Invalid model configuration
Kodak
Why Is the VLAN Priority Configured on the S5700 Invalid?
Fault Symptom The outbound interface of the switch joins a VLAN in untagged mode. When the remark 802.1p command is configured on the outbound interface, the configuration is invalid.
Cause Analysis The configuration of the S5700(such as S5700-28P-LI-AC)is as follows:
traffic classifier test
if-match any
traffic behavior test
remark 8021p 2
traffic policy test
classifier test behavior test
interface GigabitEthernet1/0/1
port link-type access
port default vlan 10
traffic-policy test outbound
The outbound interface joins a VLAN in untagged mode, so VLAN tags are removed from packets sent by the interface.
Conclusion To apply traffic policy defining remark vlan to the outbound interface, ensure that the interface joins a VLAN in tagged mode.
Jun 22, 2016 | Electrical Supplies
Kodak easyhare software won't download invalid calling object
just click the red button "share" on your camera, then disable sharing, if you have the device connected to a computer, automatically it will open the content of your camera as if were a pendrive or an external hdd, problem solved.No need of kodak addon software.
Jun 14, 2013 | Cameras
Invalid System Board
Open the BIOS, is the time correct? Consider replacing the CMOS battery. You didn't mention the Make , Model of computer or the OS.
Jan 04, 2013 | Computers & Internet
Real time clock failure. Invalid configuration
..plz do check the following as in order:..
the Hardware part:..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..change if required..
6)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
7) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
8)on main/mother board..see with a debug card for mb error..may bshort..look for defective capacitors(esp above1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
if u r not a professional, always better to seek advise from ur system admin/vendor....
Nov 16, 2009 | Intel Computers & Internet
Dell PE 1600SC invalid memory configuration detected
You may need to install memory in matching pairs. If the new memory is a single 1Gb module and you didn't already have a similar one they may not work together. Try removing the original module(s) and see if it makes a difference.
Oct 28, 2008 | Dell OptiPlex GX280 PC Desktop
Order says invalid zip code - not true
Contact The Kodak Online Store Phone number so they can help you set up the order.
Aug 26, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Invalid partition
wat is the model of the systemand the os of the system did you try the last known configuration .if not try the safe mode .if you could provide the info i might be able to help
May 22, 2008 | A Computer By Design Computers & Internet
Invalid Configuration information
Windows Registry help First, get the computer to a MS-DOS prompt. Information about how to get to a ... that contains information about the current configuration of hardware ...
FTP information and help
Information about FTP and its commands. ... If you are unable to connect to any address, it is likely an issue with the network or computer configuration. ...
Device Manager information and help See our overview section for additional information on how you can get into ..... but the configuration information in the .inf file is set to hardwired. ...
Good Luck, Please dont for get to Vote.Thank you
Dec 14, 2007 | Dell Inspiron B130 Notebook
may be ur pc not supporting 1gb so make it small means get less than 1gb than try.
Nov 27, 2007 | Intel AC450NX Server
26 people viewed this question
jasbo
jasbo
