Question about LG 50PC3D 50 in. Plasma Television
No POWER CHANGED FUSE O THAT WAS BLOWN AND I STILL HAVE NO POWER WHAT CAN I DO?
Spb karaoke machine blown fuse 250volt 2amp changed it checked plug in wall still no power what could it be pls
You may have blown a component of the power supply, which is what took out the fuse in the first place. Probably will need a trip to the repair shop.
Aug 19, 2016 | Music
My fuse blew in my Samsung 53" Plasma TV. I changed it, but it's blown again? What should I do next?
The fuse blown because theres a short circuit connection in the PCB power supply of your television.Please check the power supply inside,remove the back cover to see the power supply section.unplug first to avoid electric shock.Will you check the bridge type diode first.If the bridge type diode or diodes is shorted the fuse is always blown.Using digital tester check diodes,regulator transistor,and other transistor around the power supply.
Jul 16, 2011 | Televison & Video
Changed battery then radio will not work
Most likely the fuse for the radio is blown. If the radio is factory, check the interior fuse box (normally located on the lower drivers side of the dash) for any blown fuses. Normally the fuse that will blow will say something like "Radio", "Audio", "Interior", or "Cig" near them. If the radio is aftermarket, check the fuses noted above and also check for a blown fuse located on the rear of the radio (Usually next to, or on the main power harness).
Mar 22, 2011 | Car Audio & Video
My servis m6705(3 years old)has blown the fuse in the plug,i changed the fuse now it wont start,any suggestions?
hello it might have blown the fuse inside washer it will be in the power supply
regards
shaun
Dec 30, 2010 | Washing Machines
Cub cadet has no power changed battery still no
Blown fuse. There is a fuse somewhere thats blown. It will be about a 15 amp in a fuse holder either back by the battery or behind the dash. U didnt specifiy the 100 number If thats a starter-gen it could be a reg- relay issue.
Oct 22, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Changed video games and then it would not turn back on. No power to the wii box.
HI. the power supply board has failed. There is a fuse(3amps) inside the power supply unit. you will need to remove the cover from the power supply to access this fuse. once inside the power supply, inspect the fuse. if it is truly blown, replace it. if the fuse is not blown, this will confirm a failed power supply unit. it should be replaced in this case.
((Contact Nintendo for a repair ticket if the unit has failed))
Aug 04, 2009 | Nintendo Wii Console
No auxiliary power, no blown fuses. help, please
my power outlets in my 99vw beetle don't work. i changed the fuse for the cigarette lighter and it still doesn't work. help
Apr 23, 2009 | Chevrolet Malibu Maxx Cars & Trucks
Alternator overvoltaged, car won't start no spark.
Look in the fuse box under the dash for more blown fuse, advise of which ones are blown.
Dec 08, 2008 | 1991 Toyota Camry
LG 50PC3D 50 in. Plasma Television Logo
12 people viewed this question
Computer Repairing
Computer Repairing
