Question about Saturn 2003 VUE V6
2003 saturn vue coolant issue
Had timing belt replaced and radiator flushed and filled. Since, have had to add 50/50 pre mixed coolant about one a week (maybe a 3/4 quart to fill line). No milky oil, not wet around heater vents. Suggestions or causes?
  • Saturn Master
  • 1,249 Answers
I suspect either you have a coolant leak or the water pump is slowly dying. If you don't see any coolant leaking out, it's probably the water pump.
Posted on Apr 01, 2014
Check radiator fluid? Type of fluid,and filling instruction.
There are 3 popular types of antifreeze on the market right now. Green, Orange, and Yellow or universal. If you are unable to tell what color your currently have I would go with the Yellow, or universal, just to be safe. You will want to wait until your vehicles engine has cooled before opening the radiator cap. Fill radiator and coolant reservoir with proper coolant and mixture. If using full strength coolant mix 50/50 with distilled water. If you buy pre-mixed coolant just add straight out of the bottle until full.
Jul 17, 2014 | Cars & Trucks
How many gallons is radiator fluid
On the 4 cylinder you will need 1 1/4 gallons of antifreeze mixed with an equal amount of distilled water for a 50/50 mix. On the V6 you will need 1 5/8 gallons of antifreeze mixed with an equal amount of distilled water for a 50/50 mix. Make sure and use the correct type antifreeze.
Jan 03, 2011 | 1986 Buick Century
We have replaced the radiator recently and we need to add the antifreeze fluid. Need to know which kind of antifreeze fluid we should use and if needed to mixed with water and if so at what %
if the coolant looked red/pink/orange than it was dexcool and the new radiator should be filled with dexcool only. Most of the time you will need to mix it 50/50 with water. Sometimes it will come premixed and it will be labeled as premix.
If the old coolant was green than regular green coolant is what you need. Again you can sometimes find it premixed but if not it will need to be mixed 50/50 with water.
Oct 15, 2010 | 1999 Saturn SC
Where is the radiator filler cap
There is no cap on the radiator. The radiator can only be filled or topped-off by filling the coolant reservior. To access the coolant reservior, remove the left side crank case cover and add a 50/50 blend of coolant and DISTILLED water (pre-mixed works well). Make absolutely certain that the coolant is compatible with an aluminum radiator. The wrong coolant, especially alcohol based, will destroy your radiator in short order.
Your best bet is to read the label for yourself.
Add your coolant mixture and then run the engine for a few minutes, then turn off the engine and allow the radiator to draw what it needs from the reservior.
God Bless and good luck
Sep 08, 2010 | 2002 Suzuki VL 800 Volusia
Need to refill the engine coolant in my 2003 Saturn Vue, is there a specific type I need?
Hi my name is Tom and I can help you. All manufacture res of coolant make the same coolant. There are standards set my government. I use Prestone, but andy coolant will do. I trust this is helpful to you.
Jun 29, 2010 | 2003 Saturn VUE
Temperature guage keeps going hot and cold
buy you a new temp sensor from the dealer not autozone,try that,my suburban did the same thing cause i got a cheap piece of **** sensor from az
Jan 05, 2010 | 1997 GMC Sierra
How to change/flush coolant on a 2003 jetta
Slap on those vinyl gloves because the ethylene glycol in antifreeze can cause skin damage - however we recommend this because the antifreeze feels like engine oil.With your catch pan in place, remove the radiator drain plug and collect all old coolant. Immediately dispose of the coolant as required by environmental laws - if you are to surrender the old coolant at a waste management facility, be sure you use containers which can be properly sealed to avoid spillage, etc.To expedite the draining process, remove your radiator fill cap to allow air to enter the system.
Also be sure to remove all coolant from your radiator reservoir. We suggest you use the gravity siphon trick - just be sure not to ingest any coolant.
[click for larger image]
figure 4
Watch the old coolant as it exits the system - this will give you a good idea of your vehicle's cooling system condition.If you see metal flakes, oily surface, white flakes, etc .. you can make a diagnosis of your engine's coolant system.
Essentially, if you see anything but coolant and some very minor debris, it can indicate the early signs of cooling system failure.When all coolant has been drained from the radiator, replace the radiator drain plug and then fill the system with plain tap water to dilute remaining antifreeze in the engine block.
With the cooling system refilled with tap water, replace the radiator fill cap and run the engine allowing it to reach operating temperature.When the engine's cooling fan turns on, it is an indication that the vehicle's thermostat has opened, allowing the freshly added water to circulate through the engine thus diluting the remaining coolant. Allow the engine to run for a few minutes before shutting it off.
At this point, you can either wait until the engine cools off, or take fate in your own hands and continue the flushing process.Repeat the draining process being sure to once again collect and dispose of all waste coolant.
At this point, if you have opted to purchase a radiator flush kit, you should refill the cooling system with tap water and add the caustic fluid as directed.
