Question about Balboa Instruments Pool & Spa
My Balboa wont start and makes clicking noise and the light lamp flashes. I have replaced the control panel but still no luck
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Balboa Instr... Master
  • 1,448 Answers
Sounds like bad start up capacitor for pump motor
Posted on May 08, 2014
I have a 50 inch DLP samsung and it wont power on after making a lot of noise (I replaced the lamp) worked fine for a few days now the red light and the right side green light is blinking. any sugge
The answers above are correct. It's either the lamp or the color wheel. Testing the lamp is pretty straight forward. Use an Ohm meter to see if the it's filament has continuity. It's unlikely that a good color wheel would fail immediately after changing the lamp. Look to see if some wiring is out of place and rubbing the wheel causing the noise you described. A jammed but otherwise good color wheel would cause the TV to shut down and display an error code.
Sep 12, 2014 | Samsung HL-S5087W DLP TV
Light keeps flashing in spa
Sounds like control panel failure or the keypad is locked/stuck.
Try hold temperature UP & DOWN together for 6 seconds.
or if you have a Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
As your lights are flashing the button might be stuck in the down position.
Jul 18, 2012 | Balboa Instruments Pool & Spa
Television is making clicking noise after repalceing lamp
You need to leave a lot more information than that.What is the background of replacing the lamp? Where is the clicking noise coming from? Is the lamp light flashing, etc.? My current best guess is that your ballast may be bad, but more info is always helpful in diagnosing a problem. Good luck.
Mar 25, 2011 | Mitsubishi WD-73734 73" Television
How DO I Reset My JVC '' 73'' inch tv I replaced the light but the blue light flashes and the lamp light theres a buzz noise for a second like it wants to start but no picture or sound just a black...
Take lamp out and reinstall. I had to do the same, hope this works for you. Oh, don;t forget to reset the lamp timer through the on screen menu. Good luck!!!
Feb 02, 2011 | Televison & Video
TV WONT START UP - RED LIGHT COMES ON AND THERE IS A CLICKING NOISE AS IF IT IS TRYING TO RE START - IS IT THE LAMP UNIT OR STARTER?
if the lamp has gone the bottom light will flash if the top flashes there a problem with the tv there is reset you can do
  • Point the Sony remote control at the TV and press and hold the "Up" arrow button.
  • 3
    Push the "Power" button on the TV while holding down onto the "Up" button. Release the "Up" button when the TV turns off, then turns back on.
  • 4
    Select "OK" when shown the factor settings and the television has completed its TV reset
  • Read more: How to Completely Reset a Sony TV with a Blinking LED ' eHow.co.uk http://www.ehow.co.uk/how_6011902_completely-sony-tv-blinking-led.html#ixzz17Eijjdrn good luck regards shaun
    Dec 05, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
    The Control Panel/Dispenser light went crazy...
    Sounds like a electronics problem would need to replace the board, LG parts are not normally expensive.
    Apr 11, 2010 | LG LFX25960ST Stainless Steel French Door...
    I hit power button then start start light flashes and wont start
    If your start button is flashing even when you hit your start button . Your electronic touch control board (ETC) is not working correctly . Either the intergrated curcuit board is not responding or the actuator on touch panel is broken . Push start button in and see if the button makes a clicking noise. If it does replace curcuit board , if it does't replace the part where you touch.
    Oct 09, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Replaced lamp now yellowish orange status light is flashing
    Hi,did you close everything up,make sure door cover is closed.Do you hear clicking noises? If you do it could be an issue with the the ballast that the board that powers the lamp.Make sure fans are running ok,dust them out if they are dirty.Also reset lamp timer by unplugging tv wait 5 min and plug it back again.Good luck and God bless you!
    Oct 07, 2009 | Mitsubishi WD-52525 52" Rear Projection...
    Epson ELP 3000 clicking noise and all lights flashing
    1,Check the fans ,whether each fan is running,when you turn on the projector
    2,if the fans run, then ,check the lamp or lamp ballast
    Have a nice day!
    We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
    motherboard, powersupply ... with high quality and competitive price.
    Jerry
    Lampdeng Limited
    Mar 26, 2009 | Epson (1023661) Projector Lamp for...
    Pool & Spa Logo
    147 people viewed this question
    Top Balboa Instruments Pool & Spa Experts
    russlakeside
    Level 1 Expert
    Are you a Balboa Instruments Pool and Spa Expert? Answer questions, earn points and help others
