Invalid model configuration on a kodak Ngenuity
Kodak Ngenuity 9090dc
5 Suggested Answers
Agent Allan
  • 480 Answers
SOURCE: No power to my new Kodak - Series 3 EasyShare Dock for Select Kodak EasyShare Digital Cameras
Hey ditzydiana,
If you just purchased the camera and you are already having problems with it I would not try to troubleshoot the problem I would exchange it for a new one. If you purchased the camera from a Best Buy™ store the return/exchange period on the camera is 14 days. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jul 29, 2008
SOURCE: Kodak Easyshare camera turns on and off
Hi, here is whats going on, if your M763 is powering on for 2 secs and the lense opens up then go's right back in, there is a 90% chance you got sand in the unit from say the beach ?
here is a test , when you press the power buttion watch the lense you will notice that the bigger part rotates as it comes out, what you want to do is give it a little help Lightly rotate it abit more just at the point where it normaly stops and go's back in, the cam will prob stay on and work like normal.
now the hard part 2 things to try, a can of AIR from walmarts try to blow out and sand thats around the rings, i did this and have fixed about 20 of these's now, on the others you will need to take it apart and clean the gears and mech of the lense housing then put it all back together.
hope this helps
IST tech
Chris
Posted on May 26, 2009
  • 489 Answers
SOURCE: What "Printer" to choose?
Your pronter should have come with a driver disk. You should disconnect your printer from the computer and run the installation from the disk. When prompted, connect the printer to the computer to complete the installation.
Posted on May 27, 2009
gemmy23
  • 346 Answers
SOURCE: Kodak Easy Share Back Web Error
It sounds to me that you have the backweb (virus) on your pc and its trying to run,and therefore you are recieving the error message...
First thing is...Enter ADD/REMOVE programs and see if any program is related to,or is backweb and remove it...Then enter the TASK MANAGER and see if it is running,and end the process IF it exists...Then proceed to C:PROGRAM FILES-and look for a sneaky folder called,i think it was DESK MANAGER,and click on it and read it contents to make sure it backweb related and remove it...
You might have to reboot and enter safe mode if it gets stuborn to remove it..Finally enter the registry and, when you press the CTRL>F keys and recieve the search menu,Type in backweb,and remove the keys...When the search comes back as finish searching through the registry with no results,i would reboot your pc a few times and re-enter the registry,and re-search the back web keys to make sure that windows didn't forget a few.
If that doesn't work you may have to actually go into the registry and delete the files associated with back web that way. If you are computer savvy then you might want to find someone else to do this as it can be quite tricky. You don't want to take anything off that should be in there.
Another route you can take is to restore your computer to an earlier date. Let me know if you need directions on how to do this.
Posted on Aug 08, 2009
How do i charge my kodak 8.0 digital camera
What model Kodak 8.0 megapixel camera? The M1063 is a 10 megapixel model.
Some Kodak cameras can charge the battery when you connect the camera to a power source. Some Kodak cameras come with a separate battery charger. Some Kodak cameras use disposable batteries. Without knowing the model of your camera I can't tell you how to charge your camera.
Jul 15, 2014 | Kodak EASYSHARE M1063 Digital Camera
Feed hopper wont rise up no error
Please contact Kodak Service & Support - 1-800-822-1414. This problem requires field support.
Mar 20, 2014 | Kodak Ngenuity 9090 Db - Document Scanner...
Kodak easyhare software won't download invalid calling object
just click the red button "share" on your camera, then disable sharing, if you have the device connected to a computer, automatically it will open the content of your camera as if were a pendrive or an external hdd, problem solved.No need of kodak addon software.
Jun 14, 2013 | Cameras
My KOdak Easyshare LS743 camera error #45
This is a lens error. KODAK suggests a repair for this fault.
However due to spare part shortage this model is no longer repaired. Instead KODAK offers a trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 17, 2010 | Kodak EasyShare Z700 Digital Camera
When connecting the Kodak C913 to the computer, the USB hub will not receive information from the Kodak. The driver is failing for some reason, giving the error message (during reinstallation of the...
Possible solutions:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
If all fails please contact KODAK in order to arrange a repair or order a new cable. Remember you cable is covered under the same warranty as the camera, so if covered you need the serial number of the unit:
Jan 08, 2010 | Kodak EasyShare C913 Digital Camera
Camera code e45
Lense fault. It requires a repair, however due to spare part shortage KODAK no longer repairs this camera model. Instead they offer a trade up: Since you have a KODAK model. They will offer you a current model for 25-30% less than market price.
Contact KODAK:
Nov 14, 2009 | Kodak EasyShare LS743 Digital Camera
May 17, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Black ink is faded or doesn't print at all
Once installed, Kodak All-in-One printer Home Center software allows you to print, copy, scan, and configure your All-in-One printer from your Windows XP or Vista computer.
To open the Home Center software window on your computer, use the Home Center icon on the Desktop or in the Start Menu
From the All-in-One printer Home Center main menu, selecting one of the six menu items enables you to:
  • Scan pictures and documents
  • Enhance and copy pictures
  • Enhance and print images
  • Configure settings for printing, copying, and scanning from the control panel
  • Access the Kodak Tips and Projects Center Web site.
  • Order supplies from the Kodak Web site.
Dec 17, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Order says invalid zip code - not true
Contact The Kodak Online Store Phone number so they can help you set up the order.
Aug 26, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
93 people viewed this question
jasbo
jasbo
