Question about LG 50PC3D 50 in. Plasma Television
T.v. won't turn on
Changed fuse that was blowen and i still don't have power what can i do to fix this problem.
  • 47 Answers
Bad caps in power supply,Crack or splits on top of cap or leaking, Check value of caps in power supply.
Posted on Apr 17, 2014
Power won't turn on
hi, there could be few components that might have failed, it might be best to look for a tech in your area, as you will need a multimeter service manual to help you
regards
shaun
Mar 28, 2014 | LG 50PC3D 50 in. Plasma Television
Dash lights don't work after changing alternator
Check all fuses and replace any that are blowen.
Feb 08, 2013 | 2003 Ford Focus
Magnavox 32 MF301B FLT TV has problem fuse blowen again and again no power
Most likely you have a short on the front side of the power supply. Further troubleshooting will need to be done to ensure.
Sep 07, 2012 | Magnavox Televison & Video
Fuse blowen magnavox 32 mf301b
shorted component at the power supply board. check the diode, transistor, regulator ic or a defective transformer.
My dome light in my 86 accord won't work and
Check your fuse box, it might be that simple. It should be located in the engine compartment (under the hood). When you find the fuse box, there should be a map of each fuse there and what each fuse powers. If one of the fuses is burned out, you should be able to replace it (make sure you use the same rated fuse -- a 20Amp for a 20Amp, or a 5Amp for a 5Amp -- usually they are color coded) and that should solve the problem. Japanese cars USUALLY have all of the fuses under the hood, but there is a chance that there might be a fuse box (or second fuse box) in the glove compartment, or under the dashboard.
If the fuse is not the problem, there might be a short circuit between the fuse box and the broken components. Bad wiring is much less likely, and much harder to fix, so if it is worth it for you to get it fixed, I recommend visiting a professional mechanic. If you don't want to invest that much money to repairing the issue, but need the Cig lighter to power a cell phone charger or GPS, you can run a bypass wire from the fuse box straight to the cig lighter. This will give you back your lighter, but will not solve the problem, which could indicate something more important, so it would be good to have a professional mechanic check it out when you have the time and money.
May 23, 2011 | 1986 Honda Accord
Turn signals inside are steady and don't blink. Exterior lights don't turn on at all in rear. Front signals turn on but stay on and don't blink.
this ether sounds like you have bulbs burnt out in the rear, a fuse blowen, or a bad flasher
first check the fuses to see if any are blowen (usually a blowen fuse will lead to this issue)
then replace the bulbs that are not working
replace the signal light flasher (this is usually found in the fuse box in the cabin of the car or mounted to the steering colum)
i hope this helps ^-^
Jul 26, 2010 | 1995 Buick Century
LG 50PC3D 50 in. Plasma Television Logo
Computer Repairing
Computer Repairing
