Question about gmail.com
My gmail account cannot find the server
Rudolf.louw@gmail address cannot connect to its server
    Guru:
  • 170 Answers
Open yours account through google chrome, it will fixed the problem.
if still happened again then after signup hen a/c. is in processing for opening, then choose a basic html viewer in down side of right hand above task bar. it will fix this problem. if still happens then updated your adobe & flash on urs computer
Posted on Mar 31, 2014
How to configure gmail SMTP setting for outgoing server?
Process to configure gmail SMTP setting for outgoing server
Gmail provides email services to user.It is used for sending and receiving mail.It is freely used by users.It is developed by Google.If you create an account an G mail then you can directly open your Google account there is o need to create another account. It provides unlimited space to user. For some Business application Gmail is used as paid .Gmail is used as open source.
When you use Gmail then you need to check that your server is connected to Gmail or not.You should know that Gmail SMTP server is used for sending email from your Gmail account. SMTP is Simple Mail Transfer Protocol ,it is used for every email account but it is not same for all the accounts.so for Gmail Account you need to configure Gmail SMTP settings then you need to follow these steps:
First you need to go in the Email client software then you have to go in the outgoing mail
first you need to check that your Gmail SMTP server Address that should be SMTP.gmail.com.
Then you have to enter your Gmail SMTP user name ,your SMTP user name should be same as your Gmail address.
Then You have to enter SMTP Gmail password,it will be your Gmail password.
Now you have to enter Gmail SMTP port number for TLS and secure socket layer connection.
Then you have to select "Use SMTP authentication".
Then you have to click on YES if if you see that Gmail SMTP TLS/SSL required.
Then your SMTP server will be set to your Gmail client.
You can easily configure your SMTP Gmail Setting with the use of above steps but if still you are not able to configure your SMTP settings then you can contact Gmail Technical Support for any query .They will provide you best solution.
GET INSTANT SUPPORT FOR YOUR GMAIL ISSUES NOW
Jun 15, 2017 | Computers & Internet
Tip
Gmail on outlook!
To use your Gmail e-mail account in Outlook, you must first make sure POP3 support is enabled in Gmail, and then you can add it to Outlook.
Log in to your Gmail account.
At the top of any Gmail page, click Settings.
In the Mail Settings window, click Forwarding and POP.
I don't see Forwarding and POP
Gmail is turning on POP3 support for users in phases. If Forwarding and POP does not appear, your Gmail account cannot be configured for POP3
support.
In the POP Download section, select Enable POP or all mail or Enable POP only for mail that arrives from now on.
Click Save Settings.
In Outlook, on the Tools menu, click E-mail Accounts.
Click Add a new e-mail account, and then click Next.
Click POP3, and then click Next.
Under User Information, do the following:
In the Your Name box, type your full name the way you want it to appear to other people.
In the E-mail Address box, type your e-mail user name followed by @gmail.com.
Under Server Information, do the following:
In the Incoming mail server (POP3) box, type pop.gmail.com.
In the Outgoing mail server (SMTP) box, type smtp.Gmail.com.
Under Logon Information, do the following:
In the User Name box, type your full e-mail address, including @gmail.com.
In the Password box, type your password.
Select the Remember password check box.
Note You have the option to have Outlook remember your password by typing it in the Password box and selecting the Remember password check
box. Having Outlook remember your password means that you won't have to type your password each time you access the account; however, it also
means that the account is vulnerable to anyone who has access to your computer. Use strong passwords that combine upper- and lowercase letters,
numbers, and symbols. Weak passwords don't mix these elements. Strong password: Y6dh!et5. Weak password: House27. Use a strong password
that you can remember so that you don't have to write it down.
Click More Settings.
On the General tab, under Mail Account, type Gmail.
Click the Outgoing Server tab, and then select the My outgoing server (SMTP) requires authentication check box.
Select Use same settings as my incoming mail server.
Click the Advanced tab, and then under Server Port Numbers for both Incoming server (POP3) and Outgoing server (SMTP), select the This server
requires an encrypted connection (SSL) check boxes.
Change the Outgoing server (SMTP) port number to 465.
The Incoming server (POP3) port number should change automatically to 995 when you select the This server requires an encrypted connection (SSL)
check box.
Click OK.
To verify that your account is working, click Test Account Settings. If there is missing or incorrect information, such as your password, you will be
prompted to supply or correct it. Make sure your computer is connected to the Internet.
Click Next, and then click Finish.
Notes
Do not select the Log on using Secure Password Authentication (SPA) check box.
Unless specified by Gmail, all server and address entries are typed in lowercase letters.
