Question about Jenn-Air Dishwashers
Panel does not light up when press start
Press start, nothing happens. 'normal' and 'quick' wash light up a little bit, nothing happens.
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
control panel light all of a sudden do not come on and my unit wont start model kud101fl
Posted on Mar 25, 2008
  • 171 Answers
SOURCE: dishwasher powers up when switched
Hi mcdoddle,
I'm Harvey the master Plumber.
Your problem is: dishwasher powers up when switched on via control panel. When start is selected, the lights indicate wash but nothing happens. This may sound stupid but first make sure no one turned the water off to the d/w. If OK then you likely have a clogged or failed solanoid valve. The d/w must be removed for replacement. I don't recomend this for the average homeowner. You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 15, 2008
  • 1214 Answers
I suspect for either of these units that the timer control boards are bad.
Posted on Jan 24, 2009
SOURCE: My Whirlpool Quiet Partner 111
Disconnect your circuit breaker for 20 minutes and then reset. It should reset your dishwasher.
Posted on Jan 28, 2009
No sign of life to our 5 year old D/W except flashing "CLEAN" L.E.D.
7-1 heating circuit problem control programmed to shut down machine when no rise in water temp during heat cycle, you either have an open heating element or wire burnt a shorted thermistor or a bad control not outputing 120VAC to the heater you can reset the control by placing the machine into diagnostic hit cancel button to turn off all the lights press heated dry-normal, heated dry- normal within 6 seconds lights should come on press cancel unit should start it will run till same part of cycle reached and lock out again if it has not been removed the little black panel below the door remove should have the tech sheet in a plastic pouch which explains how to check the components mentioned earlier,
Apr 03, 2014 | Whirlpool GU2800XTV Dishwasher
I am trying to start a cyle and everytime i push the cycle button it does not light up and the quick rinse button comes on and flashes nothing works at all if i push heavy wash it comes on and nothing...
You haven't told me how many times the light flashes, but I will take a guess that this is an error code associated with the water entering the machine being too cool. I believe the machine expects the water to enter at 110 degrees F (43 Degrees C).
To clear the error, press "Heated Dry" then release, then press "Normal Wash" then release and repeat this sequence until all the lights on the machine go solid green. Once this happens, hit ""Cancel" and the machine will reset.
The fix for the root of the problem is to increase the temperature of the incoming water in future (Turn up your water heater temperature a little)
Jul 05, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
The washer fills with water but then nothing happens. The washer does not cycle at all.
I had this happen too; the problem was the lid switch. The plastic housing had come apart, either from the lid being slammed down or just normal wear and tear (the washer is 5 years old). Two small screws on the top inside edge and there was enough slack in the wires where I could pull it out to look; I held it together with my hands, pressed the lever and the washer started cycling as usual. Replacing it is a little bit of a pain but better than buying a new washing machine.
Jul 10, 2010 | Kenmore 22422 Top Load Washer
Machine has no lights or power.
Our Whirlpool washer is GVW9959KQ0, bought in September 2001, in September 2010 it had the problem as follow. When the panel was lite up, it was always set at "44" minute, NORMAL wash, no touch area is responsive, not even STOP or START. I could turn off the panel completely by pressing STOP and "Whitest white" in sequence quickly. When the panel was shut off, I could turn on the panel again by just pressing "STOP"; But the panel was back to "44" minute, NORMAL wash. Unplugging the power did not help (see as follow). That was the washer life for a couple weeks. We left it w/o power for 24 hours, it worked again normally just for 1 wash, and it was back again to the zombie mode; left it again for 24 hours, no luck, left it again for 24 hours, worked again for just one wash. We managed to wash 3 loads during the 2-week period (just 1 wash per time). Since the washing functionality sounds and looks working well to me, I thought that the panel might be the culprit. Finally we ordered Control Panel Assembly (Parts AP3884746, it is just the panel part where we touch for washing selections w/o electronic boards behind it) at appliancepartspros.com (cost $178 regular S
Apr 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
When i press the on button - no lights light up. the little bell makes its normal noise but the lights do nothing. i can't get anything to happen
You can try unplugging the machine for a few minutes and then trying again. Sounds like the control panel may be out though. Good luck
Nov 30, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
It won't start. The panel lights up, but nothing
Either the door switch or timers is faulty. I would test with ohmmeter, voltmeter, or a multi-tester that has both.
Sep 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Power light is on but nothing happens - indesit iwme12
If the door does not lock at this point it probably needs door lock replacing
Sep 05, 2009 | Washing Machines
Turn on ok. Press start and spin light blinking and beeping.
Several problems were found
1. the touch panel PCB board had tracks which were damaged by moisture and had it repaired for $50 (Aus); this affected the advance function on the washing machine.
2. Controller motor was replaced with a rebuilt one (since the touch panel kept on shutting down).
3. Make sure that the wire holding the harness reed switch is tight (this I think controls the level in the washing machine).
Apr 13, 2009 | Fisher Washing Machines
Dishwashers Logo
22 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
