Question about Janome Memory Craft 5700
Screen won't respond
Tried the solution you suggested for technical problems. At the end of procedure my machine says "adjustment end". I turn off the machine and power back up and am confronted with the same problem. Suggestions?
  • 23 Answers
We believe that it is a problem from the touch screen and you need to replace it. We do have this part in stock if you need it. You can contact us through email sale@sewingmachine.com.au or go on our website http://sewingmachine.com.au/index.asp .
Posted on Apr 13, 2014
Bernina 880 will not respond to touch screen
Recalibrate touch screeen:
Access is achieved by simultaneously pressing the needle position buttons < > and at the same time switching the machine on.
• Brightness is adjusted by turning the stitch length knob.
• Touch the cross symbols on the touch-screen for calibration.
Jan 01, 2017 | Bernina Sewing Machines
How to open fixed screen? on Designer 1
I would check the Touch Screen first. Your Owner's Manual tells you how to calibrate the touch screen from the SET menu. However if the touch screen isn't working, you can't get to the SET menu. Suggest taking it to an authorized Viking Dealer and they would be able to quickly determine the solution. You can find the nearest dealer by going to the Viking website - http://www.husqvarnaviking.com/us website and click on 'Locate a Dealer'.
Jun 10, 2014 | Husqvarna Designer I
Probably needs a replacement Touch Screen...please
Contact Us at Bargain Box
Mar 31, 2014 | Janome Memory Craft 5700
My Bernina Artista 180 won't turn on
here is a link for bernina, click on the link and it will take you to
the contact us part,, choose which option you need, maybe
technical support contact them ask them if there is a hidden
http://www.bernina.com/en-US/Company-us/Contact-us-1
Mar 29, 2013 | Bernina Artista 180
My Designer 1 sewing machine touch screen is frozen and won't calibrate or respond to touching. This is intermittent behavior. Sometimes it works, and sometimes not. Can you tell me what this is
Sounds to me like the plug-in connector from the screen is not firmly attached to the motherboard (directly behind the screen but inside the machine). This kind of problem doesn't take a factory trained technician. Ask various sewing machine dealers to whom they subcontract cleaning and adjustment. Ask people who sew whether they have the name of a repair person. Taking apart the machine and replugging the connection should be all of a 15 minute job.
Feb 23, 2013 | Husqvarna Designer I
Tension of pe770
Besides the other advice here, check your bobbin case. At first I didn't get my thread hooked into the bobbin case properly and had problems that looked like the bobbin tension was not adjusted properly. I have to take the case out, put in the bobbin to make sure it's caught properly and then put it back into the machine. This is what worked for me.
Mar 14, 2012 | Brother PE770 Computerized Sewing Machine
Sewing machine tension problem
if you've tried to adjust the top tension & the dial is not responding then the tension dial may need to be replaced because sometimes they do go bad
a sewing machine shop can tell you for sure
Mar 10, 2012 | Sewing Machines
My bobbin thread keeps looping and the top looks fine but pulls out easily. I tried adjusting the top tension, but it didn't help. What can I do?
There could be several things that could cause the machine not to pick up the bobbin thread.
1. The upper thread could be tangled. Remove the thread completely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine according to the directions in the manual.
2. Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
3. You could be holding the needle thread too tight. Hold the thread lightly to keep the end from going down into the shuttle.
4. The needle could be thread incorrectly. Thread the needle eye from the front to the back.
5. The needle could be bent or improperly inserted. Install a new needle with the flat side of the needle facing the back.
If the problem persists, your machine may require service.
The bobbin thread tension has already been adjusted at the factory for general use. For most applications, no adjustment is needed.
When sewing with then thread on thin fabrics, the thread tension may not be adjusted adequately with the upper tension control dial. Therefore, the thread tension must be adjusted according to the procedure described below.
If bobbin tension is too loose and locks appear on the surface of the fabric, decrease the thread tension by turning the dial to a lower number.
If the result is still not satisfactory, then adjust the bobbin thread tension.
Increase the tension in the bobbin by turning the screw with a small screwdriver in a clockwise direction. However, do not turn the screw more than one full turn.
Jun 19, 2011 | Brother XL-5340 Mechanical Sewing Machine
When I turn on my designer 1 the needle is off center to the right, not centered. Also when selecting a zig zag or other decorative stich it sews something different. Have tried recalabrating the screen no...
These machines are computers are just that: COMPUTERS. Nothing to do but have a mechanic ltake a ook at it for possible fix. It is not communicating with the brain since settings are off. There is a manual on ebay for $5.99 that is a three-part CD and I suggest you go on-line and buy it. It will hep with parts, service and how-tos for your D-1. I have it and find it invaluable for fixing my own machines. Hope this helps.
May 14, 2009 | Husqvarna Designer I
Sewing Machines Logo
27 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