This works for both Outlook 2003 and 2007!
on Sep 04, 2009 | Microsoft Office Professional 2007 Full...
I m looking for email configuration for samsung corby
Note 2 Email accounts and Email section profiles
STEP 1: Create an email account on your phone
Go to E-mail accounts to create an email account (eg Gmail). You will see a screen installation instructions Email> Yes
Mailbox name: The name of the mailbox (you can put anything you like)
Then select Options, select Next to the mailbox. You will see two types of POP3 and IMAP4 (default every Gmail account has been activated POP3 allows sending and receiving mail from a mail client, here is the phone of you. If you want to use IMAP4 account Gmail using your computer to enable IMAP4 for your account because of Gmail IMAP4 default is Disable.) In this section using POP3
Click Next to enter information in the Your email account.
In My Email address box enter your Email address (eg samsung@gmail.com), The User name will automatically be filled in after you enter your email address. Then enter your gmail password (******)
Then select Next to address server and receiving mail server to send mail. (Phone automatically entered so you do not care)
Next to finish the account creation process.
For Gmail you need to install some new numbers on a phone is used, as follows:
After completing the above created account, you go back to Menu Email accounts to edit the parameters for Gmail.
At this time we have created an account named Babi, now I'll edit it (Options> Edit)
You may notice two parts Incoming mail server (the server to receive mail) & Outgoing mail server (mail server):
Incoming mail server you choose, check Secure connection and then Save again
Then go back and select the Outgoing mail server, also check Secure connection> Save
At this point you have completed STEP 1.
STEP 2: Create a connection to the account.
Guide to Vinaphone. Mobifone and Viettel similar
Email back your menu to create a connection profile (as created for the WAP GPRS connection). You select any one profile and select Options> Edit
O Profile name (profile name) can put anything you like, but so named for the network to be distinguishable.
Configuration of Vinaphone Email: APN: m3-world Login ID: mms Password: mms
(Viettel, the selected APN Network: v-internet)
Then choose Save to save your settings.
At this point you have completed the installation Email. Can now be used right:
Message Menu and select the Email Inbox and select Check for new mail check mail from your mailbox.
You will see a list of new mail is fetched. But that's just the title of the email you received. To view the full text, as well as downloading email attachments of the sender. You select Options> Retrieve to restore the email you want.
Mar 17, 2011 | Computers & Internet
I want to know if there's a way / software to sync my Samsung SGH-i607 with my Gmail account.
Yes, the SGH-i607 can support an IMAP account, and Gmail can be accessed through IMAP. They don't list the SGH-i607 as a supported client, but it should be possible to configure it to work with Gmail.
First, go to your gmail account and enable IMAP:
Sign in to Gmail. Click the gear icon in the upper-right and select Gmail settings at the top of any Gmail page. Click Forwarding and POP/IMAP. Select Enable IMAP. Click Save Changes.
Next, configure the SGH-i607:
While in standby mode, press the left soft key for Start Select Messaging Select New Account (3) Select Other (POP3/IMAP), using the navigation keys Press the right soft key for Next Enter your name & E-mail address, using the Qwerty keypad Press the right soft key for Next For User Name, enter your full email address (including @gmail.com), using the Qwerty keypad . For Password, enter your Gmail password. For Domain, enter gmail.com. Press the right soft key for Next. For Server Type, choose IMAP. For Account Name, enter your full email address (including @gmail.com). Press the right soft key for Next. For Incoming Server, enter imap.gmail.com and select "Require SSL connection". For Outgoing Server, enter smtp.gmail.com and select "Outgoing server requires authentication". Press the right soft key for Next. Select desired message settings, using the navigation keys. Press the right soft key for Next. Select desired configurations for Storage and Connection. Press the right soft key for Next. After you have determined how often the device will connect, press the right soft key for Next. Setup will now be complete. Pressing the right soft key for Finish will enter the newly-created account in the Messaging application.
Mar 05, 2011 | Samsung Blackjack SGH-I607 Smartphone
How to configure email for samsung gt-b5310
GO TO UR GMAIL ACCOUNT SETTING AND ENABLE IMAP. account name: Gmail SMTP server: imap.gmail.com SMTP port: 465 secure connection: SSL Incoming server type: Pop3 Pop3 sever: pop.gmail.com APOP Login : ticked Secure Connection: SSL Download limit: 500 Retreive option : whole messge Keep on server: ticked my email address: *****@gmail.com username:*****@gmail.com pssword: **** POP before SMTP: unticked SMTP auth: ticked SAme as POP3/IMAP: ticked
Sep 06, 2010 | Samsung Cell Phones
How to configer email address in lotus notes
From what provider are you trying to configure email?If its gmail,
1. Create a Lotus Notes database file to store your POP emails: Lotus Notes does not create a file automatically as Thunderbird or other mail clients do but you have to manually point the mails to flow to a file that is already existing.
