Automatic turntable adjustments
I recently bought a used Onkyo CP1055f turntable. While in overall good shape, the automatic queuing function seems out of adjustment. When I hit play, the arm rotates over the platter 1-2 mm too far. The needle is dropping in the grooves of the first track rather than on the rim of the record. How does one adjust the trim settings on the automatic queue?
  • Kevin Catalano
    Kevin Catalano Mar 31, 2014
    fixed the issue. Underneat the tonearm there is a semicircular plastic piece lined on the outside with rubber. This disc is held in place by a small phillips machine screw. This disc has cutouts for the photodiodes to time automatic functions. By rotating the disk slightly counter clockwise a very small amount (this was a touchy adjustment requiring several attempts), I was able to fix the issue.
    Scholar:
  • 188 Answers
The Service Manual may be downloaded at:
http://www.vinylengine.com/library/onkyo/cp-1055f.shtml
You will have to register (free) before downloading.
Posted on Mar 06, 2015
djproaudio
  • 515 Answers
SOURCE: sl-dd33 turntable
If your needle just started to skip across the LP, then that means your stylus is damaged/worn and needs to be replaced. It's very hard to see the diamond tip on the stylus, and it might not even be there at all. So checking it might not yield any results. This is what happens when the needle is worn. It will skip across the record.
- OPTiC
Turntable Technician
www.1200s.com
Posted on Sep 08, 2008
  • 3 Answers
SOURCE: Arm does not track properly but skips across records
Just guessing, but it sounds like you haven't counterbalanced your tone arm.  When a tone arm skips, it's usually because there's too much counter weight on the rear of the tone arm.  You want between 3-5 grams, but first you have to calibrate your tone arm (balance it so you know where zero is).  If you don't know how to do this, refer to the Ion directions called "Tonearm Setup" in the instructions.
Posted on Jan 04, 2009
djproaudio
  • 515 Answers
SOURCE: Cannot adjust speed on a vintage Technics SL-B30 Turntable
More than likely it is a faulty drive IC (Integrated Circuit). If so, your out of luck, because most parts for this unit are discontinued, with the exception of the belt.
There really isn't much else you can do. Will probably cost too much to repair, if you can find someone who can repair it.
Sorry couldn't be of much more help.
- OPTiC
Master Tech
Digital Analog Therapy
Technics Parts : Turntable Repairs
Posted on Aug 30, 2009
SOURCE: When I push the start
Click on the link below and view pictures and instruction on how to adjust your Denon DP-47F turntable:
http://www.audiokarma.org/forums/showthread.php?p=4192169
You can download a free copy of the service manual, click on the link below:
http://www.vinylengine.com/library/denon/dp-47f.shtml
Posted on Dec 05, 2010
SOURCE: Akai Ap-003 belt drive turntable pitch problem
Hi!
Make shure that is a 50Hz turntable. If you connect a 60 Hz turntable in a 50 Hz system, the result is aprox 28 RPM in the 33 RPM position/
Posted on Apr 03, 2011
ION Max LP turntable connected to Onkyo TX-SR604 Home Theater
Use a different, brighter sounding cartridge and/or use an equalizer to bring the sound up to your expectations.
Jun 21, 2016 | Audio Players & Recorders
How to hookup a sony turntable to a Onkyo TX-sr605
Hi
I have managed to find a manual for your Onkyo machine. It is in pdf format so can be saved to your computer for future reference. It can be obtained here:
http://www.uk.onkyo.com/downloads/1/1/7/3/6/21507518_65197b9e73.pdf
and by using the Adobe Acrobat Reader search function with "turntable" as the search term, I found diagrams on page 36 which clearly showed how to connect various types of turntable.
Hope this helps
Cheers
Jan 03, 2015 | Onkyo TX-SR605 Receiver
Hello, I own a Technics SL-235 among other technics among other turntables. My problem with this one is that while it sounds very good, there is a point whete it slows down every few seconds with different...
The pitch control maybe dirty a cleaner for this may help! Use only with the power unplugged! as some cleaners are too wet! let it dry then try unit if this does not work it may need to be calibrated. With the service manual this can be done if the right test tools.
Dec 01, 2014 | Audio Players & Recorders
Buzzing Technics SL-1300 Turntable
Check the connections to the cartridge.
Mar 13, 2013 | Audio Players & Recorders
I have a technics sl-b2 that hasn't been used in a while. It was my fathers, looks in good shape. I put a new belt on. I'm having trouble with the pitch adj. It seems to not be able to maintain the same...
Switches and other controls that permit the user to adjust the speed on the turntable often become erratic due to oxidation of the metal contacts contained therein. Dust and smoke add to the problem. Cleaning the controls with quality electronics-type contact cleaners usually gives years of happy service. The job is best left to someone familiar with the complete assembly since other finite adjustment potentiometers are often employed and located on the internal circuit board.
Aug 06, 2010 | Technics Audio Players & Recorders
I recently aquired a used rotel rx102 stereo receiver and onkyo cp101 A turntable. I bought a new stylus needle for my turntable, and plugged the turntable into the phono jacks on the receiver and from...
If the receiver doesn't have a function specifically named PHONO, yes. Very few AVR's have phono preamps. They're not expensive. I'd check eBay.
Jul 05, 2010 | Nakamichi AV-7 Receiver
Hi!
Dec 31, 2009 | Audio Players & Recorders
Stanton Turntable Problem with receiver/audio
You need a turntable pre-amp, or a receiver with turntable inputs.. The turntable is functioning properly, until recently no turntable had this built-in. Search ebay for turntable pre-amp and you should be good.
Oct 04, 2009 | Audio Players & Recorders
Operating instructions for Onkyo PL-25F turntable
I have the same problem with mine! If i budge the arm by pushing it to the left a bit, it seems to catch. i think the motor on mine is worn out and cannot get started on its own, but with help, it will slowly move on its own to the edge of the vinyl and drop into playing position. If that doesnt work for you, you might need to clean the belt for the arm motor, or buy a new motor.
Mar 08, 2009 | Audio Players & Recorders
Leveling Turntable
Yes, shims are fine, but just remember, shims are prone to movement. Why don't you bring all the feet to their maximum setting, then adjust from there. Perhaps the table it is sitting on needs the shims?
- Davis
DIGITAL ANALOG THERAPY
Jun 05, 2008 | Technics SL-1200MK5 Turntable
103 people viewed this question
 Grubhead
Grubhead
