Question about Philips 42PF5521D 42 in. HD-Ready Plasma Television
Flashing green light and no picture on phillips tv
The green light comes on and then blinks twice,stays on and then blianks again.also makes a clicking sound
    Top Expert:
  • Philips Master
  • 75,304 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Unlike other brand sets, counting the number of blinks to Philips it different. It is not directly countable. Check the site for more details.
Posted on Mar 28, 2014
  • 100 Answers
SOURCE: Phillips TV clicking sound, then cuts off
The problem of that is a loose solder on the board..
Posted on Aug 07, 2009
  • 61 Answers
SOURCE: Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Posted on Nov 19, 2008
D_LLAMA
  • 6 Answers
SOURCE: 42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Posted on Mar 03, 2009
SOURCE: Hi, I have a Philips model 37PF7321d/37, 37 inch
The power board numbers you need to search for on eBay is 310432847531 or 310432838621 - they are compatible according to Philips.
Posted on Nov 05, 2009
SOURCE: Phillips Flat TV Model 20pf4121\105 (Flashing green led)
electrolitic capacitors 1000mf /10 v in pover unit
Posted on Jan 02, 2010
Mom's Sharp Aquos TV no sound or picture there is a green flashing light where the power light is I heled the volume up and channel down while the TV was unplugged. plugged it back in sound no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 24, 2016 | Sharp Televison & Video
Toshiba theaterwide hd
replace the lamp on your TV, but only replace it with PHILLIPS brand. Anything other than that, will not last. We just replaced ours with Phillips and the picture is much brighter. It really shows the HD quality of the tv.
Mar 24, 2014 | Televison & Video
How to determine if power board on emerson tv model lc320em1 is shot
The power supply regulator board to your TV is now working fine, and has no problems at all, as, there is standby light. Check all the other voltages comes out from the power board, to main board. If all of it found OK, the fault should be at its main board.
About blinking of standby/power light;
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 19, 2014 | Emerson Lc320em1 TV
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
WHY WONT IT COME ON?!?!?!?
If you would like us to help you, you must tell us what brand and model TV you have.
Aug 28, 2007 | Televison & Video
Philips 42PF5521D 42 in. HD-Ready Plasma Television Logo
111 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
