarden TCR 102 mover wont get into gear
I stopped to clear out the grass while cutting and when i restarted the mower wont go into gear - has anyone seen this before?
    Guru:
  • 145 Answers
Hydrostatic or geared transaxle??
Posted on Apr 12, 2014
  • 52 Answers
SOURCE: craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Posted on Mar 11, 2009
  • 109 Answers
SOURCE: blades are engaged,but won't cut the grass
Check the blades to make sure that they are not upside down
Posted on Apr 24, 2009
  • 32 Answers
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
  • 61 Answers
SOURCE: I have a scotts (made
sounds like safety switch
Posted on Sep 06, 2009
perpetually
  • 360 Answers
SOURCE: uneven grass cutting
I have seen dull blades, blades not installed right and an un-level deck cause that.
Hope this helps.
Posted on Sep 21, 2009
Craftsman zts 7500 50" deck is there anyway to adjust height on this mower? at the highest level it cuts way to short and i have tons of grass blowing out the side cant hardly mow unless i mow about e
The range of the mover cut should be between 3-3/4" to 1-1/2".
If you are not getting these heights then the mover height mechanism may be jammed or broken. Use lubrication as instructed in the manual.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0803095.pdf
Sep 01, 2014 | Garden
How to take out bearings out of housing on castlegarden 17,5/102 deck
Hard to say without model numbers but from what I seen about them it looks as if you have to knock it out from the underside of the deck pushing it thru the top. Use another bolt to put in blade hole so you don't ruin regular one. Hit it with a hammer or press it out.
Aug 03, 2014 | Briggs & Stratton Briggs Stratton...
Castlegarden twincut ride on lawn mower cutting out
some engines have a low oil level sensor yes. ck. oil level
Jun 02, 2013 | Garden
White smoke coming out of front of Husqvarna riding mower
it might not have been over filled with oil i have seen many needle valves not seating in the carb the gas over fills the carb and drains into the crank case thinning out the oil and if not caught in time i scores the cylinder wall
Jun 02, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
MY TRANSMISSION IS VERY WEAK, MOVER WILL SOMETIMES STOP, WONT MOVE, OTHER TIMES IT WILL CREEP ALONG. ITS ONLY HAS 300 HRS ON IT.
noted for frequent failure of hydrostatic transmissions, just search this site. you have to buy another transmission or lawn mower.
Sep 01, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My jd 102 doesn't make a sound when key is
check the sensor for the box and check the main fuse on the line from switch to starter.. the fuse can sometimes trip and the connector work loose. if you have no turn over the fault is electrical. I would go over the wires for the seat switch as this was the last to be cut off when you got of mower
Aug 05, 2009 | Garden
Lots of smoke when I engaged stuck blades - now runs roughly
Most likely what you did was burn one or more spots on the belt. When the blades and belt stop turning, like in tall grass, the engine doesn't stop and will burn flat spots on the belt at the engine pulley. Every time the flat spot hits a pulley, it will jump and can set up a bad vibration. Run your hand around the sides of the belt or take it off and you will feel or see the thin spot(s) on it. Replace belt.
Jun 09, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower won't start
13 to 15 amps electric or battery operated mower may runs slow when cutting thick grass. also recommended not to cut grass when it's wet & need very sharp blade to do the lawn. may overloading it, cutting grass too thick also draws too much power. check house breaker first.
Jun 11, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
