Question about Nintendo 64 Console
Luxor TV Nintendo 64 tuning
Having real trouble tuning my Nintendo 64 into my Luxor LED TV. Done this many times before on other TVs but having real trouble on this one. There doesn't seem to be an easy way to manual tune either, any suggestions?
    Problem Solver:
  • 5 Answers
Could have a bad cable. If its a coaxial cable, it should display over channel 3 or 4. Check you TV settings, might need to change the broadcast option(Digital/Analog). Or get an rca cord(red/white/yellow connectors) if your TV takes composite/component inputs. Good luck.
Posted on Mar 28, 2014
5 Suggested Answers
SOURCE: My nintendo 64 wont workon my tv!!
First you must be sure that the connection on your tv is securely connected.
Posted on Mar 08, 2009
  • 52 Answers
SOURCE: can't work nintendo 64 with a antenna connector. help?
Yes you will, you will have to find an un assigned channel and get the tv to fine tune it in.
Posted on Jun 01, 2009
  • 47 Answers
SOURCE: will not tune in to samsung tv
Hi recommend purchasing a Audio Video Cable which does not require tuning these consoles. see
http://www.gameoz.com.au/store/super-nintendo/snes-accessories/super-nintendo-audio-video-stereo-and-s-video-cable-brand-new.html
Posted on May 07, 2010
  • 424 Answers
SOURCE: my nintendo 64 is not working on my tvs
Well it might be the av cable or the rf switch which one you are using might be causing the problem or it might need a new expansion pack then.
Posted on Oct 18, 2012
Factory settings on Luxor tv
You should after factory settings ,when you tune the correct channel you must press store ,and if your doing it manual you must press store after each channel is found. That's should do the trick.
Sep 21, 2017 | Luxor Televison & Video
My Luxor LED 55FSBi, can not get the correct aspect ratio. Not in any position, I get the whole picture. The image is zoomed in too much and do not in any position, I can´t see the edge of the texts.
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jun 06, 2016 | Luxor Televison & Video
Luxor LED550FHD Wont start
I'm afraid if the power was lost during the update, the TV has a real software problem. But you don't have the tools to put in a complete set of new firmware. When the TV is still working, the processor and the program can manage the upload to the memory and after a restart everything should work fine. But no perfect firmware in the TV now that can do the upload rot the flash memory. A technician has to connect the TV to a computer and flash the firmware manually.
The best thing is to contact a certified service centre from luxor and ask them.
Sep 06, 2014 | Luxor Televison & Video
I have a Luxor 19" TV from ASDA Mod: Lux-19-914-cob.
There are two possibilities:
1. channel memory is retained by an internal battery, which has died and needs to be replaced;
2. channel memory is retained in a memory chip, which for some reason is not functioning properly or has failed.
Either way you're going to need to fix something inside the set. TVs are so inexpensive today, you're better off buying a new one.
Sep 03, 2014 | Luxor Televison & Video
Nintendo 64 RF Switch Stuck
Well I guess that you will have to get a person that repairs tvs to get the piece that's stuck inside of the tv out then.
Jun 21, 2012 | Nintendo 64 Console
Need manual for luxor tv remote 19000 model
you cannot eject using remote. Press the stop button on the side 3 times to eject
Jan 15, 2012 | Luxor 19822 COB
Mylittle brother has just bought an n64 but were having terrible trouble tuning it into the tv,he has 2 leads with the console,1 lead goes from console to power supply the other goes from console to...
Ok, with the 3 coloured leads, this is an A/V or audio video lead. You should have 1 yellow, 1 red and 1 white. They simply plug into the corresponding ports on the TV. Also with A/V you don't actually tune the telly into the N64, you simply change mode, for example if you have an LCD TV you can switch between, HDMI, component, A/V etc etc. You simply need to use your TV remote and change the mode to A/V and everything should be fine.
Hope this helps
Dec 22, 2010 | Video Game Consoles & Games
TV not tuning to Nintendo 64
try with another tv if it dosent work on that too your 64 is passed away
Feb 21, 2010 | RCA Mikomi 5290925 15 in. LCD TV
Can't work nintendo 64 with a antenna connector. help?
Jun 01, 2009 | Nintendo 64 Console
Mar 08, 2009 | Nintendo 64 Console
Nintendo 64 Console Logo
133 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
