Remove frame need to work with text in frame
    Master:
  • 496 Answers
Remove frame? Which frame? Be more specific please
Posted on Apr 17, 2014
Is thier a way to take a tranny out without dropping the frame
NO. the bottom frame must be removed, it alot of work to remove the tranny on a ford taurus, you will need a top engine support also, this will hold the engine and trany inplace to remove the frame and then you lower this to remove tranny. good day.
May 12, 2011 | 1997 Ford Taurus
Need to remove the broken scanner glass on Hp 7780 all in one and replace it. All of the screws have been removed, however the frame will not come out.
This glass is easily removeable with the white plastic frame by removing the eight visible screws on the frame but there are also two more under the front control panel. Gently pry the cover off the panel and then with a small screwdriver carefully pry the panel from the frame (it has three small plastic retainers on the top edge). The panel will still be held by the two ribbon cables. Once this panel is removed you will see the remaining two screws holding the top frame on. To remove this frame you also have to unseat the lid by opening and then lifting straight up out of the hinge brackets...it will still be hanging by its control wire harness.. be sure and secure it while working so as not to damage your wires. Also if the glass was broken be sure and vac out the scanner area with a shop vac for any small pieces. If you need a replacement glass contact me at huddy911@aol.com. I should have a few laying around.
Aug 19, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
How do we remove the crocodile frame around the
If you have a DYMO LETRA TAG XR:
Press SHIFT + B key (simultaneously)
Choose 1 / the first option (no border)
Press ENTER key
Aug 01, 2009 | Dymo LetraTAG Thermal Label Printer
Wanted to erase a single picture, accidentally erased all. Now, computer not recognizing frame, asking me to format removable disk before I can use it. Unable to reinstall. Before, computer recognized...
Yes, that's because you have deleted the files. The frame will work just fine. You can can rename 'removable disk' to PANDIGITAL but it doesnt really matter.
All you need to do is copy the images and it will show up on the frame.
Jun 09, 2009 | PANDIGITAL 7" Digital Photo Frame With...
How to hide frame contents
kunju1:
I am uncertain as to whether you have previously worked with me or with another expert, and I don't know exactly what system, software, and setup you are using. This response presumes that you are using Word 2007.
I would suggest checking to make sure you feel confident that the frame is better to use than a text box, as it is unclear what content you have. See http://office.microsoft.com/en-au/word/HP051893331033.aspx.
At any rate, likely the best way for you to make the content "invisible", although you evidently still want the contents present, and the frame at its current size, would be to change the font color to agree to your page (usually white). For example, white text on a white background is not visible.
I will be happy to help further if you have more specific needs, if you will provide additional info to help me zero in on what you are trying to accomplish. Please post back if you need further help, otherwise thank you for using and rating FixYa!
smartsolve
Jun 19, 2008 | Microsoft Office Professional 2007 Full...
Scanning
Did you tried with any OCR software to convert the Scanned imaged (jpeg) to Word Documen?.Always if you scan anything to an image, it will scan in JPEG format that will consume lot of memory.Scan with OCR(Optical Character Recognition) Software and that will Convert JPEG to word Document which will fix the problem.
The OCR software that i Recommend is ABBY Fine Reader.
Thanks
Riz
Apr 21, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Xreox workcentre pe 16 problem
Remove the back cover. And looking from the back, remove the right side cover. There is a white ribbon cable and one connector with mostly red wires, remove and reseat those. Return power to the machine and see if it comes on.
If not, then remove the right side cover, the 2 screws that fasten the scanner to the frame, remove the scanner and then the controle consol, ( display.) then unplug all the connectors on the display and reconnect them.
It the display still does not work after reseating all the connectors, the display and or the scanner is/are defective.
Mar 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Razor video text
use motorola phone tool and convertor that convert video text to competibel to your motorola V3i , Because it's software has inbuild conveter
Feb 03, 2008 | Motorola Mobility RAZR V3
About flash 8
Here is the small sample code. This will convert the lower case letter to upper case letter from left to right character by character.
TextField.prototype.caseAnimation = function(str) {
    var tf = this;
    tf.upperIx = 0;
    tf.str = str;
    var id = setInterval(moveUppercaseLetter, 100);
    function moveUppercaseLetter() {
        var str1 = tf.str.slice(0, tf.upperIx);
        var str2 = tf.str.charAt(tf.upperIx).toUpperCase();
        var str3 = tf.str.slice(tf.upperIx+1, tf.str.length);
        tf.str = str1+str2+str3;
        tf.text = tf.str;
        tf.str = tf.str.toLowerCase();
        tf.upperIx++;
        if (tf.upperIx>tf.str.length-1) {
            tf.upperIx = 0;
this.createTextField("animated_txt", 1000, 0, 0, 500, 25);
animated_txt.setNewTextFormat(new TextFormat("_typewriter", 16));
animated_txt.caseAnimation("pack my box with five dozen liquor jugs");
Oct 18, 2007 | Macromedia Flash MX
Computers & Internet Logo
139 people viewed this question
David Payne
David Payne