2. In the local Address Book, create two accounts for accepting incoming email and sending outgoing email on Gmail. Names are not important but the configuration on the two accounts is!
Account document for Incoming Gmail:
The Basics tab
a. Account name: Can be anything (I chose In Gmail)
b. Account server: pop.gmail.com
c. Login Name: Your gmail email address (complete with the @gmail.com)
d. Password: Your password
e. Protocol: POP
f. SSL: Enabled
g. Only from Location(s): Doesn't matter. Although I would recommend creating a location document specific for Gmail if you are also using Domino Server. I chose creating a location (Gmail).
Protocol Configuration tab: There is only one field here and it doesn't matter what you do with it.
Advanced Tab: This is the most important tab.
a. Port Number: 995
b. Accept SSL site certificates: Yes (Most of the articles on the web tell you to choose No here. But it does work. Trust me. I have tried it)
c. Accept expired SSL certificates: Yes. (Most of the articles on the web tell you to choose No here. But it does work. Trust me. I have tried it)
d. Send SSL certificates when asked (outbound connections only): No.
e. Verify account server name with remote server's certificate: Disabled
f. SSL protocol version: V3.0 with V2.0 handshake
3. Click on Save and Close to save the document and exit. Now you will need to create another account document to handle the outgoing email.
Account document for Outgoing Gmail:
The Basics Tab
a. Account Name: Can be anything. I chose Out Gmail
b. Account server name: smtp.gmail.com
e. Protocol: SMTP
f. SSL: Enabled
a. Port Number: 587 or 465 (Both are SSL port and both work)
4. Once these two documents are created, I would recommend creating a location document to ensure that you separate your gmail from your other Domino based account on the client. The steps to create are:
5. In the same local Address Book, choose New --> Location
Basics Tab:
a. Location Type: Local Area Network
b. Location Name: Can be anything (I chose Gmail)
c. Internet Mail Address: Your gmail email address
Leave the rest as it is.
Servers Tab:
a. Home/Mail server: pop.gmail.com
Ports tab: No changes (ensure TCPIP is checked)
Mail Tab (Most important):
a. Mail file location: Local
b. Mail file: My Gmail.nsf (whatever you created in step 1 above).
Update: A couple of readers pointed out that I had missed an important step in the configuration how-to. So here it is. Step C has been added to include the missed step.
c. Internet domain for Notes addresses when connecting directly to the Internet: gmail.com
d. Send Outgoing mail: directly to Internet
Leave the rest of the fields as it is.
6. There is no need to change the rest of tabs. Click on Save and Close to create the document.
Change to the the new location and you will see Gmail getting downloaded in the mail file you created.
Jul 27, 2010 | Microsoft Windows XP Professional
Mozilla Thunderbird setup
    Google Gmail Outgoing Mail Server (SMTP): smtp.gmail.com
    The Gmail SMTP server requires authentication (use the same settings as for the incoming mail server)
    The Google Gmail SMTP Server requires an encrypted connection (SSL) on port 465.
    GMail uses POP3 over an SSL connection, so make sure your email client supports encrypted SSL connections.
      Google Gmail Incoming Mail Server (POP3) - pop.gmail.com (SSL enabled, port 995)Outgoing Mail Server - use the SMTP mail server address provided by your local ISP or smtp.gmail.com (SSL enabled, port 465)
Sep 21, 2008 | Computers & Internet
Email settings for sonyeric k810i
Menu>Messages>>>Email>>Settings>>New Account>> Add>> Account name>> Connect using>>(Chose your ISP)>>enter email address>>select Connection type as POP3>>incoming server address for the mail you want to configure (ex yahoo= pop.mail.yahoo.com, google: pop.gmail.com) username: (yahoo or gmail login id)..>> Password( for you account)..>> outgoing server (yahoo : smtp.mail.yahoo.com or for gmail: smtp.gmail.com) please specify your login credentials again, then port number is 110 and 25. should work.
May 12, 2008 | Sony Ericsson W910i Cellular Phone
gmail.com Logo
51 people viewed this question
Top gmail.com Computers & Internet Experts
David Payne
David Payne
john cordey
john cordey
Thomas Stauber
Thomas Stauber
Are you a gmail.com Computer and Internet Expert? Answer questions, earn points and help others
