Question about Fujitsu fi-5120C
Won't accept sheet feed. Replaced pick roller and pad assembly with Care Kit. Now the scanner won't intake the sheet, and makes a series of loud noises when we try to feed a document. It looks like
Drivers are in place, and device worked normally until we changed the pick roller and pad.
Adi_Taticu
  • 71 Answers
SOURCE: Fujitsu FI-4220C only scans one page at a time.
The problem is not just to roll over, be changed and separation pad. These two components change very easily and boxes that are delivered and indications for replacement.
These are the codes for parts:
Pad Assembly - Part Number: PA03289-0111
Pick Roller - Part Number: PA03289-0001
After replacement counters to be reset for each Pieces. Open the scanner properties.
Usually have to display a maintenance message on the computer display, such as: separation pad should be replaced.
If there is to scan any messages like that, you have to clean the sensors around the separation pad. They are round and are getting a little inside. Click on the blue button at the top of the ADF and open the lid.
I hope you was helpful.
Posted on Oct 07, 2009
TechSatya
  • 104 Answers
SOURCE: has Fujitsu fi-4340c scanner. Worked for a while
Explanation:
Front Side Optical Alarm only generated when start command is received or when white level reference is checked (every 50 scans). CCD output must be above predetermined slice level when reading the white reference. Slice level is set in F/W and compared to the read range values. The read range is approximately pixel 120 to 4800. If CCD output does not reach slice level the AGC tries to adjust the output of the amplifier to exceed the slice level. If any portion of the read range is lower than slice then Optical Alarm is generated. Also, it can be generated by dirty optics or reference, bad lamp or CCD.
Resolution:
If "Front Side Optical Alarm" appeared, clean the glass (small and large one) of the flatbed and carrier unit.
If the issue persists, then check if CCD harness or CR cable is disconnected? Connect the connector.
If the issue persists, then replace Front lamp.
If the issue is not resolved, then replace the Control PCA or Carrier unit or Optical unit.
Pls acknowledge if the issue is resolved.
Regards,
Tech Satya
Posted on Feb 09, 2010
TechSatya
  • 104 Answers
SOURCE: I have a fujitsu 4120 scanner that will not pull
Does the scanner displays any error message on the scanner panel? Is there any TWAIN error message?
If paper jam occurs, U1 error will be displayed on the scanner panel and TWAIN driver will display " Paper jam the ADF (Code DS32002)" error message.
This error is detected when one of the followings occurs:
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner
performs retry operation.)
2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Scan condition Transported length.
In order to assist you with your scanner issue, Please provide the issue details with error message.
If nothing is being displayed, then the issue could be due to failure in Pick Motor function or Pick Sensor malfunction.
Hope the above information is helpful.
Thank you for contacting FixYa.
Regards,
TechSatya
Posted on Aug 01, 2010
  • 11800 Answers
SOURCE: Just bought (ex USA) new
Mechanical noises = mechanical failure. You will have to dismantle the scanner and inspect the pickup mechanism - the parts that move the paper sheets are defective: the movement of the motor isn't transmitted to the gripping pads, probably a gear is out of position or a linking pin has been sheared off.
If you can't fix them yourself then the unit is pretty much dead : these replacement parts aren't available anywhere, not even the repair shop of a dealer - the parts and the labor to install them would cost more than a new scanner.
But you could search for another defective scanner on which the pickup mechanism is in good working order then buy it and cannibalise it for those parts. Or you can search at repair shops for same.
Posted on Dec 19, 2010
TechSatya
  • 104 Answers
SOURCE: We have replaced the pick roller and the scanner
Hi Tiffany,
This seems you've logged in to your PC as user. The clear option is sometimes not highlighted in user login. You need to login as Administrator to reset the count.
Thanks & regards,
TechSatya
Posted on Aug 28, 2011
HP 5100 paper feeding problem
Hello Paper feed problem are usually caused by worn feed rollers and separation pads. If you printer can not pickup the paper or pulls more than one sheet into the printer at a time then the rollers and pads need to be replaced. This is a user replaceable kit. You can get the kit here:
http://www.ccl-la.com/catalog/product_info.php?products_id=325
Apr 19, 2013 | HP LaserJet 5100 Printer
The DR-9080c scanner will take a whole stack of papers (20 or so) and shove it thru the paper path, not just the top sheet. On old laser printers there was a paper pick that got slippery. Is there one in...
