Question about Cycling
How to put an adaptor for a child carrier on the rear wheel - it has a quick release lever
    President:
  • 1,138 Answers
This may help you. http://www.expertvillage.com/video/4835_rear-rack-bicycle.html Some child carriers mount on racks such as the one in the video using a quick release. If this doesn't help you will have to consult someone at a bicycle repair shop.
Posted on Jun 25, 2009
Magna great divide
The Magna Great Divide does not have a quick release lever on the rear wheel.
Aug 02, 2014 | chitech Magna Womens Great Divide 24"...
Rear seat jammed release lever does not clear
Is this a fold-down rear seat? Is it jammed the the folded or open position? If folded, try putting some weight and pressure on the seat back while trying the release lever (having an 8-year old bounce on it would probably work well :-}). If it's jammed in the open position, have the same "assistant" bounce back and forth against the seat back while you attempt the release lever. If no 8-year old is readily available, have your spouse/significant other, friend (or enemy) perform the same actions as would the child. The latch may simply need some "persuasion". Good luck.
Sep 29, 2013 | 2007 Hyundai Santa Fe Limited
I'm trying to change my rear tire , i have put the chain in the smallest cog in the rear, loosened the quick release but the tire doesn't want to come out. Do you have to do something with the...
If the quick release is truly loose, from the rear just lift the bike by the left side of the seatstay (or what would be a seatstay if itwasn't rear suspended) and rotate the rear derailleur backward with your right hand. It should just fall out.
Google "remove rear wheel bicycle" for lots of advice in video form.
May 20, 2011 | Cannondale Jekyll 800
How do I remove the rear wheel from my bicycle? I think it has quick release but I don't know.
1. If it has quick release it will have 2 plastic levers one at each side of the wheel axle. Otherwise there will be 2 nuts.
2. If it has the levers, Pull them out from the wheel. This eases the pressure on the nuts holding the wheel on the bicycle. Turn them anti clockwise to loosen them further. The wheel will then come away from the bike frame. (If it doesn't have the quick release levers just loosen the 2 nuts with a spanner)
3. Before taking off the chain draw a diagram or take a photo of how it's setup on the derailleur so you'll know how to put it on again. Pull the derailleur upwards to release the pressure on the chain and you will be able to remove it from the wheel.
4. All that remains then is to pull the wheel out of the brake pads.
Nov 15, 2010 | Cycling
I have a Cannondale road bike. There is a quick
You may need to remove the wheel, undo the quick release axle from the opposite side and then use the axle that comes with your trainer.
Jun 11, 2010 | Bell Sports Bell Motivator Indoor Riding...
No Rear Quick Release
Some less expensive bikes do not come with quick release skewers. You just unscrew the bolts like you would any other using a wrench or socket. The will probably be really tight so you may need to bear down or use a cheater pipe. Unfortunately, these bolt on wheels tend to be solid axles and cannot take a quick release skewer. You would need to replace the wheel.
May 20, 2010 | Schwinn Miramar Women's 21Speed Bicycle
1997 Geo Metro rear door won't open!
I have the same car, same problem. I've still not been able to fix it, despite taking the inside panels off the rear doors, checking the rods were seated, applying WD-40 to the lock mechanisms, and manually working the mechanism. Child locks are not engaged, but I tried putting them on and off too. Just won't open.
Feb 19, 2010 | 1997 Geo Metro
I am needing a manuel on how to put a 10 speed 26in girls bicycle together it is about a 1977
Rear wheel should be already on, put front wheel into forks and tighten nuts or quick release lever.
The handlebars should alredy be attchd to the neck. Put the neck into the frame and tighten bolt or allen head when bars are straight aligned to front wheel. Install seat and any reflectors....follow these instructions carefully cause the manual that comes w/these bikes is junk....Good Luck to you friend.....Tim
May 09, 2009 | Huffy 26in Ladies Sante Fe Cruiser Bike -...
Rear wheel problem on Raleigh X1 mountain bike
Three things come to mind when I read your question. First is the rear wheel bearings. Spin the wheel back and forth while holding onto it. See if you can feel any vibration or a rough feel in the wheel. I would think that if it were the wheel bearings you would hear or feel a grinding noise when you are riding.
If your rear wheel has a nut on both sides and you tightened them and that didn't work this means you must have the quick release system. You can tighten this by unclipping the wheel. Then hold the side that has the quick release lever. Hold onto the lever itself. Then turn the other end a little bit clockwise. Then put your wheel back on the bike and reclip the lever. It should now feel tighter. You may have to readjust the quick release lever a few times until you find the desired tightness.
Lastly the problem could be that your frame is worn out or broken somewhere. This would only show up when you are out riding because of your body weight and the strain put on the frame while you are pedalling. Also the part of the frame where your rear wheel sets may be chewed up. This would cause the wheel to never really tighten on the frame and could also cause the rear wheel to move.
I had a bike where the quick release wheel stystem went bad and it would not tighten on the frame. I believe the rod that went through the middle of the wheel hub was stretched and would just not tighten onto the frame.
I hope this has been helpful
Mar 17, 2009 | Crank Brothers Joplin Adjustable Seatpost...
Cycling Logo
102 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
