Question about LG DLE2532W Electric Dryer
Blowing but no heat
It runs but the temperature is off
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
The problem needs to be identified as it could be one of 4 problems.
The Thermal fuse needs to be checked firstly as this prevents overheating of the dryer.
If it is OK check the continuity of the heating element with an Ohm meter, check also whether there is a reading present, meaning it should not read zero Ohms.
Components that do not commonly cause this problem are the High Limit Thermostat and the Main Control Board.
If the first 2 checks are fine, check the thermostat to see whether it is "open" (Not giving a reading on an Ohm meter) if so, replace.
The main control board very seldomly causes this problem but it does not rule it out.
Posted on Mar 30, 2014
Mitsubishi heat pump blows cool air when set on 70 in heat setting. It will be 3 years old in January.msz-fe18na
Cooler than normal discharge air temperatures are kind of nature of the beast for an inverter compressor system. An inverter compressor has essentially an infinitely variable output due the varying speed of the compressor. When is is running slower the transfer of heat is less than when it is running full bore. At least on a mild day. On a cold day, even running at full speed, the leaving air temperature can feel a bit cooler due to the lack or heat available in the outside air to transfer in to the indoor coil. The Mitsubishi's are capable of running down to 5 degrees above zero without the addition of a low ambient control kit and the nearer it is to that temperature, the lower the leaving air temp will be.
There's only about three more 300 page VOLUMNs of information available to describe the function of these little guys, but maybe just a taste of the info will satisfy your concern. Of course what's written above is a very Cliff Notes version with a lot of holes in the description.....but you get the drift.
Dec 18, 2014 | Mitsubishi Heating & Cooling
Heater blows little heat
If my information doesn't answer your question I would ask, please provide year, make, and model. The first thing that I would check is the coolant level (radiator needs to be full). Check that the coolant is reaching normal running temperature (that will be between 200-210 deg.s). Check related coolant hoses to the heater core. Check hoses for defects (a clogged or pinched hose will restrict flow). Check coolant flow valve (shut off valve), at operating temperature test both coolant hoses and see if the temperature going in is slightly hotter than the temperature of the coolant going away (if the two temperatures are very different then the heater core could be clogged? I hope that helps, please let me know. Good luck.
Mar 01, 2014 | Chevrolet Cars & Trucks
Heat gauge goes way up,then by reeving motor it will go down.blows cold air
Check out related help links with solutions to troubleshoot the problem:---
Click the link below:---
2004 Toyota Tundra: Oil Gauge and Temp Gauge Not Working?
http://howtobyme.blogspot.in/2012/05/2004-toyota-tundra-oil-gauge-and-temp.html
Toyota 4Runner: Temperature Gauge Sensor http://technoanswers.blogspot.in/2012/04/toyota-4runner-temperature-gauge-sensor.html
Temperature gauge sits over half way mark? http://schematicsdiagram.blogspot.in/2012/04/temperature-gauge-sits-over-half-way.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
------------- No heat on Oldsmobile Silhouette? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Temperature gauge does not move and no heat when heater is ON? http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
Temperature gauge keeps fluctuating up and down close to red? http://technoanswers.blogspot.com/2012/01/temperature-gauge-keeps-fluctuating-up.html
----------- Temperature gauge on the dash quit working on Pontiac Grand Prix? http://technoanswers.blogspot.com/2012/01/temperature-gauge-on-dash-quit-working.html
Dodge neon gauges not working? http://technoanswers.blogspot.in/2012/02/dodge-neon-gauges-not-working.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
1992 Lexus LS400: Engine overheats, Antifreeze out of reservoir and heater Blows Cold Air? http://whatisbyme.blogspot.in/2012/05/1992-lexus-ls400-engine-overheats.html
These details will help.
Thanks.
Nov 22, 2012 | 1997 Ford Taurus
Heater blowing cool air
Is it set on summer switch which is the fan running all the time blowing cold air
Feb 15, 2012 | Heating & Cooling
Temperature guage doesn't work and heat blows cold
Check the thermostat.It sounds as though it's stuck in the open position. Fuel comsumpion increases as well.
Nov 24, 2010 | 1994 Toyota Tercel
The car over heats while idling then cools as you drive
its the radiator fan running? check the fuses.
if the radiator fan does not run when the car achieves certain temperature, then your temperature sensor maybe defective.
check if you have enough coolant.
Apr 27, 2010 | 1997 Honda Accord
Remington PTAC Heater/Cooler
you may have a bad heat sequencer
Jan 11, 2009 | Heating & Cooling
LG DLE2532W Electric Dryer Logo
44 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
