Question about Canon Pixma MX420 All-In-One Printer
My printer is not printing properly. Print job is completely shaky.
It's not printing clearly and it's so bad it's to where it's hard to read the script and can't even make out the picture. I've tried resetting it, cleaning, print head alignment, nozzle check and it hasn't improved. I've also tried the "prevent abrasion" setting in printer settings and it worked for a while, approx 2 weeks, although it was still blurry around the edges and now it's gone back to not being legible. Help??
    New Friend:
  • 35 Answers
First try making a copy on the printer itself. How does this copy come out? If the copy comes out okay then try deleting the printer and reinstalling it. Sometimes printer drivers can get corrupt and cause problems. If the copy comes out bad then there might be something wrong with the print head.
Posted on Mar 31, 2014
SOURCE: Printer will not use the magenta color
I had the same problem. It is most likely that your print head nozzles are clogged. Your choices are to attempt to manually clean them, or order a new print head from Canon.
Attempt the manual cleaning at your own risk, this doesn't always work. When it does not work, it means your print head is damaged.
To maually clean the print head. Printer cover up (so you can get to the cartridges and print head). Turn the Printer Off. Remove all the cartridges (I put each cartridge in a separate zip lock bag). Then flip up the lever and remove the print head.
Now heat (don't boil) distilled water (Iused a good sized cook pan and a plastic measuring cup to pour the water). Find a container you can soak the print head in (I used a deep alluminum baking pan). Pour the hot (not boiling) distilled water over the print head molding where the cartridges seat down (hold the printhead over your diposable alluminum pan). Then dunk the molded print head part into the pan numerous times. When the water gets dark change it (be carefuill not to stain the sink). Then slowly pour the hot distilled over the print head (opposite side from where the cartidges seat in). Eventually no ink will be in the water. Set the print head on a dry paper towel, and let it dry for 24 hours or longer. Reinstall the print head, then the catridges. If it worked, your true colors will return. It make take up to 15-20 photos to get all the ink catridges flowing-be patient. You can also just wait 24 hours after re-installing the cartridges, and hopefully it will take less photos to see the correct color match.
Never keep printing when a cartridge is low or out.
Print a few prints every week. Not printing for weeks causes the printheead and the ink flow to clog!
Good luck. I just recovered my S820 and my i900D using the above cleaning method. Like everything else, your mileage may vary! It cost me $1.29 for distilled water and about an hours worth of time!
Posted on Oct 20, 2008
artifixit
  • 59 Answers
SOURCE: Unclear Printing
Your print head is most probably blocked.
First try and run the cleaning program a few more times, it make penetrate deep enough to get through.
If that doesn't work you can either replace the print head or try and clean it.
To clean it you could soak it in a mixture of window cleaner and water (filtered best), but don't let the electronics get wet by this and try to avoid wetting the rubber seals where the ink tanks go get wet by this too, it should only soak the very bottom part of the head.
Let it dry off and wipe any residue with a soft cloth especially on the bottom where the print heads actually are. You may need to soak it a few times to get all the gunk out.
Posted on Jan 25, 2008
SOURCE: All colors not printing
Replace the print head, which is very simple, and they are readily available on ebay for about $40. I had no black print, and I replaced it and it immedicately fixed the problem.
Posted on Mar 16, 2008
SOURCE: canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Posted on Apr 03, 2009
supertech6
  • 513 Answers
SOURCE: Print head seems to be out of alignment.
Run the alignment in the maintenance software. Each new print head must be aligned.
Possibly release and remove the print cartridge and reinsert it. Maybe it is skewed.
Posted on Mar 21, 2010
Document will not print; status reads deleating-printing; printer appears to be frozen; does not print any other items...
Kill the job on computer that sent the print job. If the job fails to clear you can stop and start the print spooler
Right click My Computer > Manage > Services.
Right click Print Spooler > Stop then Start. That should clear the job.
Same principle pertains to a network printer, but needs to be done print server.
Sep 24, 2012 | Lexmark International Lexmark 8300 Series
Tip
49.*** error
If you notice an error 49.*** on the printer's screen, follow these steps to reset your printer and get you printing again. First, turn off the printer. Second, Go to the print queue on the computer (this assumes you have full access to the queue, admin rights). Clear the most current print job in the queue. Note: The print job may be one of two things: A pdf file or an attachment opened from inside your email program. If the print job was from an email, do the following - Save the documant locally to your hard drive, open it from that location and try to print again, but only after you have completed the rest of the steps below. Also, I've noticed that most of the time the computer's operating system is Windows 7 and above. Microsoft and HP have not provided any support to this problem as yet. Third, once the print job has cleared the queue (this can take a few minutes), go to the printer and turn it back on. If you have other jobs pending they may print once the printer has come up to the "Ready" screen and has completed it's handshake with the network or USB connection. That should at least get you printing again without having to place a service call! I hope this helps. If you are in the San Diego County area visit our website www.docuflowsolutions.com and give us a call. We are here to help.
on Sep 22, 2014 | HP Office Equipment & Supplies
LaserJet 4350 Printer: HP 4350 printer, 49.2F9D service error...
