Question about Ingersoll Rand Air Tools & Compressors
Excessive oil with air
I have m22 ingersol rand rotary screw air compressor the oil go out with air i change the seprator and clean the scaving line and problem is still i wanted to ask there is the oil seal inside the air end
  • 44 Answers
Replace the oil separator it should work or check the scavange line for blockage
Posted on Apr 01, 2014
2 Suggested Answers
  • 2976 Answers
SOURCE: My rotary screw air compressor model SSREP100H
It's just too hot. Blow out the radiator weekly. There is an oil temp switch that might need replaced but the radiator is the most common problem with screw compressors. You can check the settings in the control panel, where you turn it on and off. It should be set for a high temp of 185°.
Posted on Aug 08, 2009
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Recomendation rotary compressor
1 check oil level
2 clean dirty oil cooler
3 replace thermostatic valve
May 09, 2013 | Ingersoll Rand Stationary Air Cooled...
My Ingersoll Rand UNI15-5-150-L rotary screw compressor only starts uo after trying to start between 10 and 15 times
image Regulator may difference on all set ups good luck
you may have a Regulator on Air-Compressor Mount on the Gauge or next to it this allow you to set a pressures from 0 - 200 psi this to helps you maintain steady and reliable operation of your air tools.
Apr 18, 2013 | Ingersoll Rand Stationary Air Cooled...
What does alarm start fault mean on the control panel on a ingersoll rand ssr ep-30 air compressor
I use to start up a 25 HP Ingersol screw type compressor. The only alarms I got were from power spikes which just needed the reset button to be pushed, then the on button - and the low oil sensor would shut it down and give an alarm when the tank was about half way down. They will blow up with no oil so there is a saftey margin on oil level.
Mar 28, 2011 | Ingersoll Rand Stationary Air Cooled...
My ingersoll ssr2000 rotary screw compressor trips &restart on it
Check defective HATS or Airend is defective. HATS means High Airend Temperature Switch.
Mar 03, 2010 | Ingersoll Rand Stationary Air Cooled...
Excessive oil in the air tank and air filter housing (more than a pint). I would like to know which component is not working. it is a 2 year old UP6-10
it might be a cracked piston ring that is causing your problem, or the wrong viscosity oil. I would change the oil first using the right weight and check again. Another issue might be a stuck or sticking valve. Let me know if you need more assistance
Dec 22, 2009 | Ingersoll Rand Ingersoll-rand Up6-10-150...
40 hp ingersoll rand rotary screw air compressor keep shutting
I have a ingersoll compreesor that keeps shuting down on high discharg air temp
Nov 12, 2008 | Ingersoll Rand Stationary Air Cooled...
Air Tools & Compressors Logo
160 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
