Question about Pit Cycling
Hi my 125 starts but cuts out
Its got a new carb and electrics was out on it earlyer it back fired then cut out it started after few kicks then cut out again when i pulled away it dose start then cuts out could it be piston or timing
  • graeme
    graeme Mar 28, 2014
    for got to say its a 4stroke
  • 4,731 Answers
The carb float level is probly off--u need a repair manual for that model or ask the manufactur the measurement------may also b gittn a weak spark-----library has a motor section in ur city
Posted on Mar 31, 2014
  • 9 Answers
SOURCE: My XB-300Li motor cuts out after riding about a mile or so
Sounds like overheating alright. How is the weather? If its over 80 it might only be that. If it is cooler, then if you are running the recommended volt/amp battery pack you may have a bad temp sensor on your control board. If you are using a higher powered battery to boost speed then you will have to cool the motor or get a more powerful one that can take the load. I do not have that mode bikel, so I can not say if it is a common problem, It is not a problem with my 24 volt Lafree.
Posted on Jul 12, 2010
  • 104 Answers
SOURCE: I cant start a pull start mini pit bike. Its pull
Spray a small ammount of starting fluid into the aircleaner. It will fire much easier and should start if your ignition is ok.
Posted on Aug 28, 2009
ollie reece
  • 1167 Answers
SOURCE: I just bought a 2 stroke 49 cc atv. Everything was
hi mate are you mixing the bike with 2 stroke if not buy a mixing bottle with a ratio of 32/1 on ebay and buy 2 stroke and mix it up with petrol and oil if not the engine will seize also take the spark plug out and give it a clean with a wire brush and check the gap is ok and then put it in the plug cover and put the plug against the cylinder and turn the engine over and see if there is a descent spark if not replace the plug good luck
Posted on Jul 23, 2009
dbdrive2011
  • 12 Answers
SOURCE: 50cc mini atv wont start
do a compression check if its under 100 psi could be piston rings are bad or leaking gaskets.
Posted on Mar 31, 2012
SOURCE: I have 110cc kids quad tired of trying to fix electricals can i add a pull start to engine
yes i had one put on through honda in melbourne
Posted on Apr 03, 2012
Testimonial: "thanks for the answer, but cannot get anyone here to work on chinese motor, at least i now know it can be done."
Why my pitbike wont start or cuts out
Yep, clogged fuel filter, dirty carb. ????
Mar 24, 2013 | Pit Bike 125cc 4 Stroke Dirt Bike
Gilera runner 125 st 2008 cuts out by arcing
coil lead plug cap needs replacing , no shield to protect spark plug from getting wet due to weather/water splash. electrical spray lubricant requires from damp start problem
Dec 29, 2012 | 2008 Gilera Runner ST 125
I need help with my rm 125 1995 it has a perfect spark iv cleaned the carb and it don't start but wen I take the spark plug out then I kick it then screw the spark plug back in the kick it it nearly...
the way you explain this, the fuel and air mix is wrong, is the spark plug wet, if it is check the carb air mix screw. remove the mix screw and use a can of air and blow it out. before doing this remove the air filter and the spark plug then spray some wd (brand name) in hole and do again with the air can. then screw back in. leave the air filter off. and put spark plug back in and start the engine you will need to adjust the screw until you can get it to start. when it does give it a few good revs and keep it running for a bit. replace the filter and start engine and you will need to adjust the air screw till the engine sounds right again.
Feb 01, 2018 | 2003 Suzuki RM 125
Hi I got a 98 yz 250 new clutch plates piston negosiled barrel new ring and shortcut the gears I kicked it and it started on the 3 rd try I ha then added more fuel and mixed 200 ml oil to 5 liters petrol...
Replace the spark plug to new one they rarely come good or be reliable once fouled shouldn't need to clean carb but if were mine I would clean it anyway
regards Jamie
Aug 04, 2011 | 2008 Yamaha yZ250
Take to long to start.. takes almost ten minutes of kick starting... electric starter wont turn over to start bike yamaha ttr 125
The TTR-125 Carburetor's Run Lean by design. Mine had the same issues till I found a post on Thumpertalk.com on Carb and air box Mod. This is a good starting point on gets; 110 and 112.5 main and 17.5 pilot. But you must check spark plug coloring to make sure the jetting is correct. Check spark plug after the bike has been ridden for a wile. I also took out the stock baffle and replaced it with exhaust tip and now it fires up after a few kicks and worms up in a few minutes.
Dec 15, 2010 | 2005 Yamaha TT-R 125 L
My bike wont start electricly.i have to bump srart it and it just backfires and after a few attemps it starts and then cuts out after 5 or 10 mins....
Try taking the jets out of teh carb and soke in carb cleaner and get a tiny wire and THOUROGHLY clean the jet holes. You may be able to see through the holes, but if there just a tiny bit clogged those holes are not allowing enough gas to get to the carb!
Jun 21, 2010 | 2000 Honda NSR 125
To keep my engine running i have to pull the throttle obviously to rev it, else it the engine cuts out, and when i ride it splutters and cuts out, so i kick down a gear n it starts again but then dies...
has the bike been sitting for some time? Sounds like a classic case of gummed up low speed jets in the carbs. Pull the carbs and clean then out.
Mar 11, 2010 | 2000 Aprilia RS 125
Gilera runner sp50 - engine turns over but does not start
you went through the electric. system, now check fuel supply filter, tank, valve carb bowl for dirt
Aug 08, 2009 | 2005 Gilera Runner VX 125
99 cr80 starts but cuts out at the top end of 4th gear. jets and carb clean air filter clean just had a new top end and new packing in exhaust
cuts off or breaks up?? if it breaks up it could be a couple of things bad reeds or electrical like stator or cdi bog ign coil check those
Jul 11, 2009 | 2002 Honda CR 125 R
Cycling Logo
56 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Are you a Pit Cycling Expert? Answer questions, earn points and help others
