Question about Minolta DiALTA Di183 Copier
H2 after one legal page, the error h2 shows and does not copy No.2-3-4 continuously.
  • Minolta Master
  • 6,161 Answers
Paper size is set for a different country. Assumimg your in the US. Have to go into admin mode Maintenance mode set paper size to letter or legalnot B4 or C5 or A3 or A4 theese are metric size paper.
Posted on Jul 04, 2014
H2 error code and its solution
Just go to your key panel where you have the function keys and press the following in quick succession:
  1. Press # key- interrupt key- c key- interrupt key. The display should go off.
  2. Enter 14 and press ready key or copy key.
  3. Problem solved.
Dec 24, 2012 | Sharp AR-M205 Copier
My Zoom H2 recorder is not recognized by my new computer with Windows 7. What can I do to solve this?
No solution, just a workaround. I have used the H2 with firmware 1.90 successfully with Windows 7, but lately the H2 is not recognized anymore. Built-in obsolescence maybe?
Anyway, I just take out the card and put it in a card reader. It is faster also. Card readers are cheap.
Sep 07, 2011 | Zoom H2 Digital Voice Recorder
H2 error code
The power went off and then back on again... on the startup it shows you that your a set up for a 2 speed heat pump by showing you the H2 code.
Now you will have to just reprogram the t-stat again as you would if it was new...
Click here for the manual and programing instructions.
The good news is that there probably is nothing seriously wrong...
heatman101
Sep 02, 2011 | Carrier 38CKC042 Air Conditioner
How do you make legal size copies
When you want to print something just hit Ctrl+P and then you\ll have a screen showing you some details regarding your printer, click on details then look for Page Size. There select Legal and then click OK and you're good to go.
Hope it helps...
Apr 29, 2011 | Office Equipment & Supplies
How do you enlarge on the HP309A SERIES
  1. Use the following guidelines to determine which setting to choose:
    • Copying an original to letter or A4 paper : Choose Fit to Page , or choose Full Page 91% to prevent unwanted cropping.
    • Copying a legal-size document to letter paper : Choose Legal > Ltr 72% .
    • Copying a photo to full-size paper : Choose Fill Entire Page .
    • Copying to a custom size : Choose Custom 100% , use the Up or Down arrow buttons (c01314741.gif ) to reduce or enlarge the size of the copy, and then press OK .
  2. On the LCD screen, choose Copy from the options (use the arrow buttons) and press OK .
  3. Press the Settings button (the button below the Home button) twice, to access the Copy Settings menu.
  4. Select Size and press OK to access the copy size options.
  5. In the Copy menu, use the arrow buttons to select the appropriate size settings. Press OK to continue.
  6. Press Start Copy Color or Start Copy Black .
Mar 05, 2011 | HP Photosmart Premium C309A All-In-One...
H2 Error Message on AR M205 Sharp Copier
hi..there is a problem in the thermistor,thats why you
get the error code as H2.
check this out..
thank u..
kindly rate my response..
Jun 23, 2009 | Sharp AR-M205 Copier
Tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Legal Sized 2-sided Copies through Automatic Feed
Does the copier print correctly when copying off the glass? I suspect that the document feeder has been set up to feed other paper sizes eg A4, A4R. Because of the conflict between sizes the copier adjust the image.
Oct 05, 2007 | Canon imageRUNNER 5000 Copier
H2 error
An H2 is an indicator that the temperature sensing device is reading open, preventing the machine to warm up. There is only one way to correct this and that is to replace the thermistor, and that takes a technician. Not a hard job but a novice could get into trouble and make matters worse. Aloha, Bill Monroe
Sep 06, 2007 | Sharp AR-5316 Advanced Digital Imager...
How to change from metric back to inches
H-2 errors are displayed when trying to change paper size in the U-7 function area. Also, the setting shows only two paper sizes instead of three.SolutionCAUSE: The machine is set to the wrong marketing area.
SOLUTION: Set the machine to the proper marketing area. USA=MC
Oct 13, 2006 | Minolta Di151F All-In-One Laser Printer
Minolta DiALTA Di183 Copier Logo
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
