Question about Sylvania 7" sdvd8732 widescreen portable dvd player w/additional
Wrong region player says wrong region when u put disk in and try to set to default but does not change anything
How do i make my dvd player region 1 to region 2?
You can not change the region setting on set-top players. You will have to buy a region 2 or a region free player.
Yes, there are a few (players) that can be hacked, but this is way beyond the scope of the question.
Sep 02, 2016 | Televison & Video
My driver is not working with DVD.it is unable to read DVD .
It won't be a driver problem, DVD drives are generic, it will be either the drive has a problem, the dvd has a problem or your media player has a problem
1) Drive issue - does it player other dvd's - if yes, your drive is ok, if now you have a drive problem, try using a CD lens cleaner or a blast of canned air to clean the lens.
2) Disk issue, if just one disk doesn't play, then its a disk issue or data issue. Assuming the disk is clean and not scratched. Does the Disk have the correct country coding for your region. If not then you have to change the region setting on your DVD player
RMB My computer - Manage - Device manager - Optical drive - Properties - Regional settings.
Bear in mind most DVD player will only allow about 5 changes.
3) Media player, your current media player may not have the correct codecs to decodes the video files on this disk. Go to filehippo.com download and install VLC media player. This will play about anything and its free.
Nov 27, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Wrong disk
try cleaning your disk player with cleaning disk see what format your dvd player is set for chage to region 1 N America or whatever region you are in
Mar 20, 2010 | Coby TFDVD5000 Portable DVD Player
I have a region 2 samsung dvd player. All of a sudden the following message displays: '' Can not play disk. Wrong region code'' We have been playing the dvd for more than 1 year. What is the problem? Same...
What follows is mostly generic advice which applies to the vast majority of DVD players which I've tinkered with.
Your problem normally only happens if someone else has played a different region coded DVD on your machine. Normally you get seven chances to reset the region code before the machine locks itself permanently to one of them. before the changes are permanent the player will usually ask you if you want to change the region code when you try to play a disc from the wrong region.
Before doing anything else it's worth asking other members of your household if they have recently used the player, especially if you know anyone may have been using imported discs. If they've used up all of the region changing opportunities then hacking the machine might not work at all.
If you use a search engine you can search for DVD-P181 hack and these will guide you through the process to make your DVD player a multi-region machine, but there are three different hacks which I've seen for the same player so you may need to try them all.
Jul 03, 2009 | Samsung DVD-P181 DivX DVD Player
CURTIS DVD8723 i dont know why but now it keeps saying wrong region i got it iu the uk ond only use uk disks pleas help I currently have the same problem with my Curtis DVD 8723UK it is showing wrong...
hi there,
try to to do this to remove region code warning:
  • Turn the player on.
  • Press and hold Clear until the screen turns dark.
  • Now enter a region code (0 is defult, or 1 - 8).
  • Press and hold Clear. The opening screen comes back.
  • The default code (Region 0) is reset when the unit is turned off.
Hope this initial info helps.
Apr 23, 2009 | Televison & Video
Unknown disk -samsung HT-x30 DVD Player
It has no region code .You can download anydvd at slysoft.com
AnyDVD works in the background to automatically remove the copy protection of a DVD movie as soon as it's inserted into the drive aslo removing the region code.
Dec 17, 2008 | LG LHY-518 System
Coby 224 wrong disc
you can reset the settings through the menu, its under the advanced option in the menu. however, its not a regional error, if it was in the wrong region, it would say wrong region and not wrong disk, try putting the region back to 1 or 0 or 9, 1 is USA, 9 and 0 are all regions.
Jul 06, 2008 | Coby DVD-224 DVD Player
Proton PD-800 DVD player Region reset
Without disk in player click setup, then hit + and - over and over until the code shows up on your screen. I don't know which code will work, you may have to experiment.
Jan 26, 2008 | Protron PD-800 DVD Player
Wrong disc displayed
try to find crack for region code and set it up to be region free. that should do the trick.
Aug 14, 2007 | Yahoo Diamond Vision DVDC803-04 DVD Player
Sylvania 7" sdvd8732 widescreen portable dvd player w/additional Logo
27 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