Ensure that the "BYPASS" button on the control panel is not illuminated. Make sure the "Standard Feeding " is selected in the driver. Try cleaning the lower separation roller. Make sure the separation roller is pressing up against the feed rollers. If the roller set is worn, order a replacement set of rollers (Google: Canon 9080 Exchange roller kit)
Apr 04, 2012 | Canon DR-9080C Path-Through Scanner
I need part numbers for the ADF feed roller/shaft/clutch and the ADF Separation Pad/Roller.
Should be 002N02001 for the Feed Roller Assembly and 22N1487 for the Separation Pad
About $50 total for both parts
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 16, 2010 | Xerox WorkCentre M15i Laser Printer
The feeder takes several sheets at a time. How do
When ever you face such type of issue, the Scanner will display U-2 error with the Red led blinking and the TWAIN display will be "The multi feed is detected.(Code DS32006)".
To resolve the issue, please follow the steps provided below:
#Check if the documents satisfy paper specification? Please refer to the Operator’s Guide for paper specification, paying
attention to the following points:
• Is there any print within 10mm x 10 mm square in the center of documents on the top?
• Is multi feed error detected by paper length when scanning documents with different length?
• Is there perforation in the center of documents?
#Check ADF and clean pick roller, Pad ASY and around DF sensor with care.
#Replace Pick roller and Pad ASY and see if the error is removed. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the permitted values, replace Pick roller or Pad ASY. If the error still occurs, confirm that the cable is correctly connected then replace the sensor.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
May 06, 2010 | Fujitsu fi-5120C
The scanner takes 2 sheets of paper at a time instead of 1 so only 1 is being scanned. I've tried a different paper that is thicker than regular printer paper and it's still doing it.
There is a pad below the feed roller that wears out. It is called a ****** pad, it retards the feeding of extra sheets of paper. That pad will need to be replaced. Once it is it will stop multisheet feeding.
Apr 01, 2010 | Xerox DocuMate 152 Pass-Through Scanner
Documate 510 Roller Pad Assembly
Hi, I don't know if it's permissible to advertise but we currently sell the assembly for the Xerox Documate scanners. As far as I know the scanner's discontinued, and the pads are getting pricey so consider how much longer you want to wait before replacing the scanner.
sales at sprucecomputer dot co dot uk if anyone is desperate
Sep 21, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
I620-auto feeding multiple sheet
I opened the hood on the machine, and between the first two intake rollers on the bottom, there is a small rubber strip. This strip comes packaged with a sticky yellow tape to protect the rubber. When it was installed, no one removed this tape. After doing so, the machine feeds great. Hope this helps someone else who may be experiencing a similar feed issue.
Jul 16, 2008 | Kodak I620 SHTFEDSCAN Path-Through Scanner
XEROX DOCUMATE 510
The rollers and retard pad need replaced.
The rollers are self explanitory, the retard pad is so named to retard the feed of multiple sheets of paper.
That is your problem.
Nov 07, 2007 | Xerox DOCUMATE 510 Flatbed Scanner
Paper Jam
We need to the model/make to help you
but using some detective skills I've decided you are using a HP machine
Yup Dirty damaged worn feed roller but what model machine is it they are all different but pull out tray 2 cassette all the way and look in, there is probally a cylinder like rubber roller 5cm wide front centre of where cassette slides in, there might be roller on the cassette too at the front center as well.
Most modern printers feed rollers just slide off after lifting small plastic tabs on them and gently pulling, feed rollers are available but you can sometimes also get results by cleaning them with a dash of metho or water on a rag.
If paper feeds 2wo sheets at once then you need to change the seperation pad/roller too.
Nov 01, 2007 | Dell W5300N Laser Printer
Fujitsu fi-5120C Logo
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