1st thing to do is upgrade the firmware. Go to hp.com and look for the software and drivers. Drill down to the firmware and read the instructions.
May 16, 2010 | HP LaserJet 4350 Printer
We have a spooling problem. The sharp mx-2300n just says "ripping" and 20% complete but won't move from there and print anything. Can cancel print job from Mac but won't stop anything at the printer end....
Go into the Job review mode and highlight the pending print job (note: it may be stuck in processing). You should then get the option to delete the job.
Make sure that the pending print job is also cleared from the network print queue. They can sit in the queue and be persistent on processing, even after you've cleared the copier. Clear the queue prior to deleting the job on the copier.
If this doesn't, disconnect the copier from your network and try the above steps again, then reboot the copier and reconnect it to your network.
If you're trying to print out Adobe-based web pages from the internet, this may be what's causing your copier to jam up. There's known coding anomalies with Adobe-embedded documents on web pages. Trying to directly print from the web page can stall or lock up the print process.
Sep 07, 2009 | Sharp MX-2300N Color Copier
Need to print a report of past print jobs
If you have CentreWare IS you can do the following (taken from the manual):
You can find the manual link here: http://www.office.xerox.com/userdoc/P6250/6250_Web/pdfs/reference_guide.pdf
On page 97 of the manual it states:
Using Printer Management Features
Job Accounting
The printer stores information about print jobs in a log file. The log file is stored either in the
printer’s memory or on an optional hard disk if one is installed in the printer. If the log file is
stored in the printer’s memory, it is lost when the printer is reset. It is recommended that a hard
disk be used for job accounting.
The log file lists job records. Each record contains fields such as user name, job name, pages
printed, job times, and toner and ink used. Not all fields are supported by all printers. For
information go to CentreWare IS online help or CentreWare Web online help.
The job accounting values reported vary depending on the protocol and print command used
when each job was printed. For example, using NPRINT over NetWare provides the printer
with the most information about the job being printed. When using Windows and NetWare, the
job name is often LST: or LST:BANNER. Other jobs from other ports may provide less
information about the job.
Job accounting is available through CentreWare IS and CentreWare Web.
Using CentreWare IS
1. Launch your web browser.
2. Enter your printer's IP address in the browser’s Address field (http://xxx.xxx.xxx.xxx).
3. On the right side of the main CentreWare IS page, click Jobs.
The “Job Accounting Links” page provides links that enable you to browse, download, and
clear job accounting records.
For complete information on CentreWare IS job accounting, including clearing job
information, downloading job information to a file, and job accounting file formats, go to
CentreWare IS Online Help.
Hope this helps!
WizardRepair
Jul 17, 2009 | Xerox Phaser 6250DP Laser Printer
Printer stopped working after I cancelled a print job
Turn off your printer and completely unplug the USB cable (from both the printer and the computer). Next check if the stopped document or the later documents are in the print spooler queue. If you can cancel all documents from the queue, do so. Otherwise: from Start Run (or the command prompt)
type: net stop spooler [enter]
then type: net start spooler [enter]
This works in XP and older MS Operating Systems but I've never tried it in Vista.
If you only enter the first command, you need to reboot the computer and then take a long coffee break after logging in before trying to print again.
May 06, 2009 | HP Deskjet D1455 InkJet Printer
Canon pixmaip4000
Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
  1. On the Windows taskbar, double-click the printer icon located to the left of the time.
  2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
  3. From the 'Document' menu, select 'Cancel'.
  4. Repeat steps two and three to cancel another print job.
  5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
    1. Close the Printer window.
    2. Shut down the computer.
    3. Disconnect the printer cable (USB or parallel cable).
    4. Restart the computer.
    5. If a message window appears asking to cancel printing, select 'Yes'.
    6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
    7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
  6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Reset Job on Workcentre 24
You need to also clear it from the computer. Open the printer properties on the pc to see if the job is still present. If so, cancel it.
Apr 07, 2009 | Xerox WorkCentre M-24 Color Copier
Hp psc 2210 all-in-one printer is busy
I replaced the black ink cartridge and my printer keeps saying press enter to
align cartridges. I have done this a dozen times using up paper and ink and it
still says pres enter to align cartridges.
Jan 18, 2008 | HP PSC 2210 All-In-One InkJet Printer
Not printing
pls reomve all the print job from print spooler like just double click on the printer icon it will shows the list of pending job pls clear all the documents and restsrt the sytem and then give the print command it will work.
Oct 09, 2007 | HP DeskJet F380 All-In-One Printer
Canon Pixma MX420 All-In-One Printer Logo
112 people viewed this question
old marine
old marine
