Question about Skullcandy Crusher
My skullcandy crushers bass is not working
I have them right out of the box and I have the battery installed. The bass is supposed to vibrate and shake, but I am getting no bass at all.
How to get crusher to turn back on after replacing batteries
Make sure batteries are installed correctly : note the +/- terminals on the batteries and the device need to match.
Jun 16, 2014 | Mattel Prehistoric Pets Interactive...
The bass vibration suddenly stopped working I changed the battery turned the music up loud and still mo vibration. I constantly have the bass on Max, and if that is the problem then skullcandy should not...
Sounds like you blew out the sub-woofer in the headphones. You could replace them, or if you've only had them for a year (or less) you can use the warranty included and have them fix it. All you have to do is call them up and ship the headphones to them.
Their contact page is listed below:
http://www.skullcandy.com/contact-us.html
May 17, 2011 | Skull Candy Skullcandy Skullcrushers...
Whatdo i do if my skullcandy headphones dont charge?
Are these amplifing headphones or ? Most headphones use the devices power source to make the headphones work, they use very low voltage and various ohlms to make the earpieces vibrate and make sound. If they are not working try pushing the connection in all the way, or try another set of headphones to see if the problem is with the device. Sometimes we get defective headphones right out of the box, Skull Candy is usually very reliable and quality checked before shipping, but it can happen with all manufactures. Gool Luck.
Mar 15, 2011 | Audio Players & Recorders
Contact issue with skullcandy headset/headphones.
could be the battery? or it could be a wiring problem. If that is the case they will replace it for you.
Aug 10, 2009 | Skull Candy (NNTN5751) Headset
Bass amplifier doesn't work even when i switched the batteries.
The bass unit must be defective. Talk to the guys at Skullcandy for a replacement (they offer lifetime warranties for stuff like this).
Their website has a link directly to the warranty page as well: www.skullcandy.com/warranty
Hope this helps
Apr 14, 2009 | Skull Candy Skullcrushers Headset
Rear Speaker Vibrations
just right off hand does your rear speakers have a port so that air traped can be released if you port your box sound would get better
air inside of a speaker box has no where to go so it bounces off the speaker makin it vibrate out perfect harmony
also some stations and cd's can have a bad tune too them or signal which can give distortion greatly not appreciated sound
but i would go with the port suggestion first
when i built my first speaker box from scratch i found out the smaller the box the more air would dammage the speakers so i ported the boxes sound increased so much better
bigger the box better the air flow and bass
May 08, 2008 | Car Audio & Video
No bass at higher volume
Your battery should be fine! Although the amp might not be strong enough for the sub. All you can do is check the RCA cables from your radio to your amp as these might vibrate loose when you get to 17 volume and also check the monster cable from your amp to your sub asit might have vibrated loose as well.
Oct 21, 2006 | Pioneer GM-5200T Car Audio Amplifier
Skullcandy Crusher Logo
336 people viewed this question
Top Skullcandy Home Experts
Donni Steen
Tom Chichester
Are you a Skullcandy Home Expert? Answer questions, earn points and help others
