Question about Rainbow E series Canister Wet/Dry Vacuum
Trigger pin is stuck or something else is wrong. why is it constantly leaking water as soon as I plug it in?
Water comes out bottom as soon as I plug it in. It seems that the pin that pushes up to release the water from the tank it stuck b/c water comes out like I'm squeezing the trigger constantly. I have to remove the clean water tank or it will leak all over the place. Its not the dirty water tank that leaks it the clean. How can I stop the water from coming out or wasting more time removing the tank after I wet the area of carpet that needs cleaned?
    Sergeant:
    Habit-Forming:
  • Rainbow Expert
  • 138 Answers
You will need to provide more information as in the model AquaMate you are using as I can't determine which one by your information. You can also call and speak with a tech. at 800-640-2033.
Rainbow Vacuum Cleaner Systems Repair Center
Posted on Mar 28, 2014
Hoover spin scrub 50 leaking from bottom
Uh, may I encourage everyone to check the trigger under the handle...we went through taking the whole thing apart and it was just that the trigger was stuck in the open position, which poured the water out continually!
Apr 09, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steamvac
Let me start out with an apology. I did not ask my question very well - and you did not answer it as I needed.
If you wish, we MAY be able to communicate in your native language. We can do most indian languages, Turkish, Ukranian and some Russian - as well as Spanish. If any of those are easier for you - please feel free to use any of them.
The Machine storage tanks are 2 - one clean water, one dirty water.
I understand that, when OFF, no leaks happen.
I understand that when on a leak comes from "the side". Also, water comes from the bottom.
So, water comes out near the bottom brushes (even without trigger). Then, with trigger, MUCH water comes out near bottom brushes. Am I correct so far?
Water out the side concerns me. I am guessing that the bottom of the clean storage tank may have a small leak.
I am also guessing that the trigger valve (located in the small opening behind the black rubber seal that the clean water tank rests on) is not closing all of the way - or is broken (cracked).
Can you please remove the clean water tank and inspect the trigger valve with a torch (flash light). Can you see it open/close as you operate the trigger? Is it broken, cracked, or dirty?
If yes then it must be replaced. If no, the the storage tank is bad and must be repaired.
You inspect all of these things and you should be able to determine the failure. THEN, I an help you repair the failed item.
-Jim (Raleigh, NC - USA)
Nov 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Trigger on hose attachment not working so water sprays constantly
from your description, the trigger sounds like it is stuck in the release position. this sounds like a very simple repair. The component parts need to be looked at by a service shop
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Water leaks
This model has a resevoir with a diaphram valve. The location of this part in under the clean water tank it has a black round gasket.. Your problem could be a bad resevior or something mechanical with the trigger and rod that when you pull on the trigger, solution is released.
Jan 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Total leak issue
There maybe a tube that has come disconnected, depending where the water is leaking. If at the bottom, then take the top cover off and check for a loose tube. If it is leaking where the tank sits on, could be a tube under that platform, or there is a rod inside the handle, when you squeeze the trigger, it pushes a diaghram where the tank sits, If the rod is going up and down, then it is probably ok, but the diaghram on the reservior asm(#48). is staying open allowing water to go thru all of the time. You may have to replace that reservior asm.
Aug 26, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Constantly sprays water
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=515776&thid=544922
Posted by elstretcho on Apr 25, 2008
Hoover F7452-900 SteamVac Upright Vacuum
I noticed recently that our Hoover F7452 All Terrain constantly sprays water. As soon as I turn it on, whether or not it's set to Rinse or Auto-Rinse, its leaking water at the brushes. I probably wouldn't have noticed but I attached the hand-held adapter to clean our stairs and when I was done there was a HUGE pile of water under the vac. I took everything off and cleaned really good and looked again this morning and its still doing it. Any ideas?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You probably have a bad trigger release valve or a loose connection @ the bottom of the SteamVac or the gasket under the solution tank in not sitting on there right and is leaking or you may have a small cut in the hose, but it so may guess that it is a bad trigger release valve or a bad gasket. Check with your local vac dealer to see if they have a new or a good used one to see if there is the problem or back track the problem from the bottom to the solution tank. So If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 25, 2008 | Hoover F7452-900 SteamVac Upright Vacuum
Water coming out w/out trigger being pressed
You may have a problem with the valve at the bottom of the tank, or a water line has come loose. How old is this, there is a 1 year warranty, so if less then a year, take it in for repair.
Feb 19, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Plugged water line?
The trigger in the handle is clipped into two plastic snaps. When the trigger is pressed, the trigger pivots in these snaps and the pressure is transmitted through a rod connected to the trigger down to a valve located under the water tank. If the machine has been carried by the top handle insead of the carry handle that is incorporated into the water tank, the extra stress on the trigger will break off the snaps and the trigger will not function properly. Take the water tank off the machine and press the trigger. Observe the valve below the tank support and see if the rod is pressing down on it.
You might also check the hoses that come down the handle where they turn at the bottom of the tank. Sometimes they kink there and this will restrict water flow.
If you have been using the wrong shampoo, that is shampoo not designed for hot water extractors, it is possible for it to congeal in the lines and plug them.
Jan 27, 2008 | Hoover F5807 SteamVac Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
539 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
