Question about Philips 42TA648BX 42 in. LCD TV
I have a Philips 42'' it works fine. But lately i been having trouble turning it on. When i try turning it on it does not shows the Philips sign its like purple then it turns off or its black complete
No sound No Picture No light when turn on but flicker and stays in stand by.
  • irma a
    irma a Mar 29, 2014
    THANKS VERY MUCH I'LL DEFINITELY LOOK INTO THE WEBSITE.
    Top Expert:
  • Philips Master
  • 74,251 Answers
Main board fault. Contact the authorized service centre for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 28, 2014
mumma_1
  • 903 Answers
SOURCE: 42" philips plasma
when a television turns off by itself and flashes as you say, it indicates that there is a problem inside the tv. If you keep trying to turn it on you may do more damage. It could be something as simple as a faulty fuse inside. If you have no expierience with electrics I suggest you get it checked out by a professional. I had a similar problem with another tele model and it was the fuse in the back of the tele that needed changing. I did try to this on my own but unfortunatley didn't have the right fuse so i took it to a repair shop and he done it really quickly.
Posted on Oct 23, 2008
  • 44 Answers
SOURCE: Philips 42 inch HDTV - "FlatTV" Plasma -- does not turn on.
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
  • 231 Answers
SOURCE: I have a Philips plasma 42 with black lines across the screen
I would first check if there is an available firmware upgrade for your model .Upgrade requires you to download firmware from philips website.Then transfer it to a memory stick .Then use a memory stick reader to plug into tv for firmware upgrade.Other wise the set would probably need repair .Possible a bad SSB board or another issue
Posted on Aug 26, 2009
SOURCE: Philips 42" Flat Screen Plasma - blinking red light 7 times - HELP please!
Here is a photo of the board where I have removed the two from my TV. You can see the two open holes.
Posted on Dec 12, 2009
SOURCE: philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
Posted on Mar 06, 2010
I have a 42 inch philips lcd tv and it will not turn on. Tried unplugging it for 60 seconds and only the light will blink red sometimes and then blue sometimes. Do I change out the power source
Number of TV have a bad batch of capacitors on the power board. If you look like split mushrooms that is a bad sign. But there are kits if you know how to solder.
Oct 25, 2015 | Philips 42PFL7403D/F7 42-Inch 1920 x 1080p...
I have had my TV-- a 42" Philips plasma-- for
it can be a poor contact or puffed capacitor in the power supply board
Dec 06, 2010 | Philips 42PFP5332D 42 in. Plasma...
My tv has thin black horizontal lines on screen while showing picture. this is not caused by cable since it happens while using ps2 or dvd player. I recently moved, but it was working fine after the...
that could be a sign of a bad panel. my experience is that these panels are more expensive than the tv itself, but might be worth looking into since I've heard about prices coming down
Mar 27, 2010 | Philips 42FD9954 42 in. Plasma HDTV
Screen frozen
I've had this same problem and we only bought this TV back in July. It seems to be getting worse. Anyone have any answers?
Feb 07, 2010 | Philips 42PFL5603D 42 in. LCD HDTV
Aug 26, 2009 | Philips 42PF9630A 42 in. Plasma Television
One minute its good, the next i get nothing.
There is a eletronics parts thats has a cold solder on it. Maybe there is a cable or wire is barely touching on the connector inside the main pcb board. See technician to check your tv. Don't let this problem will continue, bacause some of the electronics will be damage.
Jul 24, 2009 | Philips 42PF9631D 42 in. Plasma Television
Philips HDTV
Hello, please describe the issue (if the power lamp is on or blinking). Anyway, you will have to call the Authorized Philips Service or the tech with best references. Best regards, Arpi
Apr 25, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42TA648BX 42 in. LCD TV Logo
78 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
