Question about Dayton (4LX56) Gas Heater
Electrical diagram for my new 4LX56A
I did not receive the wiring diagram with my new Natural Gas heater
I have a valliant atmo gas water heater and no hot water just the red bulb flashing
Gas (natural or propane) water heaters require electrical power to make the igniter work. The most common source is two (2) D batteries. When the batteries become weak an visual alarm will be visible, such as a red blinking light. Try installing new batteries.
Oct 10, 2016 | Water Water Heaters
Can you convert the tankless water heater model # RL94in from natural gas to propane?
Contact Rinna
Some water heaters allows changeover by installing new chipboard or changing dip switches... some do not.
Propane burns much hotter with higher pressure than natural gas
Gene
Water Heater Timers Save Money
Feb 14, 2015 | Rinnai RL94i Tankless Water Heater
Wiring diagram on whirlpool gas water heater
Whirlpool is AO Smith tank-type heater.
Year, model, type of heater not known.
So add a comment and then expert can look up the manual.
You probably have power vent, or dampered water heater, otherwise the only wiring would be for thermopile, thermal reset, and igniter.
Power vent, or dampered, of flow control water heaters plug into outlet, and wires from gas control run to the various components.
Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/Review-AO-Smith-Effex-water-heater.html
Don't forget to add comment and include model number that shows on label located side of tank.
Sep 21, 2012 | Whirlpool 6th Sense 40-Gallon 6-Year Tall...
I've been told that I need a new gas valve. Are they expensive and difficult to replace
Usually under $100 and easy to replace. Comes with instructions. The tricky part is knowing which wires to connect so make a good diagram of the original to match up with the new in case the wire colors are different.
Aug 11, 2009 | Jandy Lx Pool & Spa Heater - Electronic...
Owners manaul for SR400NA
If you have not received an answer to this issue, you can find an Owner's Manual online at:
http://www.pentairpool.com/pdfs/MaxEThermOM.pdf
I hope this is helpful!
Jul 12, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Rheem Pronto Hotwater Heater Error
Unplug unit from wall. Disconnect remote wires from circ board, and let unit set for about 5 minutes. plug back in. run water and see if unit comes on.
Jun 16, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Every time the thermostat tries to switch the heater on, the pilot light goes out. Cozy natural gas mod # CDV 335A
remove the thermostat wires from the gas valve and put a wire accross the outer terminals if unit starts up the stat or stat wire is bad.
Dec 17, 2008 | Cozy Enclosed Front Console Heater 20,000...
Dayton (4LX56) Gas Heater Logo
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