Run the engine for as long as the radiator flush kit calls for (usually less than 10 minutes).
figure 8
Once again, drain the cooling system, collecting all waste fluid. This is the last time you will be required to collect engine coolant during this process.Now that the cooling system is empty, replace the radiator drain plug and refill the cooling system with distilled water only. The reason that you should only use distilled water at this point is to avoid mineral deposits which will deteriorate your cooling system over time.
Once the cooling system has been completely filled, start the engine to allow the water to circulate. Once again remove the radiator drain plug. As the engine runs, pour fresh distilled water into the radiator fill hole at the same rate that it exits the system.Continue this process until the water being drained from the radiator appears to be clear and free of debris. Once you are satisfied with the drain water's appearance, stop the engine and allow all remaining water to drain out.Replace the radiator drain plug and prepare to mix your distilled water and coolant.
Be sure to mix your coolant to the ratio recommended by your manufacturer. In most cases, the ratio is 50% distilled water and 50% coolant.
As a tip, mix the coolant and water in a third container being sure to observe the proper ratio.As you mix your water and coolant, use your hydrometer to measure the specific gravity - this will give you a good idea of whether or not you are mixing the coolant and water properly.
Once you have mixed enough coolant and water to fill your engine's coolant system entirely, grab a funnel and place it in the radiator fill hole.Fill your radiator at a rate of no more than:
{ 1 L/min. \ 1.1 US qt./min. \ 0.9 Imp. qt./min. }.
Continue the filling process until the coolant reaches the bottom of the fill neck. Now fill the radiator reservoir to the full mark.
With the radiator fill cap still off, start the car and allow it to idle. As the engine runs, continue to add coolant as air escapes the engine and cooling system.As you top up the radiator, be sure to "burp" the cooling system by firmly squeezing the radiator hoses (both upper and lower). Continue to squeeze and release the hoses to help push any errant air bubbles out of the system.
Once you are unable to fill the radiator any further, replace the radiator fill cap and stop the engine - you are finished.
Nov 15, 2009 | 2003 Volkswagen Jetta TDI
How do you flush the cooling system?
on the new double cross flow radiators, trust me take it to a reputable shop, you dont want to starve one side while flushing the system and end up with a cracked head or warped aluminum head if so equipped
Oct 18, 2009 | 2002 Saturn L-Series
How to change radiator 1998 oldmobile intrigue
Hope this helps you. Here are the basics. There are many problems you may run up against (frozen bolts, stubborn or cracked hoses, rusted clamps, etc)that may need to be fixed or replaced before proceeding: SHut off engine, allow to cool completely. Disconnect the cooling fan, remove negative battery terminal connection. Drain radiator by opening draincock and/or removing lower radiator hose, collecting coolant in a drain pan. Do not let it go onto the ground - bad for environment! Open top radiator hose to allow remainder of coolant to flow out. A few quarts of coolant will remain in the engine block. You will want to totally flush and refill AFTER replacing the radiator to get all the crud out of the system. Unbolt radiator and disconnect any other items still attached (transmission cooler, temp sensor wires, etc.). Remove radiator and replace with new, reattaching all items removed from old radiator. Inspect other items and possibly replace suspects. Reattach hoses and make sure the clamps are tightened without pinching hoses excessively. Do a flush job with water/radiator flush, making sure the water runs clear out the draincock. Instructions for flushing the cooling system are usually printed on the radiator flush bottle. Be sure the heater is on and the engine warms up completely to open the thermostat. SHut off engine and drain as much water as will leave. Fill with 50% coolant mix (Dexcool or equivalent). Estimate water remaining in the engine and add 100% coolant to balance. COmplete fill with 50% mix. Remove air by running engine until warmed with the radiator cap off, adding coolant mix along the way.
Oct 09, 2009 | 1998 Oldsmobile Intrigue
Where can I get a wiring diagram for a 2003 saturn vue? After turning the air off, and the knob setting to zero, then turning the car off, I can hear the fan running for some time (like 10 minutes)...
That is the normal if your taking about the radiator ran, as long as the engine is hot, the radiator fan will run till the engine cools down enough for the temperature sensor to turn off the radiator fans. Your Saturn is 2003 and if you have not serviced the cooling system it may be time. The orange antifreeze has a life of 5 years or 150,000 miles and the green antifreeze has a life of 1 year or 30,000 miles. If the antifreeze has not been replaced, it may be a good thing to have the system flushed out with Preston radiator flush and then the antifreeze replaced with a 50/50 mix (water/antifreeze). If your not sure how to mix the antifreeze, you can buy them 50/50 premixed, With then new coolant, your engine can transfer the heat much better and will cool down faster. Note, too much water will boil over and too much antifreeze will gel up causing over heating. Good luck and hope this helps, keep me posted, be glad to answer any questions you may have.
Jul 16, 2009 | 2003 Saturn VUE
Saturn 2003 VUE V6 Logo
61 people viewed this question
Top Saturn Heating & Cooling Experts
Tom Chichester
Hank O
Level 1 Expert
David Ellis Rhea
Are you a Saturn Heating and Cooling Expert? Answer questions, earn points and help others
