Question about Ovens
My frigidaire es340 oven door won't close properly how can I fix it? I also have a little rust on stainless steele how do I remove without harming stainless steele?
3 Suggested Answers
SOURCE: oven door not closing
I was having the same problem with my frigidaire oven door. I was thinking that it was the seal getting in the way at first, but then I realized that the hinges needed to be repositioned. I wasn't in the mood for that kind of reengineering, so I came up with a better solution. Magnets. Not those **** fridge magnets either. Neodymium magnets. Place them on the upper part of the inside of the door, near the door lock (outside of the seal). You'll only need about three or four depending on the size. (get the fatest ones you can). If you know a computer geek you might be able to get a few free magnets from an old hard drive. I used five of these and I can just about pull the oven out of it's place while trying to open the door. The onhly problem is that heat destroys magnets and I can't say how long these will last because I just figured this out tonight.
Posted on Jan 25, 2011
SOURCE: have an old chef oven,
chef dynasty electric oven door needs someone to hold the oven door up when taking out hot food.
Help
Bev
Posted on Mar 09, 2011
The oven door is locked
Hello Berna Morgan, thank you for your inquiry!
Based off the information you have provided the door on your Frigidaire oven is locked. If you check on the control panel of your oven there should be a clear or cancel button, hold that down for three to five seconds. If that does not help unlock your door I would suggest performing a power reset and you can do that flipping the household circuit break for roughly ten minutes. That should provide a factory reset to your oven. I hope this information is helpful to some degree. -Matt
Feb 10, 2015 | Frigidaire FGB24L2EC Built-In 24 Gas Wall...
My oven hood has developed small rust colored spots on it. It is barely 5 yrs old and is stainless steel. I'm wondering what it is from and how to clean it without damaging it.
Your oven hood is "ferritic" stainless steel. Simply put it has iron in the alloy, and the appearing spots are rust. Use DeBruce Polish to remove the corrosion and "PACIFY" the surface. DeBruce Polish is non-toxic, odorless and non-abrasive. This multi - surface cleaner also works wonders on glass cook tops, chrome, polished granite, marble, fiberglass and more. A powder, simply use with water and terry towels. DeBruce Polish can be found @ debrucepolish.com
Sep 06, 2013 | Ovens
Remove oven door
Hello Eleanor Dailey - I understand that you will like instructions on how to remove the oven door, however may I please have the exact model number so I can assist you better in pinpointing you the instructions on how to do so.
Dec 15, 2012 | Frigidaire 27" Built-In Single Electric...
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
The doors on both ovens do not close tight. Are there replacement hinges? where can I get theme?
Same on ours... one seems like it is just softly lying against the gasket without a solid tight seal... doesn't bother the cooking much, it seems, but I hate little problems like this!
Will follow this thread to see if there is an adjustment for a DIY'er, without having to make a $120 service call...
Feb 12, 2011 | Bosch HBL 755 Stainless Steel Electric...
Do you know if a 445 stainless out door grill will rust
The new 445 stainless has a higher percentage of chromium. It has a better resistance to rustingt that the standard 316 stainless, and is much easier to work with in the manufacturing.
So , short answer, It will last a very long time in the weather without rusting. ((never say never ??))
Please Vote !
Jun 05, 2010 | Bosch HBL 445 Stainless Steel Electric...
Removing dust from inside the oven door
We buy DeBruce Polish at debruce polish.com, this stuff will remove the rust and pacify the surface.
Apr 15, 2009 | Frigidare GLEB30M9EC STAINLESS STEEL...
DOOR PROBLEM
I am not sure about your oven model.  I had a similar problem in my oven.  The hinges are riveted to the oven and can be fixed.
First remove the oven door - normally the door slides on to two prongs on either side and is screwed down.
Once the door is removed check the mechanism that holds the two prongs to the oven body.  Mine were held with stainless steel rivets that had worn out and became wobbly.  Cut the rivets and replace them with new ones.  You can get a rivet driver and the stainless steel rivets for under $20 at Home Depot.
Hope this works for you.
Oct 16, 2007 | Ovens
Ovens Logo
24 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
