Question about Runco Office Equipment & Supplies
Runco CL-410 picture cuts out, sitting on side works fine... is this a ballast issue?
My Runco CL-410 project when sitting on its belly or upside down cuts out after 30 seconds or so. Power will stay running as if nothing happened. But, when I sit it on either side, everything works fine and normal. Insides are clean, no dust, I had reset the lamp hours, and reset everything to factory... My friend says he put a new bulb in it, could the bulb be defective? or could this be a ballast issue. Thanks!
2 Suggested Answers
  • 14 Answers
SOURCE: My Runco CL-410 projector runs
Look inside the lamp. If you look into it if you see any white build up at its base, replace it. Need help, let me know.
Posted on Feb 28, 2011
Runco CL710 projector. Had power outage and projector won't turn on. Project was plugged into surge protector. Surge protector is working, green light is on. Checked all electrical breakers, they are...
The capacitors on the power supply need to be replaced. When you take apart the projector, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video for this.
Aug 25, 2013 | Runco CL-410 Multimedia Projector
My RUNCO projector is projecting upside down and we cant seam to fix it. Any advice?
1. Press the menu button on the remote to bring up the on-screen menu. 2. Select the Setup Menu 3. Select Picture Orientation 4. Change the configuration so that the image and text appear correctly.
Feb 28, 2011 | Runco Reflection VX-1c Multimedia...
My Runco CL-410 projector runs for about 30-45 seconds, then the lamp turns off. The hour meter says it has 471 hours on it. Any ideas?
Jan 09, 2011 | Runco CL-410 Multimedia Projector
The picture on our runco projector is upside down
in the menu there is a picture flip option. some projectors can be mounted on the ceiling which you will have to do this, you just need to put it back. keep looking in the menus and you will eventually find it.
Jul 19, 2009 | Televison & Video
Runco CL710 Pass code required
I have the passcodes pdf for most models, let me know..
Feb 03, 2009 | Runco CL-410 Multimedia Projector
CL-610 RUNCO PROJECTION SCREEN IS UPSIDE DOWN. Some one touched the remote control and I am at a loss to fix problem.
turn on your projector as usual, and using the remote, press the 'menu' button.
the menu will appear on the scree (albeit upside-down), and your looking for a setting like 'setup' or 'orientation'.
some runco's need a special code to get into some menus, but the orientation selection should be easy.
once you find the menu, there are usually 4 choices; front projection/floor mount, front projection/ceiling mount, rear projection/floor mount, and rear projection/ceiling mount.
the most common is 'front projection/ceiling mount'
Dec 08, 2008 | Televison & Video
Need to adjust from full screen to wide screen on Runco SC3050
You need to use the remote, press the Menu button... on the menu that pops up on the screen, use the remote to scroll down to where it says "aspect ratio", and then select enter.
From that menu, you can select all the different aspect ratios that your Runco can perform.
Here is a link for the owners manual, straight from Runco.
http://runco.com/legacy_prods/legacy_manuals/CL-510_510LT.pdf
Oct 11, 2008 | Runco CL-510LT Multimedia Projector
Screen goes blank after 5-6 minutes but sound continues
It may be overheating, check fans and or obstructions of the vents
Sep 02, 2007 | Runco CL-410 Multimedia Projector
16 people viewed this question
Top Runco Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Are you a Runco Office Equipment and Supply Expert? Answer questions, earn points and help others
