Question about Sharp BD-HP22U Player
CHANGE REGION CODE TO REGION 1 - Sharp BD-HP22U Player
Change region code of my disk player
Go to device manager in control panel on pc
You will see list of devices
Click the tab by CD\DVD drives to expand tree
Right click on the CD\DVD drive you are needing to change region code
Second tab should be Region Code(Region 1 USA)
You can only change a limited number of times before it is locked to a region code.
Aug 07, 2012 | Televison & Video
I can't play dvd's from USA
The most likely issue is that the region code setting on your PS3 is not set to the United States region code. To change this:
1.) Go to BD / DVD Parental Control Region Code (don't ask me why its under parental control)
2.) Change the region code from whatever it is to "United States". The region code for USA is 1.
Mar 15, 2011 | Sony Playstation 3 (PS3) Console
My compaq laptop says i cant change the region
You only can change this setting 5 times, then it is locked. You can not change the Region code after this even if you reinstall Windows, or move the drive to another computer. You can try upgrading the Firmware for the drive from the Compaq / HP Support page for your product. If that does not work, you will need to replace the drive, or download and install a Region Free software like AnyDVD or DVD Region Killer.
Jan 09, 2010 | Compaq (158165-001) DVD Drive
How can i change regional code on panasonic sc-bt207
Please follow the steps : To change the player region code
1. Be sure players drive is empty (nodISC)
2. Enter following key sequence using remote control:
Enter, 6, >=10, <<, 00F2, Audio, 8, * requested region code here (1-8) *, Subtitle, 1
3. Player will reset and requested region code will be set.
- For example to set region code to 3 press: "Enter, 6, >=10, <<, 00F2, Audio, 8, 3, Subtitle, 1"
To set the player to RCE proof region free
Enter, 6, >=10, <<, 00F2, Audio, 8, 1, Subtitle, 4
3. Player will reset and set to "region-free" and "RCE-free" mode
To restore players factory region code
Enter, 6, >=10, <<, 00F2, Audio, 8, 9, Subtitle, 1
3. Player will reset and set to factory region code
Regards, Jay__yhg6
Nov 16, 2009 | Panasonic Home Theater System System
Change DVD Region Code
Regards, Jay__okj4
Oct 15, 2009 | Panasonic DMP-BD60K Blu-ray/DVD Player
DVD drive ''Free'' Region code does not play Region 1 DVD
You cannot see region 1 movies unless you change the region code, its designed this way as an anti piracy measure.
Oct 03, 2009 | Computers & Internet
Changing region code
you can change the region code with updates but its risky cos once you upload the update for the region code it may not let you play the other region coded games
Oct 01, 2009 | Sony PlayStation® 3 (60 GB) Console
Unlock region code for Insignia IS-HTIB102732
Call this number for Insignia technical help. Service : 1-877-467-4289. Hope this helps you with your problem.
Apr 01, 2009 | Insignia IS-PDVD10 Portable DVD Player
Changing the DVD Region code
Legally, the only way to resolve your issue is a new drive, the region code in the drive has been locked in the firmware and cannot be changed by normal means (You can search google for DVD region Code Cracks, but it is not recommended no legal)
Antipiracy laws mandated a limit to the number of times the Region code can be changed (5) and if you are going to be playing a lot of media from different regions, then get another drive and set it to one region (and mark the region on the drive) and use this for the other
Jan 26, 2009 | Dell Inspiron 1300 Notebook
Changing the region code
You can only change the region code a few times (usually 5), so I wouldn't do it. You should leave the current player at region 1, and buy and install another DVD player and set it to region 4, then you will have 1 for each region you want.
Aug 15, 2008 | Samsung DVD-R155
Sharp BD-HP22U Player Logo
29 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
